Roll-center bump steer angle kit BMW E36 M3
Our latest product finally available!
Roll-center / bump steer / angle kit for E36 M3 3.2 cast control arms (no control arm or tie rod included).
This kit utilizes same accessories as our high-end tubular control arm kits so if you want to upgrade later, you don't need to buy a complete kit!
The kit offers 30mm roll-center and bump steer correction, corrected camber curve and 15% quicker steering ratio, +12degree lock to lock gain can be achieved using this kit.
It's a perfect choice for a daily, autocross or a trackday car and tolerates some drifting action too!
-Only fits control arms with a 41mm diameter outer end hole (no rubber bushing)
-Needs to be pressed in, nut is for locking
-Does not fit other E36 models
-Compatible with orginal or aftermarket tie-rods
-Steering reducers might be needed
-Minimum wheel size 16" with orginal tie rods (highly depends of the wheel design)
-Spherical bearing is replaceable
List Date: 2/14/2017
For more info, click here to view the original listing: Roll-center bump steer angle kit BMW E36 M3
This item is no longer available.
