Page 6 of 34 FirstFirst 1234567891011121314151631 ... LastLast
Results 126 to 150 of 832
Thread: Chikinhed's Mini Build
  1. #126
    Vancouver, BC Ca
    1993 325is
    None of the rear sway bar links/brackets I have will work so I'll probably have to buy or make some.
    Oh, shit! I totally forgot about this. Sorry, I should have warned you.
  2. #127
    Vancouver, B.C., Canada
    '97 M3
    Quote Originally Posted by jakermac View Post
    None of the rear sway bar links/brackets I have will work so I'll probably have to buy or make some. Oh, shit! I totally forgot about this. Sorry, I should have warned you.
    Ya, I saw your fix for that. No rear sway bar
  3. #128
    Jul 2002
    Long Island, NY
    98 Turbo M3, 04 E53 X5
    I need to start getting energy like you, Im ready for bed at 8pm lol
    98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
    2017 Toyota Tundra Crewmaxx - Family Whip
    2011 Pierce 75' Quint - Fire Apparatus West Islip FD
  4. #129
    Bellingham, WA
    e30
    Brad, have you tried adjusting your dampers to eliminate the wheel hop? Im sure the answer is yes, but that is a great way to help reduce the wheel hop.
    -Nick
    91 E30 M42 on VEMS
    Turbo Camshaft Thread
  5. #130
    '97 M3
    Quote Originally Posted by NY98M3 View Post
    I'm a mix of a lack of patients and a lot of perseverance and a prime example of sleep dep.
  6. #131
    '97 M3
    Quote Originally Posted by wazzu70 View Post
    I've hopped on soft and hard, front and rear. I've hopped on low and high tire pressures. I've hopped in the wet and the dry. I've hopped off the line and at 50 mph.
    I've come to the conclusion that my car is actually a bunny rabbit.
  7. #132
    Bellingham, WA
    e30
    Quote Originally Posted by chikinhed View Post
    I figured you had already tinkered with that and wore out the options there. Maybe at this point call the vet clinic and ask how to cure a hopping rabbit?
    Either that or turn down the torques a bit.
    -Nick
    91 E30 M42 on VEMS
  8. #133
    '97 M3
    I've tighten up the chassis by fixing the spot welds and removed the last rubber bit from the rear suspension. I have a bit of play in my axle CV's that I could deal with and I could put some drag radials on it, those are my last two options to fix the hop.
  9. #134
    Oct 2005
    Northern California
    95 M3, 15 Golf TDI wagon
    Why doesn't the rear sway bar work? 210mm diff?
    -WTB: OEM Class 2 LTW GT wing with risers- Mazak
  10. #135
    '97 M3
    Quote Originally Posted by 3literheater View Post
    The sway bar work with a 210. The e46 rear upper control arms use different links that don't work with aftermarket sway bars, therefor you need to buy or make new links. Jaker just doesn't use a rear sway bar because of how he set up his suspension.
  11. #136
    Vancouver, BC Ca
    1993 325is
    No rear bar permits moar powers to get to the pavement coming off corners.
  12. #137
    Mar 2012
    Renton, Wa
    98 m3
    Uninstalling now.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  13. #138
    Vancouver, BC Ca
    1993 325is
    You do need to up your rear spring rate though to compensate for some of the lost roll resistance and to maintain the front/rear balance.
  14. #139
    '97 M3
    See, you don't just yank your rear bar, you need to set it up for it! I got Jaker's hand-me-down springs after he did that.
  15. #140
    Mar 2012
    Renton, Wa
    98 m3
    I think im tck sa 350/450.. i can buy rear springs. What ratio are you running?
    1989 535i - sold
  16. #141
    '97 M3
    Quote Originally Posted by vollosso View Post
    I think im tck sa 350/450.. i can buy rear springs. What ratio are you running? Sent from my iPhone using Tapatalk
    I have 680F/800R. I know Jaker has higher rates than that.
  17. #142
    Los Angeles, CA
    #Project333Ti & Z3 Coupe
    Stock rear bar with proper rates is great. Going that high of rates out back on a high powered car will hurt traction, especially in the straight line. Remember Jake makes like 250wtq...
    On a turbo e36, I wouldn't go stiffer than 600 personally. Personally I've never liked no rear bar, I prefer a stock or smaller than stock rear bar, with properly matched spring rates, poly rear bushings, and properly valved shocks. I also really like running H&R race rear springs out back for high powered cars. The progressive rate springs allow you to understeer in a corner and throttle harder to make up for the softer rate. From a launch, or low speed roll the H&Rs do great!
  18. #143
    Joliet, IL
    Out of Service
    I ran 700F/850R with no rear sway bar and didn't note any I'll effects. I ended up putting the rear bar back in when I installed TMS bars and there was a difference but that may have been the larger bar up front too
    Sent from my SM-G935V using Tapatalk
  19. #144
    Los Angeles, CA
    Quote Originally Posted by cragg56 View Post
    No rear bar requires 800+ for the corners. From a launch or low speed roll, that would be too stiff for proper traction.
    If you go way stiffer out back only, it will throw off the balance of the car. With a heavier turbo set-up up front, I would go 550 at least up front.
  20. #145
    Apr 2006
    Minnesota eh?
    86 325es
    125lbs in the back with shortened struts and stock springs in the front for me, nice and comfy little different use than you guys I guess though
  21. #146
    Mar 2012
    Renton, Wa
    98 m3
    As a side note i really like my setup.. i got it right and liked it so much i never have felt the need to change.
    1989 535i - sold
  22. #147
    Los Angeles, CA
    You may enjoy it even more if you go 50 - 100# stiffer up front to compensate for the added front weight of the turbo set-up.
  23. #148
    '97 M3
    I use to have 550F/650R and with the weight of my car I wouldn't have wanted the springs any softer. Even launching with my current springs the car still squats.
  24. #149
    Manchester, N.H.
    96 332IS 6466 turbo
    Am I the only one that has no idea the spring rate I have ?
    Mine are lime green.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  25. #150
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Lime green is 800 lbs.
  1. My mini build thread for the 98iL
    By dburt86 in forum 1995 - 2001 (E38)
    Last Post: 05-04-2014, 01:30 AM
  2. Glove Box Power Ports Mini Build Thread
    By DrJomamachubby in forum 1988 - 1996 (E34)
    Last Post: 10-04-2011, 05:53 PM
  3. Almost there... Mini Build
    By onasled in forum Track Car Builds
    Last Post: 12-29-2010, 10:15 AM
  4. BMW/Mini builds great cars...in a crash
    By Fripp64 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-15-2010, 05:02 PM
  5. Mini build
    By rbodor3 in forum MINI (Cooper & Cooper S)
    Last Post: 07-17-2009, 03:40 PM
