Results 1 to 8 of 8
Thread: Finally defeated by the fan clutch nut, must be getting old and feeble.
    NW suburban Chicago
    hiss by my window
    For a very long time I have removed the fan clutches using a wrench and BFH. This method has served me well, until yesterday.
    I hammered away for several minutes and managed to almost bash the fender with a missed blow as I was getting tired swinging a 3# hammer.
    With a bit of grinding on an old garage door opener bracket I fabricated a crude tool to hold the pulley and it was off in a flash.
    My apologies to all those who've posted over the years struggling to remove a fan clutch where I simply replied with something to the effect of "hit it harder".
    Denver, CO, USA
    93 M5 88 M3 14 i3
    Lol, its hell to get old.
    Mar 2013
    Albany, ny, usa
    96 M3. 94 E34. 98 750il
    I took mine off 2 winters ago. It stays in my trunk just in case i get stuck in traffic.
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by mboor View Post
    That would be fun times on the side of the road trying to start those damn threads with a hot engine.
    Mar 2013
    Albany, ny, usa
    Quote Originally Posted by ross1 View Post
    Normally yes. I have no fan shroud, and the factory air box is no more, There's actually a decent amount of room, it spins right on.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    what is the nominal value of the visco fan clutch for the M50, M52 to open? The same fan clutch part number 11527505302 is also used on S50, S52 engines, Z3, E39, and even an E38 and X. engine.
    I have checked in realoem but there is no info, when I check for my E32 750 M70 it says 92 degree Celsius for 111527502804 visco fan clutch. On the original fan clutch there is only the bmw and Behr logo and the part number.
    As far as I could check, dimensions and connections are same for both, maybe just the bimetal might be slightly different which is probably neglectable.
    Standard t-stat for the M70 is 85 degree C, while the S52 for example runs with 88 degree C. t-stat.
    Looks like all the aftermarket visco fan clutches are not that specific, as there are endless OE part numbers for comparison purpose usually mentioned.
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by shogun View Post
    I don't know the temp they are supposed to work at.
    Something I have noticed with some replacements is that they seem to open late(some seemingly never) as they are noisier, perhaps they are meant to also swing a larger fan. The aftermarket might be more concerned with consolidating numbers/applications than a bit of fan noise.
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
  1. Replies: 5
    Last Post: 09-03-2015, 03:56 PM
  2. Hung up on the Fan Clutch Nut - Advice?
    By royAdler in forum 1983 - 1991 (E30)
    Last Post: 09-15-2013, 06:13 PM
  3. Is the fan clutch supposed to be stiff when turning by hand?
    By eclipseguy in forum 1992 - 1999 M3 (E36)
    Last Post: 03-29-2009, 12:13 PM
  4. i must be getting old
    By barry8108 in forum 1976 - 1989 (E24)
    Last Post: 03-18-2008, 05:32 AM
