Page 9 of 34 FirstFirst 12345678910111213141516171819 ... LastLast
Results 201 to 225 of 832
Thread: Chikinhed's Mini Build
  1. #201
    May 2003
    Irvine
    95 M3, 03 E55, 07 335I
    No thas his waste dump
    Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
    New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
  2. #202
    Vancouver, B.C., Canada
    '97 M3
    Quote Originally Posted by Matutino View Post
    Correct, only in the WG recirc pipe. I've never had an issue with the down pipe cracking but I've had issues with the WG pipe cracking with the Steed 1.0.
  3. #203
    A house
    '86 325e, '14 VW EPA
    Quote Originally Posted by chikinhed View Post
    I wasn't concerned about the pressure capability of the aluminum since we are dealing with relatively low pressures (rated to 250 psi) but it was super soft, probably 1100 or 3003 aluminum. Very easy to work with but not acceptable due to how fragile it is and the e85 issue. Stainless hard lines are definitely the way to go, good for over 3000 psi.
    Where did you see the rating of your tubing? I got mine off summit and it's rated for like 50psi. Not that it will immediately burst at 51 but...
  4. #204
    Manchester, N.H.
    96 332IS 6466 turbo
    You guys ever think about doing nylon lines ? I have a kit that can press in GM/Ford quick disconnect fittings. I was thinking about running 3/8 nylon the whole way. Can even do nylon to rubber.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  5. #205
    '97 M3
    Not that I plan on doing it but the thought of sliding sideways across FIA curbing at the track with nylon fuel lines under the car would scare me. I'm surprised the damage on the aluminum lines didn't lead to a rupture.
  6. #206
    '97 M3
    Tonight I made up three stainless steel 1/4" lines, two for the WG's and one for the EFR recirc valve.
  7. #207
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Do you run hardlines all the way for your wg? I run 1/4" hardline as well but I have a few inches of soft line at one end to allow for movement.
  8. #208
    Manchester, N.H.
    96 332IS 6466 turbo
    Am I the only one that runs SS 4AN lines to and from WG ?
    1996 332IS
    Built 3.2
  9. #209
    A house
    I will be in this iteration. Teflon braided though not rubber.
  10. #210
    Feb 2012
    1995 BMW M3
    I thought about running braided ptfe 4an lines but figured hardline would be more reliable, especially in close proximity to the manifold.
  11. #211
    '97 M3
    My plan was to use the SS hard lines with short silicon vacuum hose at each end. Teflon hose would be nice but I can do a much tighter bend radius withe the 1/4" SS rigid line and I really don't like external SS braided hose as it acts like a hacksaw to anything it comes in contact with.
  12. #212
    Apr 2006
    Minnesota eh?
    86 325es
    I used to have 1/4" brake like but I got tired of fighting with it every time I took it on and off so now I just use 1/4 fuel hose with banjo fittings for easy on and off. My wastegate is in a pretty cool location compared to some though
  13. #213
    A house
    Quote Originally Posted by rajicase View Post
    I don't know if they'd be more reliable, the flexible teflon hose would probably survive vibrations better but my only legitimate excuse for wanting the teflon lines over hard is that I like making them
  14. #214
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by TheJuggernaut View Post
    I run a few inches of soft line at the end of my hard line in the engine bay to allow for movement.
    I think either eay is going to be reliable if done right.
  15. #215
    '97 M3
    I'm totally not concerned about the durability of the stainless hard lines, I'm more concerned about the silicon vacuum hose. Has anyone had any issues with it? I usually just use rubber but the IWG actuator isn't very far away from the Steed.
    I was able to tuck away the SS hard lines so that you would have to hunt for them to find them and not have them blocking access to anything. Two of them go from where the engine mount arm bolts onto the engine, along the sub-frame, up the side of the frame rail to the WG on the Steed. The other goes from the EFR recirc valve, behind the sub-frame to the other side of the engine and up to a Tee for the Tial BOV. I've used Adel rubber cushion clamps to secure the lines
  16. #216
    '97 M3
    Tonight I pulled the under tray off of the front of the car and removed the old hot pipe. I'll be making a new 3" aluminum hot pipe and by the looks of it I can fit a 4" turbo inlet pipe with AC still installed. The fit was close so I tapped in three smooth dents for the extra clearance.....
  17. #217
    '97 M3
    I tonight I finished up the 4" turbo intake pipe. I found a larger filter (K&N RF-1032) than the one I had. It is as big as would fit in that location. I also installed a heat wrap sock on the pipe to keep the heat of the exhaust manifold away from it......
    Next will be the 3" hot pipe.
  18. #218
    Apr 2006
    Minnesota eh?
    86 325es
    Looking good!
  19. #219
    '97 M3
    When I was looking for a filter, the parts told me that the inverted cone filters are not good for forced induction based on what the Vibrant catalog states. What's up with that, I've used one for probably 6 years now without issue.
  20. #220
    Joliet, IL
    Out of Service
    Wanna make a second intake pipe and 3 inch hot pipe for me?
    Sent from my SM-G935V using Tapatalk
  21. #221
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Make 2 more of each.
  22. #222
    '97 M3
    I believe you would also need the modified AC lines as well
  23. #223
    Joliet, IL
    Out of Service
  24. #224
    Oct 2016
    Oklahkma City, OK
    1993 BMW 325is
    Here is the intended mod and maintenance list:
    Steedspeed TS manifold
    BW EFR 9180 0.92 IWG
    Turbosmart Hypergate WG 14 psi
    Turbosmart IWG actuator 14 psi
    New down pipe and WG pipe
    New x-brace without scav pump mount
    New UUC feramic twin disc clutch
    Stock, shortened, strengthened driveshaft
    New diff output seals, cover gasket and diff oil change
    Aluminum rear upper control arms
    Rear subframe and mounting point inspection
    New rear shock lower bearings
    And a bunch of not so exciting stuff.
    I hooked up the ethanol sensor right to the openOBC last night but I think I have a faulty sensor, I have a new one on order.
    How did you do this?
    Sent from my SM-N920P using Tapatalk
  25. #225
    '97 M3
    Quote Originally Posted by Wes1311 View Post
    How did you do this? Sent from my SM-N920P using Tapatalk
    What part don't you get?
    If you are talking about the OBC with ethanol sensor then you need to go here...
    https://www.bimmerforums.com/forum/s...irmware/page67
    And here.....
    http://openlabs.co/projects/openOBC
  1. My mini build thread for the 98iL
    By dburt86 in forum 1995 - 2001 (E38)
    Last Post: 05-04-2014, 01:30 AM
  2. Glove Box Power Ports Mini Build Thread
    By DrJomamachubby in forum 1988 - 1996 (E34)
    Last Post: 10-04-2011, 05:53 PM
  3. Almost there... Mini Build
    By onasled in forum Track Car Builds
    Last Post: 12-29-2010, 10:15 AM
  4. BMW/Mini builds great cars...in a crash
    By Fripp64 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-15-2010, 05:02 PM
  5. Mini build
    By rbodor3 in forum MINI (Cooper & Cooper S)
    Last Post: 07-17-2009, 03:40 PM
