1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
I've got random wheel hop sometimes too... would a linear spring help in the rear or does that not matter. Mine are progressive.
I've had hop for a long time now. I've changed out everything in the rear and still had hop. I'm hoping the welding in the back will help but I won't be surprised if I still have hop.
I'm not the one to give advice on the solution to eliminating hop until I have gotten rid of my hop.
1989 535i - sold
1999 M3 Tiag/Dove - sold
1989 535i - sold
Wheel hop is the result of an uncontrolled resonance that continues to have energy applied to it. There are cases where there might be 2 or 3 nodes caused by different elements that all line up, and they hide each other when trying to troubleshoot the cause. In our case the resonance could be the tire, half shafts, suspension pickup points, shock damping, or the chassis.
On my black car, I never had wheel hop issues. That covered a range of tires from a 16" drag slick, 18" RA1s, and 17" street tires. I took the exact same subframe and mounted in my silver car, and now I have wheel hop. The differences:
1.) - MCS 2 Way remote reservoir shocks (Silver Car) vs Moton Clubsport 2 way remote reservoir shocks (Black Car)
2.) - 400 Lb/in springs (Silver Car) vs 450 Lb/in Springs (Black Car)
3.) - DSS Halfshafts (Silver Car) vs Stock half shafts (Black Car)
4.) - Poly RTABs (Silver Car) vs Spherical RTABs (Black Car)
5.) - Stock E46 Chassis (Silver Car) vs 14 Point Caged E46 with subframe tie-ins (Black Car)
If I were to guess the main contributors, it would be the Poly RTABs, and the stiffness of the chassis.
My next step for me is to replace the Poly RTABs with spherical units.
I'll bet the whole floor of the car and all the mount points are deflecting like crazy. Cars aren't as stiff as people think.
It's feasible.
On the Black Car, I ran a tube at a 45 degree angle from the main hoop through the floor and tied it directly to the RTA pocket. The subframe was effectively bolted to the cage, so sheet metal flex wasn't a factor.
I'd hate to do all that to a street car....
Pre 'Mini Build' rear end components resulting in massive wheel hop:
PolyFlex black 95A poly subframe bushings shimmed for full contact
Bimmerworld spherical RTABs
Turner spherical lower control arms
Stock upper control arms with recent rubber inboard bushings
Spherical outer upper and lower control arms
Solid aluminum diff mounts
DSS 1,000,000 hp axles
3.15 210 4 clutch LSD
Reinforced rear subframe
MCS 2-way shocks
800 lb springs
Alignment set at 1/8" total toe in & 1.0° camber
17 x 9 wheel with Starspecs or NT-01's
And a crap ton of popped spot welds.
Are the rear shocks in a coil-over configuration?
I ran 700 and 750 in the rear on the black car, and it was a bit much on the street....but I also was running a UUC rear sway bar.
I am curious to see if this fixes your wheel hop. I think Dburt had a wheel-hoppy e36 until he fixed rusty/flimsy shock or spring mounts. I don't remember the details, but I think it was the previous shell of his twin turbo LS project, back when it was just nitrous. Maybe he can chime in.
My car wheel hopped with every combination of spring and tire and rust repair until i got a soft sidewall tire.
This car will have stock springs and an auto so im hoping its better.
It will also be on a soft tire most of the time
328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
9.20 at 150 on 22psi
I guess my memory fails me, I thought the rust repair fixed the wheel hop.
I got the rear subframe, diff and control arm back the car last night. That was not very fun.
I had to order rear sway bar end links because the ones that came with the Whiteline sway bar won't work with the e46 rear upper control arm. I bought the Turner ones. They are advertised to work with the e36 and e46 so I thought I couldn't go wrong. Of course they don't work, next comes fabricating mount brackets that will work....
That ate into a bunch of my time.
That was a lot of work and expense to put those e46 aluminum control arms in. Not a cost effective mod in the end but they are in.
Whats the benefit of the E46 aluminum control arms?
98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
2017 Toyota Tundra Crewmaxx - Family Whip
2011 Pierce 75' Quint - Fire Apparatus West Islip FD
1 lb weight savings per side?
The fact that you can brag you have aluminum control arms... Brad is into bling bling
Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
Brad is probably going to have the best all around e36 in the world.
1996 332IS
Built 3.2
The people around us influence our lives. Jaker, with the anorexic NA e36, had mention that the e46 upper rear control arms are lighter, so when a buddy was selling a set i bought them, thus going on my 'to do list'. I honesty didn't plan to spend 10-15 hrs to get them where they are but things got out of hand. Sand blasting, polishing, clear costing, bushing replacement with spherical bearing, making new sway bar brackets, researching and ordering the links and then driving across the border to pick them up. Ya, I think I may have saved a couple of pounds. LOL!
In the airplane world, if an owner builds 51% of the airplane it is considered an amateur built and the owner gets to assign their own serial number to the aircraft they built and assembled. When are our cars no longer e36's?
