2001 Z3 Coupe.
Right front daytime running light not working. Checked bulb and replaced. i dont see any obvious wiring issue. Ground wire shows connectivity. When runnging lights are on meter only shows 1 volt getting to light. I am clueless. Does this sound like a bad DRL relay?
I found the problem after considering another problem, ambient temp sensor not working. Recently had bumper replaced and body shop guys reversed the plugs. Thanks BMW for making all of your plugs exactly the same... Silly error and pretty rookie...
Translate a similar problem. She helped to change the temperature sensor
