Im looking for a new complete clutch setup for my m50.
The one I currently have ( single plate) slipped on the dyno at 900wnm.
So that leaves no room for clutch kicking.
Any recommandations for a clutch?
https://www.gucci.com/ca/en/ca/women...FdG4wAod2TgE4w
Use the search function on this forum next time.
I'm running this cause I'm a cheapass.
http://www.ebay.com/itm/FX-STAGE-4-S...dVUUn5&vxp=mtr
works well enough to satisfy my taste/needs.
instagram @andyitslit
Doesn't say what clutch he has, but asks for a better one. Inb4 promotor tells op to add more info before asking question.
Add more info before asking question!
If you read the first post it says the clutch slipped at 900wnm or 1020nm engine torque.
So I will need something that will leave a little headroom for clutchkicks.( Without breaking driveshafts on a regular)
Current clutch is a 240mm 4 puck kep disc, with a sachs 765 pressure plate. M30 lightened flywheel.
I know I can get a 4 plate os giken that will hold up, but it will also kill the drivetrain.
So looking for someone with personal experience with multi plate clutches and drifting.
Guys you could buy so many ebay bmw clutches for the price of 1 gucci clutch. Clutchception
IG: allen_union
I use a Southbend stage 4 extreme / stage "5" used to be what they were called. It is a 6 puck, unsprung single disc. Supposedly rated to 750 + ft-lb. I have 600 ft-lb now and no problems with clutch kicks or any clutch slipping.
I can source you one if you like. Shoot me a PM.
Mike
IG: @mikevanshellenbeck
