BIG BORE 84mm Throttle Body Upgrade Kit BMW m62tu e39 540i e38 740i 1999-2003
1999-2003 M62TU Big Bore 84mm Throttle Body kit for e39 540i's & e38 740i's:
Upgrading to a larger diameter throttle body is a great way to increase power and throttle response. This kit is 100% plug & play and brand new. This is a better alternative to the Dinan TB which is very overpriced. Stock TB diameter is 79.5mm, the Dinan TB is 82.5mm diameter, and this kit uses a 84mm throttle body which is an advantage over Dinan.
This kit features:
1 x NEW 84mm big bore throttle body
1 x custom 100% plug & play wire harness adapter to connect the throttle body to OEM Engine harness.
Please note that this will ONLY fit m62tu VANOS cars.
?Approximate build time is 1-2 weeks after your purchase.
List Date: 2/16/2017
For more info, click here to view the original listing: BIG BORE 84mm Throttle Body Upgrade Kit BMW m62tu e39 540i e38 740i 1999-2003
This item is no longer available.
Trying to find the pinouts so this conversion works for me. I brought a pigtail connector from BMW that fits the N62TU throttle body, but any wiring diagram I find for conversion does not work. INPA shows that the throttle body is wide open, which it isnt and it wont click or initialize.
