Results 1 to 13 of 13
Thread: Upgrading Fuel Pump Assembly
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Measured the fuel pump pressure, one side was hitting 70psi and keeping the pressure, the other hitting 60 and bleeding off to 0 within minutes.
    While running at idle in line pressure gauge was showing 40psi on one side and the other 36psi.
    We took the pump assembly out and changed out two hoses, it helped a bit but the problem was still there.
    Decided to upgrade both pumps with 340 LPH aftermarket pumps(stock pumps are 255lph). At the same time got rid of those twisty hard lines that I was pretty sure were leaking at the connectors and installed submersible fuel lines directly connected from the pumps to the assembly.
    Replaced all the cracked wiring.
    The pump holder needs to be modified at the bottom so the new pumps would fit. Basically a hole cut out to fit. Very easy! The aftermarket pumps come with a jacket that makes them a perfect snug fit inside the holder. The hardest part was fitting the hoses, use lube
    Sent from my SM-G925T using Tapatalk
    Sunny Cali,
    6.5 second 69 Camaro
    Great info!
    Is It holding a balanced pressure now and not overwhelming the regulators? Be nice to get a crack proof fuel carrier.
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Quote Originally Posted by 8eights View Post
    Great info!
    The fuel pump assembly is re installed on the car. Have not run the pumps yet because I am changing the fuel filters and the molded lines, I will post another thread tomorrow on that procedure with some cost saving tips! I am very confident in this set up, 220psi line directly to the carrier nozzle. Unlike the OEM pumps, these can rotate inside the holder allowing for straight shot and eliminating stupid plastic twisted hard lines!
    Yeah cracks in the carrier itself is a deal barker, thankfully my car only has 48k miles on it so plastics are not terribly degraded. However fursideup had some success re sealing the carrier with a special Loctite epoxy!
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Excellent work and clear photography, thanks!
    My BMW Repair YouTube Channel
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Started the car today, seemed to run really well. Pumps are strong, filled up empty fuel filters and rails in seconds.
    Here is the link to the pumps. as you can see they come with everything, I just don't recommend using those hose clamps use FI ABA clamps only.
    http://www.ebay.com/itm/191726084011...%3AMEBIDX%3AIT
    Also don't recommend soldering the new wires in, just extra unnecessary work..use crimping tool and connectors to seal wires together.
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    Quote Originally Posted by dragon850 View Post
    ...Also don't recommend soldering the new wires in, just extra unnecessary work..use crimping tool and connectors to seal wires together.
    ...and you were doing so well demonstrating best practices before that... lol Hey, are these "coated" too?
    solder & heat shrink is far superior to a crimp connector, just saying...
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Remember once I get 5k FI miles you gonna have to admit the coating works right here on the forum I believe that was the deal lol
    Sep 2008
    Santa Barbara
    Blasphemy! Me, I'd like my main bearings to go for a lot longer than 5k... lol
    Oct 2008
    liverpool uk
    koenig ks8 /e31 850c
    The pumps you have chosen can deliver 340 lph @ 3bar
    oem pumps deliver 255 lph.
    why not use one pump? No preasure Imbalance.
    great Wright up. Been down this road myself.
    still got 1 lazy pump.
    Del Mar, CA
    91 850i, 01 740i, 06 760
    Has the working fuel pressure changed with the new pumps?
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Quote Originally Posted by koenig d View Post
    Wanted to retain limp home mode ability And not flood the one bank with fuel if that happens.
    Plus I have 24lb injectors so want to make sure they are fed
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Quote Originally Posted by BMSman View Post
    The final pressure is determined by the fuel pressure regulators. But now the pumps can keep up that pressure even when 24lb injectors are removing fuel from the rail at the rapid rate during high rpms.
    Aug 2011
    Charlotte, NC
    1991 850i manual
    Nice work...I should do this too...ah the punch list never ends!
    1991 BMW 850i
    2007 Honda Odyssey
    2017 Hyundai Elantra
    2013 Honda CRV
    2003 MotoGuzzi 850 Jackal
  1. WTB : Fuel Pump Assembly from OBD1 E36
    By Concentric190 in forum BMW Parts Wanted
    Last Post: 04-30-2006, 07:28 PM
  2. when to upgrade fuel pump
    By AKCraig85 in forum Forced Induction
    Last Post: 10-26-2005, 08:43 PM
  3. Anyone have a Fuel Pump assembly around?
    By Steve J. in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 02-18-2004, 01:51 AM
  4. Upgraded Fuel Pump....Suggestions?
    By Spencer in forum Forced Induction
    Last Post: 05-26-2003, 12:13 PM
  5. Upgrading fuel pump questions
    By artemis in forum Forced Induction
    Last Post: 08-16-2002, 08:13 AM
