I have two sets of 17x9 MT1-Rs. Both are exactly the same. Pretty sure they are 40et. These are the ones that are pretty much meant for E36s (but will work just as well with E46s - I run a set on my 330 without any issues). I use a 12mm spacer up front on my E36 for perfect fitment. With the right camber and setup, they'll run 255s without any issues. One set has 245 Conti DWs on them with 25% life left.
Looking for $550 obo for the empty ones
Looking for $750 obo for the ones with DWs on them
I also have a set of SSR Type Cs. Two of them have a small dent on the edge which is easily repairable, but won't prevent tires from being mounted (nothing that would cause air leaks) These are 45et (iirc). Rears may require a 1-2mm spacer if you're running 255s, but 245s and less should be able to be run with no issues.
Looking for $700 obo
I also have a set of Moton Motorsport DA rear shocks. Message or email me (randallprince at gmail) if you're interested in them. Fronts are TBD.
Reason for selling: I run staggered setup and looking for matching rims front and back. I actively autocross with the above rims and there is normal wear and tear for rims used on track and the street.
WUTCONE?
Anyone? Make some offers?
WUTCONE?
