Results 1 to 15 of 15
Thread: NCS Expert Error
    Feb 2017
    Romania
    BMW 120d, 2006, 163Hp
    NCS Expert Error
    Hello guys! I've bought an interface K+DCAN compatible INPA. I've installed all program exactly like tutorial received with interface, program from CD received with interface also. In INPA both dots Power and Ignition are working properly. I can make only diagnose in INPA on engine on dde. If for example i'm trying to read airbag module i'm getting error. In NCS Expert also getting error. I've tryed to acces EWS and it gives me error.
    The file OBD.ini i think is fine, com port set to 1 like device manager, latency 1, hardware = obd / i've tryed to set the hardware on usb but i can't event diagnose then/
    With d-can.exe tool i've setet to K CAN for a 3 series, 2003/03. I've tryed also with D CAN, same s**t.
    The programs are installed on a virtual machine that operate windows xp on 32 bits.
    The LED on the interface is working properly also.
    What can i do?
    Errors:
    VIN is faulty
    COAPI
    -2000: EDIABAS or SGBD error
    IFH
    -0003: DATATRANSMISSION TO INTERFACE DISTURBED
    I've read somewhere that pin 7 and 8 need to be soldered to could coding. Did this, same s**t.
    NCS Expert V3.1.0
    INPA V5.0.2
    EDIABAS V6.4.7
    Path in Enviroment variables added.
    Jul 2004
    Houston, TX
    36 Cylinders
    This is on your E46?
    Yes, the K+DCAN cable's pins 7&8 have to be bridged together for e46 (dual K line).
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Feb 2017
    Romania
    Yes. E46, 2003/03, facelift
    Jul 2004
    Houston, TX
    36 Cylinders
    Do you have any control over the K+DCAN's latency on main computer and virtual machine? Best results are at 1ms or 2ms.
    -Abel
    Feb 2017
    Romania
    I don't know what you mean by control. If you are asking if i set the latency to 1, the yes i setted it.
    Jul 2004
    Houston, TX
    36 Cylinders
    I meant that the WinXP drivers didn't always have the option to change latency on the cable. So it depends on drivers and the windows.
    -Abel
    Dec 2012
    North Carolina
    2009 335i M-Sport Coupe
    When I used virtual machines, I would sometimes run into this when I forgot to port the cable through to the virtual machine, or forgot to turn on the key. I no longer use virtual machines for this reason. I have native installation files if you want them. I only run native at this point.
    Feb 2017
    Romania
    You say that i should run the programs on my host windows which is 8.1 ?
    Jul 2004
    Houston, TX
    36 Cylinders
    Yes the pack I sent you works even on Win10.
    -Abel
    Feb 2017
    Bulgaria
    2004 320D e46
    I don't mean to be rude or obtrusive, but can you by any chance share the same package with me? I can't seem to find anything to work with win 10.
    Thank you in advance!
    Feb 2017
    Romania
    I resolved it. You can close the topic. Thank you 328 Power 04.
    MauiM3Mania's Avatar
    MauiM3Mania is online now Observer/Master Skeptic Moderator
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Someone may want to add to this or have questions, so we will leave the thread open.
    88M3 AW 43k miles Project FS
    Jul 2017
    houston
    528i
    hello my Inpa works fine but when i try to use the ncs expert when i get to final step i get an error saying "vin Faulty" please someone tell me what i can do, i have downloaded the latest inpa version and i have windows 8.1. please someone help, please email me, raggg12@gmail.com
    Jul 2017
    London, United Kingdom
    2004 BMW 330ci
    hi i recently bought the K+DCAN Cable and it came with an inpa and ediabas ncsexpert installer. once installed the inpa doesnt seem to be working properly and ncs expert throws up the same VIN faulty error. Also, if I try coding; the FG and GM dont come up and i get a bunch of german wiriting showing an error. can anyone help me?
    Mar 2020
    Sessa Cilento, Italy
    Mini one D
    Red face lik for 10
    could you please send me the same you sent to that guy? that works on win 10
    email ; virgiliolettieri@hotmail.it
  1. NCS Expert error: "Error in CABD!"
    By delithdra in forum Diagnostic Software
    Last Post: 12-25-2012, 05:16 PM
  2. NCS Expert ERROR
    By daki77 in forum Diagnostic Software
    Last Post: 12-07-2011, 03:49 PM
  3. NCS Expert error with E46/E39... but E60 works fine
    By dazultra0 in forum Diagnostic Software
    Last Post: 03-09-2011, 11:34 PM
  4. NCS Expert error: "SYS-0008: JOB NOT FOUND"
    By fishbert in forum Diagnostic Software
    Last Post: 01-16-2011, 04:31 PM
  5. NCS Expert Error reading CAPPL
    By Gene Poole in forum Diagnostic Software
    Last Post: 11-15-2010, 08:18 AM
