Results 1 to 10 of 10
Thread: BMW E92 New DME Failed Programming & Coding need help
    florida
    2007 x5
    Any member have this issue.
    i buy a new DME from BMW Dealership for e92, then try to program with ISTA-P 3.56.3 it failed programming & encoding.
    Does anyone have any solution to this?
    [attachment=42667]
    Jul 2004
    Houston, TX
    36 Cylinders
    What interface are you using?
    There are too many factors that ISTA P could fail... and it's one of the reasons why I dislike ISTA P in the first place.
    If you have a working WinKFP with new daten, you would just need a flash of the DME, coding and then DME-CAS align and you're set.
    You changed the DME for misfire reasons?
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Dec 2012
    North Carolina
    2009 335i M-Sport Coupe
    Based on those rock steady KL15 and KL30 values, I'm guessing either an emulator is at play, or a voltage simulator was used in place of a power supply. To use ISTA-P, you really need to be using an ICOM and a strong power supply.
    Jul 2004
    Houston, TX
    36 Cylinders
    Good catch!
    -Abel
    Canada
    750 F01, 850i, LR3 HSE
    Quote Originally Posted by RocketSurgeon View Post
    Yup, This!!
    Philadelphia, PA
    2005 M3 & 2004 330i
    I'm assuming you're using a D-CAN cable. There's a bug with the stock firmware on those that causes faulty data to be written to the MSS6x DMEs when flashing ('06' is written every 253 bytes instead of the correct data). That naturally causes the signature check to fail.
    Either flash using an ICOM interface or update the ATMega chip on your cable with the firmware from the Ediabaslib project. Use the instructions under step 2 here: https://ediabaslib.codeplex.com/wiki...ringTitle=Home (ignore all the bluetooth stuff).
    Jul 2004
    Houston, TX
    36 Cylinders
    Yep, probably why I bricked an 08 M5 SMG module 2 years ago trying to flash with K+DCAN.
    I've upgraded since. Omitec, ICOM, etc.
    -Abel
    Philadelphia, PA
    2005 M3 & 2004 330i
    Yeah there are definitely some modules for which the K+DCAN interface factory firmware is bugged. In addition to the MSS6x and GDSMG3 modules, I know the GWS modules also failed. I was about to buy an ICOM, but I decided to give the other firmware a try, and so far it's worked great with everything I've thrown at it.
    Jul 2004
    Houston, TX
    36 Cylinders
    Ah, so it's more of a firmware issue..
    I had assumed it was a lack of buffer memory to maintain speed... or along those lines. My Omitec cable has a 29F400BB chip inside, which I assumed was there to help. But I'm not experienced enough to know. Useless now to try to convert my K+DCANs.
    -Abel
    528, E53 4.4, E92, F86
    So, Yah, what did you end up doing? Could you please update us? ...Thanks!
  1. Transmission Program + Error Code NEED HELP
    By TJ21 in forum 1988 - 1996 (E34)
    Last Post: 09-21-2023, 04:37 AM
  2. Engine Fail Safe. Got Codes. Need Help?
    By srq in forum 1995 - 2001 (E38)
    Last Post: 02-07-2016, 08:38 AM
  3. 98 328i engine codes need help. New to the bmw world.
    By stanced328i in forum 1995 - 2001 (E38)
    Last Post: 10-02-2014, 12:16 AM
  4. BMW E92 new alloy wheels
    By M17ESH in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 04-02-2013, 01:28 PM
  5. Trans Program Fault Codes - Need Help
    By moohampshire in forum 1995 - 2001 (E38)
    Last Post: 06-11-2007, 10:52 AM
