Agree that it sounds like a couple different items
1) Coolant leak - You might have a coolant leak that needs to be ficed fairly soon, you might have a leak that could fall apart in your hands leaving the car immoble.
How many miles on the car? how many miles since the last cooling system update? There is a lot of brittle plastic that needs to be replaced about every 60-80k on these cars. The neck of the reservoir for the radiator can get brittle and snap off if you grab the cap. The plastic thermostat cover can get brittle and start leaking. the reservoir itself can get brittle and crack. The gasket bahind the thermostat cover can get dry and leak.
Look specifically for telltale puddles under the car to give you hints of where the leak is. Also look for any white residue (dried coolant from leaks). Check the coolant cap and hoses as well as the plastic elbow behind the fan which is the thermostat cover. If those areas are dry, peek under the car ad the front left corner of the bottom of the engine where the water pump is. It will be on the main drive belt. See if there is any indication of coolant leaking there. If nothing obvious comes up, have a shop to a pressure test. Also if the system is over 60-70k, just buy and replace the radiator and hoses, thermostat and cover and water pump. (or have it done).
2) Whistling - Regarding your whistling. start the motor and squeeze the intake tubing around the elbow to expose any non-obvious cracks. look for leaking oil around your valve cover gasket that might indicate a leak and possible vacuum leak there. If you don't find anything obvious to replace based on dry rot or other failure, then see about a smoke test from a repair shop.
Marc Plante
E36 M3/4/5 193k
Konis+ Dinan Springs, Understeer SS, Shepott European steering Wheel, ZKW Ellipsoids, ECIS Intake+ ATE Foam filter, Stromung Exhaust, Recaro SRDs. JVC Arsenal Head Unit. Alpine MRV-F300 Amp, ADS 535i components, JL Audio Stealthbox Subs
My Track Rig:
i7700 / 2080 PC with Assetto Corsa and Content Manager, Samsung Odyssey+ VR goggles
Fanatec CSP wheel and pedals, SSH Shifter, recaro seat. Home built cockpit
Mt Pleasant, SC, USA
