Results 1 to 22 of 22
Thread: 3" Exhaust that doesnt suck
    Apr 2013
    Alabama
    1995 M3 Coupe
    After running around with the RMS headers last night and suggestions from my fabricator and posts on here, its become apparent that the Active track pipe (Says 3", drops down to 2" in the muffler) and Eisemann rear section are now holding up the exhaust flow. I want to move to a 3" but I still want to be able to take this car on long trips without dealing with drone. I looked at the Bimmerworld 3" setup but I've seen a lot of folks state that its just loud and drones like hell. Anyone have a custom setup that they daily that does well?
    Or do I hack up my Active and put in a higher flowing muffler?
    1995 M3...Screwed
    Manchester, N.H.
    96 332IS 6466 turbo
    Put in a 3 inch electric cutout.
    1996 332IS
    Built 3.2
    CES cutring, 666 T4, Precision 6466, spraying a "$π!℅" load of meth.
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
    Toronto, Canada
    D3 A8 4.2 - E36 Turbo
    Drone generally comes from a lack of mid section muffling (resonator). Overall loudness generally comes from rear muffler selection.
    More restriction generally means quieter.
    E36 DYNO TUNING WIRING PARTS
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    I used to havea 3" with a vibrant ultra quiet res in the middle and a Borla xr1 in the rear and it didn't drone.
    H&R Coilovers - Powerflex LCAB/RTAB - Apex Arc8 Powder Coated Gold(17x9) - S52 Swap - Built Head- Built Bottom End- Borg Warner S256sx- Boost Logic- Tial 50mm/44mm - TRM 60# Tune- Full 3" Exhaust w/Vibrant & Borla - Auto>Manual Swap - ZHP Shift Knob 463whp/411wtq at 13.8Psi
    Kirkland, WA
    1999 M3 Fern Green
    I have a 3" exhaust for sale right now. I will see if I can get the PO to provide some sound clips as I never installed it. Would be willing to work out some sort of trade for the AA "b" section as I need that anyway.
    https://www.bimmerforums.com/forum/s...naflow-Muffler
    Apr 2013
    Alabama
    1995 M3 Coupe
    Quote Originally Posted by Alpine 318is View Post
    Let me think about it...to be honest, you might install that, you'll get a decent bump in power
    Quote Originally Posted by rajicase View Post
    Just listened to some XR1 clips, like the sound. What are you running now?
    1995 M3...Screwed
    Feb 2012
    1995 BMW M3
    I am running a magnaflow center muffler and a borla xr1 rear muffler; 3.5"
    Apr 2013
    Alabama
    1995 M3 Coupe
    You should update your sig
    1995 M3...Screwed
    Mar 2012
    Birmingham, AL
    99 m3
    Quote Originally Posted by Jab31169 View Post
    I have built about 5 exhausts. Na and turbo. Always use a resonator and a big muffler and it will be nice once it breaks in.
    I prefer the big oval muffler sound.
    Vibrant gear is nice. We shoulda built you one while i was local.
    1989 535i - sold
    1999 Tiag/Dove M3 - sold
    1998 Turbo Arctic/black - current
    2001 Lightning - current
    PTE6870 | 1.15 ar | Hp Cover, Custom Divided T4 bottom-mount, 3.5" SS exhaust, Fx725 twin ceramic, Dual Turbosmart Compgates, Turbosmart Raceport BOV, 3.5" Treadstone Intercooler, 3.5" Vibrant resonator and muffler, Arp 2k Headstuds | Main studs | 87mm Je pistons | Eagle rods | 9.2:1 static compression, Ces 87mm cutring, Custom solid rear subframe bushings, Akg 85d diff bushings, 4 clutch 3.15 diff, 14mm diff bolt conversion, Poly engine mounts, UUC trans W/ enforcers, Custom Ms41 id1700 E85 tune..... BUILD THREAD
    Vancouver, B.C., Canada
    '97 M3
    Read this, I spent a lot of time and money testing.
    http://www.bimmerforums.com/forum/sh...aust-Q-amp-A-s
    '97 M3, Estoril blue, 2 dr, euro 6-spd, GTX3582R T4 .82, RK tuning, CP 8.5:1 pistons, Eagle rods, Schrick cams, L19 11 mm ARP studs, O-ringed block, Supertech stainless/inconel valves, Supertech springs & Ti retainers, ported head, S54 oil pump/pan, 80 lb. injectors, OBD1 intake manifold, Steedspeed T4, 3.5" SS exhaust, AMS-500 EBC, HFS-4 W/M injection, AEM Failsafe, Zeitronix data logger, Racelogic TC, OpenOBC, Ireland Eng. engine mounts, UUC black tranny mounts w. enforcers, UUC twin disc feramic, ARC-8's, MCS 2-ways, Z3 rack, Rallyroad strut bar, X brace, Eibach sway bars, Ground Control LCAB bushings, Bimmerworld RTAB's, Powerflex subframe bushings, CES 750iL diff conversion, Stoptech BBK, titainium shims, steel braided lines, brake cooling ducts.
    Jul 2002
    Long Island, NY
    98 Turbo M3, 04 E53 X5
    Im using 2 - Vibrant 3.5" mufflers with open 38mm gates. FF to 30secs
    04 Titanium Silver X5 - Family Whip
    '97 M3
    The OP is supercharged, a straight though 3.5" would make him deaf.
    Kirkland, WA
    1999 M3 Fern Green
    Maybe, but I highly doubt it. I love the look and sound of my Dinan cat back, plus I want to be as plug and play as possible with no fab work. AA headers and AA B section do that for me
    Los Angeles, CA
    #Project333Ti & Z3 Coupe
    3" is going to be loud unless you run 2 large mufflers. I've done it multiple times with various combos on NA applications. Vibrants are loud mufflers and so is the Borla XR-1. This was 2.5" single exhaust with ebay headers, a Borla Pro-XS mid muffler and a Vibrant street power out back. No drone, and mild below 3500 rpms, definitely loud at WOT. If you ran this combo with 3" it would definitely be louder.
    https://www.youtube.com/watch?v=nS2RJCk_itY
    https://www.youtube.com/watch?v=r2H5YreLZqk
    On my s52 Ti, I run Racleand headers, to single 3" with a Vibrant Ultra Quiet resonator AND a Vibrant 12" resolator after that, to a Borla Pro-XS rear muffler. It's about as loud as my 2.5" exhaust was on my e30 with a deeper sound because of the headers and Borla out back.
    Apr 2013
    Alabama
    1995 M3 Coupe
    This the semi-current sound out of mine, its a little deeper now with the RMS headers
    https://youtu.be/L7-GFGTWYTg?t=1891
    1995 M3...Screwed
    BHAM, AL
    98.5 M3
    I'm still NA (for now), but my exhaust is similar: SS rep long tube headers into Y-pipe into 3" piping.
    I'm using a 3" Mangaflow race cat and two 3" Magnaflow oval-body straight-through race mufflers.
    No drone and nice tone (Magnaflow sometimes sounds like poo).
    I used to not have the center muffler for better ground clearance, but I added the center muffler (only 3.5" case height for better ground clearance), and the car got much quieter (esp when not full throttle) and much less raspy.
    If my car was currently running, you could come hear for yourself in person...
    98.5 M3
    Jun 2005
    Concord, NH
    08 E90M3; 99 E36M3 Turbo
    Turbo chews up the noise. Supercharger is much louder. I went with RMS to modified euro SS mid to euro SS rear. If single 3.0, you will want at least 2, maybe 3 resonators/mufflers.
    '97 M3
    The AA track pipe offers to high of back pressure based on the back pressure measurements that I took on my superchargers s52 at 13 psi. It looks pretty and fits nice though.
    Lowcountry
    1995 s52 M3
    3.5" tubing with a spintech muffler. Slip fit connection at headers
    Apr 2008
    Douglasville
    3 BMW's a Benz & a Truck
    Following this closely. Want to go to a 3" header back exhaust for my setup as well. I want to retain my Remus muffler but I'll have to split back into dual before the muffler if I really want to keep it. So Ill be Longtube headers to 3" midsection straight back to the Remus muffler, pretty much identical to my setup now except I have a dual 2.25" setup that feels restrictive. Hardest part is finding an exhaust shop in the Metro-Atlanta area that will touch an exhaust without a catalytic converter.
    -Fully Rebuilt M52-Ported & Polished Head-3 Angle Valve Job-S52 Cams-540 MAF-24lb Injectors-BBTB-Longtube Headers-TRM Tune-ZF 5 Speed Swap-M50 Manifold-AFE Stage II 3.5" CAI-Remus Exhaust-Rokkor Coilovers-Polyurethane Bushings-ZHP Shift Knob-Sport Seats-M-Technic Body-EBC Cross Drilled & Slotted Rotors-EBC Red Stuff Pads-Euro Foglights-DJ Auto-Clear Lights-M Tech Side Moldings-VDO Gauge Pod-BBS RC-M Tech 1 Steering Wheel-BSW D210-Motion Motorsport Under Panel
    Cars: 2005 BMW 545i-2004 BMW X5 4.4i-2004 BMW 645ci-1999 BMW 528i-1995 BMW 325is-1994 BMW 840i-1989 Mercedes-Benz 560SL-2001 Dodge Ram 2500 Turbo Diesel
    Tim @ BMW of Dallas
    98 Z3 2.8
    Mine's 3" all the way, no cat, Vibrant ultra quiet resonator in the middle, oval muffler out back and it doesn't drone. I believe it was made by Maximum PSI, and used to be attached to NY98M3's car.
    98 Z3 2.8 - GC, AKG, Apex. Turn car.
    97 Cosmos M3/4/5 - GT3582R, etc. Fast car.
    13 Smart Fortwo - DD/beater. Slow car.
    Mar 2012
    Lansdale, Pa
    6/98 BMW 540 6sp VF S/C
    Supercharged car here with headers, race cats, and 3". My car was loud. I tried various mufflers. All loud. I finally got it quieter by squeezing in a large Magnaflow 12589 in the back. Straight through muffler, but the large case really knocks down the sound level. Size of the case is the key to reduce sound.
    6/98 540i 6sp, Mods: VF S/C, Custom Pulleys, 16 psi Boost, Tuning Tech FS Tune, 42# Injectors, Supersprint Headers, HJS Cats, 3" Custom Exhaust, D.O. Progressive Meth, AEM 320 Fuel Pump, Aeromotive FPR, AEM Failsafe AFR/Boost Gauge, Wavetrac LSD, Style 65 w/275's square, M5 bits;[Steering Box, Clutch, Motor Mounts, Front Sway Bar], Powerflex, Eibach Rear Bar, M3 Shifter, Evans Coolant, 85 Deg Stat, Clutch fan replaced with PWM fan, 10" DVC rear subs, B.A. speakers, Grom Aux and BT, Euro Console, Brushed Ti Trim. DIY everything!
  1. who makes the best exhausts that sounds good?
    By M3Owner in forum 1991 - 1999 (E36)
    Last Post: 10-06-2001, 05:17 PM
  2. Finally got an M3 exhaust...that thing looks like a boa that just ate a freakin' pig!
    By manny328i in forum General BMW sponsored by Intercity Lines
    Last Post: 08-31-2001, 10:14 PM
  3. Replies: 3
    Last Post: 08-30-2001, 05:22 PM
