Page 5 of 33 FirstFirst 12345678910111213141530 ... LastLast
Results 101 to 125 of 820
Thread: Chikinhed's Mini Build
  1. #101
    Vancouver, B.C., Canada
    '97 M3
    I did a final inspection of the back of the car and no more cracks/popped spot welds. Yay.
    I got all the welded areas cleaned and prepped and coated with epoxy primer tonight. I'll pick up the paint and a bunch of parts tomorrow then spray the color.
    I need to put parts back on this thing. I don't have anymore room for any more parts to come off!
  2. #102
    Aug 2012
    CT
    Twin turbo LS E36 M3
    Its crazy how much room a car will take up when its apart. It really puts in perspective how "dense" vehicles are.
    Good work on fixing the chassis.
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
  3. #103
    Jul 2002
    Long Island, NY
    98 Turbo M3, 04 E53 X5
    my 25x20 garage you cant even walk in with the amount of parts I have laying around lol, I need to start putting it back together lol
    98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
    2017 Toyota Tundra Crewmaxx - Family Whip
    2011 Pierce 75' Quint - Fire Apparatus West Islip FD
  4. #104
    Mar 2012
    Renton, Wa
    98 m3
    Solid job on the repair. I guess thats the airplane mechanic in ya?
    I bet you have a huge reduction in wheel hop.
    1989 535i - sold
    1999 Tiag/Dove M3 - sold
    1998 Turbo Arctic/black - current
    2004 TiAg/Black - Current
    PTE6870 | 1.15 ar | Hp Cover, Custom Divided T4 bottom-mount, 3.5" SS exhaust, Dual Turbosmart Compgates, Turbosmart Raceport BOV, 3.5" Treadstone Intercooler, 3.5" Vibrant resonator and muffler, Arp 2k Headstuds | Arp 2k Main studs | 87mm Je pistons | Eagle rods | 9.2:1 static compression, Ces 87mm cutring, Custom solid rear subframe bushings, Akg 85d diff bushings, 4 clutch 3.15 diff, , Poly engine mounts, UUC trans mounts W/ enforcers, 22RPD OBD2 Stock ECU id1700 E85 tune, 22RPD Big power Transmission swap w/ GS6-53
  5. #105
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Repair looks professional. Nice work. I'd be too lazy to worry about a color topcoat myself, but it will look factory. Be interesting to see if this impacts the wheel hop you were getting.
    98 540i 6, 525 whp, 120 mph 1/4, V3 Si S/C'er @16 psi, W/A I/C, Water/Meth, Supersprint, HJS, 3" Ex, UUC Twin Disc, Wavetrac LSD, AEM FP, Aeromotive FPR, AEM Failsafe AFR/Boost, 65's w/275's, M5 Box, Eibach, M3 Shifter, Evans, 85 Deg Stat, PWM Fan, 10" Subs, B.A. speakers, Grom Aux/BT, Still Rolling as my DD!
  6. #106
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by philly98540 View Post
    I hope he never solves his wheel hop. His car then will be perfect and make mine that much more of a pos. At least I don't get wheel hop ; ) .
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  7. #107
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by chikinhed View Post
    Ten spot welds over a two foot distance isn't enough IMHO.
    It could be worse. This is my sisters Monte Carlo. She spun out in the snow and slid backwards into a full size van at like 30 mph. I looked it over after my dad hauled it to his place and all the spot welds holding all the structure of the back of the car together were all like 5 inches apart and they all just pulled apart. Every structural seam in the back of the car just pealed apart like a zipper and went back to being flimsy sheet metal not attached to anything. The rear seat back was flush up against the back of the driver and passenger seat and the passenger seat was actually pushed forward off the rail. It was just the back of the truck, the firewall, and the rear seat back in about a 4 inch thick sandwich. The guy in the van that she hit was able to drive the van home lol. Don't buy a GM car.
  8. #108
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Either sis was under estimating here speed or that car is made of tin foil held together with elmers arts/crafts glue and old gum.
    Good thing no one was in the back seat..
    I have seen kias fair better in similar type accidents at higher speeds...
  9. #109
    Apr 2006
    Minnesota eh?
    86 325es
    She was on a 30 mph residential street so she was probably going 40 but would have scrubbed off some speed in the process of turning backwards. The van was also going probably 30-40 in the other direction. Either way the most telling thing to me is that the van was still drivable but it ate up that monte like a fat girl on a plate of cheese fries.
  10. #110
    Feb 2012
    1995 BMW M3
    Lol :d
  11. #111
    Vancouver, BC Ca
    1993 325is
    Was the van a GM product?
  12. #112
    '97 M3
    I'm working on a GM product..... an LS1, installed in an airplane...... "Man, this thing has all the power"..... until the alternator packs it in, then a few bad things are going to happen (and, not my bright idea).
    I picked up some parts today including these Turner bearings for the upper control arms.....
    And I repainted the under the back seat area so that I won't be reminded of this fiasco every time I pull my back seat out.
    Everything is primed, painted and under coated as required under the back of the car, so finally, parts can start going back on at the back of the car.
  13. #113
    Feb 2012
    1995 BMW M3
    Title should be: "Chikinhed's Major Overhaul"
    Looks really good man.
  14. #114
    Ship, Pa
    Red Sled, RC51
    You do good work.
    What are the upper arms from? E46?
    Sent from my SM-N920V using Tapatalk
    "Believe nothing you hear, half of what you read"
  15. #115
    Mar 2012
    Lansdale, Pa
    No cut corners on this "mini build". Looking good.
  16. #116
    St. Anthony, IN
    1992 3000GT VR4
    Nice work!
    1992 3000GT VR4. 4g63 Swap. DSM 2g Auto Trans. 10:1, E85, AEM, FP Super 99 turbo. Best ET 9.98...Best MPH 137.8
  17. #117
    '97 M3
    Thanks for the props! I think I totally jinxed myself by giving the thread that title.
  18. #118
    Oct 2005
    Northern California
    95 M3, 15 Golf TDI wagon
    Wow man this all looks great!
    I wonder if those bearings are going to cause more noise? Hopefully they will help with your wheel hop issue. They sure look nice too!
    -WTB: OEM Class 2 LTW GT wing with risers- Mazak
  19. #119
    Toronto, Canada
    E36 Turbo
    Fancy parts and awesome repair job! Well done
    E36 ∑ DYNO ∑ TUNING ∑ WIRING ∑ PARTS
  20. #120
    '97 M3
    Last night I got the fuel tank back in, the control arms mounted to the subframe and touched up a couple of spots with epoxy primer, paint and undercoating. The subframe is in position for the diff to be installed and the whole thing stuffed back in the car.
    None of the rear sway bar links/brackets I have will work so I'll probably have to buy or make some.
    The fuel tank vents were a pain in the ass to remove and install, not fun.
  21. #121
    Aug 2012
    CT
    yea those fuel tank vents single handedly almost made me switch to a fuel cell.
  22. #122
    Joliet, IL
    Out of Service
    Such a pain. If only there was a bit more slack to get them back on those damn nipples while the tank was lower
    Sent from my SM-G935V using Tapatalk
  23. #123
    easton pa
    e36 m3, turbo e36
    On one of my cars those nipples were flexing and bending. Drove me nuts!
    -sold...replaced by turbo e36
  24. #124
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    Progress looking really good! lol at mini build title though.
    PTE6262 .63 A/R, Stock S52, Cutring/Copper Spacer/Arp Studs Combo, Water Methanol Injected
    10.9@131mph. #AngerMotorsports
  25. #125
    Manchester, N.H.
    96 332IS 6466 turbo
    Thread should be "maken it betterz, and fixen what I brokez"
    1996 332IS
    Built 3.2
  1. My mini build thread for the 98iL
    By dburt86 in forum 1995 - 2001 (E38)
    Last Post: 05-04-2014, 01:30 AM
  2. Glove Box Power Ports Mini Build Thread
    By DrJomamachubby in forum 1988 - 1996 (E34)
    Last Post: 10-04-2011, 05:53 PM
  3. Almost there... Mini Build
    By onasled in forum Track Car Builds
    Last Post: 12-29-2010, 10:15 AM
  4. BMW/Mini builds great cars...in a crash
    By Fripp64 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-15-2010, 05:02 PM
  5. Mini build
    By rbodor3 in forum MINI (Cooper & Cooper S)
    Last Post: 07-17-2009, 03:40 PM
