Page 8 of 34 FirstFirst 12345678910111213141516171833 ... LastLast
Results 176 to 200 of 826
Thread: Chikinhed's Mini Build
  1. #176
    Jul 2005
    PEI, Canada
    2001 330i
    Does that mean you're going to register your car as an aircraft?
    :P
  2. #177
    Vancouver, BC Ca
    1993 325is
    Quote Originally Posted by chikinhed View Post
    Jaker, with the anorexic NA e36, had mention that the e46 upper rear control arms are lighter.
    Next on the list is E30M3 aluminum front LCAs. They're about 3.5-4 lbs lighter per side.
    And then we need to get a group buy together to have an acquaintance in the Portland area make us some billet aluminum front knuckles:
    Evo stuff of his design/build:
    https://www.facebook.com/photo.php?f...type=3&theater
  3. #178
    Vancouver, B.C., Canada
    '97 M3
    Don't RX7's use aluminum front hubs?
  4. #179
    Vancouver, BC Ca
    1993 325is
    don't rx7's use aluminum front hubs?
    idk?
  5. #180
    Jul 2006
    burnaby b.c
    1998 328is 1999 540iT
    Nope, FD's had cast fronts but the rear hub was aluminum, from what i remember when i did suspension and brakes on my brother in-laws .
    95 318is - m52 powered, 97 328is - M-package, ​01 540iT/6speed
  6. #181
    '97 M3
    Quote Originally Posted by karies View Post
    '86-'91 RX7 front hubs were aluminum.
  7. #182
    '97 M3
    I finally pulled the tranny, swapped in a new twin disc, changed the heater hose at the back of the head and popped the transmission back in. I was going to install the modified stock drive shaft back in but with the expected extra power I thought maybe the DSS should stay. I installed the heat shields and rear exhaust before calling it a night.
    I really don't enjoy pulling the transmission in and out, laying on my back with the car on jack stands, especially that 6-speed but it's done.
  8. #183
    Geigertown, PA
    95 M blk/blk
    Do you have any pics of your oil drain setup?
    96 328i ITR Racecar
    95 M3 blk/blk - hillclimb project - http://forums.bimmerforums.com/forum....php?t=1798796 - Retired to street duty after two awesome seasons!
    2002 325XiT - daily
  9. #184
    '97 M3
    I'm actually going to leave the scavenge pump in for now. It would be nice to run without it but I want to make sure everything else is functioning first.
  10. #185
    Mar 2008
    Canton, Ohio
    02 525it, 97 M3, 08 X5
    I can't believe you don't have a lift. Much respect, you are way more motivated than me. Not sure what your garage is like, but I have been eyeing a maxjax pretty hard recently.
  11. #186
    '97 M3
    Single car garage, no lift. I've looked into the Maxjax and I can only go up about 28" before the garage door opener hits the roof of the car so it's not worth it. At least the garage is brick so that I can grind and hammer and crank the tunes and it doesn't bother the neibours.
  12. #187
    Mar 2001
    Oregon
    95 s/cM3,93 332is turbo,96 chevy dually, 73 camaro
    You should look into the quickjack. I recently got one but have yet to use it
  13. #188
    Manchester, N.H.
    96 332IS 6466 turbo
    Get rid of the door opener and go with the maxjax. Or punch a hole in your kitchen floor, rope it off with those velvet links like you see at the movie theaters and get a big boy lift.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  14. #189
    Vancouver, BC Ca
    1993 325is
    He'd have to build a kitchen above his garage to be able to do that!
  15. #190
    Jul 2002
    Long Island, NY
    98 Turbo M3, 04 E53 X5
    Brad, whats the max ceiling height you have in the garage?
    I cant put the car all the way up and open the door. I can get the wheels up about 4 ft with the door open, after that the door needs to be shut.
    98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
    2017 Toyota Tundra Crewmaxx - Family Whip
    2011 Pierce 75' Quint - Fire Apparatus West Islip FD
  16. #191
    A house
    '86 325e, '14 VW EPA
    Mine before I put the lift in. I want to do the other door just because I love the opener so much, it's silent compared to the horrible chain drive ones. But it's too expensive to justify two.
  17. #192
    Jul 2002
    Long Island, NY
    Quote Originally Posted by TheJuggernaut View Post
    Torsion spring is where its at. I have the similar set up but for a 16 ft door.
  18. #193
    '97 M3
    I think my garage ceiling stringers are only about 7 ft high. Not much room for lifts or high garage doors.
  19. #194
    '97 M3
    Some progress happened last night. 9180 is installed on the manifold, oil feed and coolant lines are connected, WG installed, exhaust is installed. Many more things to do before its done though....
  20. #195
    '97 M3
    Turbo oil drain now hooked up. I'm leaving the scavenge pump in for now. It's actually less work for me to leave it in at this point.
    Next on my list was the fuel system. I had aluminum hard lines from the tank to the fuel filter cover and both of them sustained damage from who knows what so I pulled them out and made stainless hard lines. I also swapped in a new ethanol sensor and fuel filter.
  21. #196
    Joliet, IL
    Out of Service
    Umm. Want to bend another set of lines for me? I gots some monies I can send your way
    Sent from my SM-G935V using Tapatalk
  22. #197
    '97 M3
    Quote Originally Posted by cragg56 View Post
    Umm. Want to bend another set of lines for me? I gots some monies I can send your way Sent from my SM-G935V using Tapatalk
    I could but it really depends on what other parts you have in your fuel system. It's best to fit the lines to the car they are being installed on. For example, here is a better shot of the lines installed on my car...
    Last night I also swapped in a new Walbro 485 fuel pump on the drivers side. The one that was in there was not e85 compatible. I also installed a new (used) sender hanger on the drivers side because the hose nipple had broken off when I was disassembling for fuel tank removal. And finally the back of the car, inside, is all back together....
    Here is a shot of the turbo and oil drain installed.
  23. #198
    A house
    Just a heads up to anyone else running these lines, I initially built my car with the aluminum hard lines but their durability bothered me later and I removed them. I later wanted to show a friend what I used and I couldn't even find them. Then I realized that they no longer appeared in the fuel injection line search results because of failures. They are not rated for EFI fuel pressures, they're meant for carbureted cars. Add to that that ethanol is corrosive to aluminum.
  24. #199
    '97 M3
    I wasn't concerned about the pressure capability of the aluminum since we are dealing with relatively low pressures (rated to 250 psi) but it was super soft, probably 1100 or 3003 aluminum. Very easy to work with but not acceptable due to how fragile it is and the e85 issue. Stainless hard lines are definitely the way to go, good for over 3000 psi.
  25. #200
    Jun 2005
    Concord, NH
    08 E90M3; 99 E36M3 Turbo
    Do you have a flex section in your DP?
  1. My mini build thread for the 98iL
    By dburt86 in forum 1995 - 2001 (E38)
    Last Post: 05-04-2014, 01:30 AM
  2. Glove Box Power Ports Mini Build Thread
    By DrJomamachubby in forum 1988 - 1996 (E34)
    Last Post: 10-04-2011, 05:53 PM
  3. Almost there... Mini Build
    By onasled in forum Track Car Builds
    Last Post: 12-29-2010, 10:15 AM
  4. BMW/Mini builds great cars...in a crash
    By Fripp64 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-15-2010, 05:02 PM
  5. Mini build
    By rbodor3 in forum MINI (Cooper & Cooper S)
    Last Post: 07-17-2009, 03:40 PM
