Page 33 of 33 FirstFirst ... 82324252627282930313233
Results 801 to 820 of 820
Thread: Chikinhed's Mini Build
  1. #801
    NY
    skateboard
    Quote Originally Posted by awp235 View Post
    Looks lik eyou're in need of a BigDuckClub kit. Built for setups exactly like this, and survives damn near anything you throw at it.
    Ehhh I think what the OP is doing will look way cleaner.
    ďIf liberty means anything at all, it means the right to tell people what they do not want to hear.Ē
    ― George Orwell
  2. #802
    Apr 2017
    NJ, USA
    '07 335I 6MT, '01 330i
    Lots of truth there. I just read higher up to see that he's doing the body himself. Will be awesome.
    Keep it simple: half gutted '01 330i, welded diff, BC coils, SLR Super kit
  3. #803
    air, dirt, fire, water
    95M3 92525iT 78810 95525
    Hell yeah.
    Reasonable prices too.
    Track is Track.
    This is ain't no Cameron/Gordon car.
    Still interested in what body style OP will be mimicking/copying?
    There has to be a GOAL.
    Please show image of "prospective" result.
  4. #804
    NY
    skateboard
    Quote Originally Posted by milKt View Post
    Hell yeah.
    Track is Track.
    Look in the rides/style section for a blue e36 m3 (most likely from 4-5 years ago)
    ― George Orwell
  5. #805
    Sep 2017
    Netherlands
    e36 328i turbo
    Quote Originally Posted by GG///M3 View Post
    https://www.bimmer-mag.com/issues/13...les/blue-magic
    this one?
  6. #806
    Quote Originally Posted by chikinhed View Post
    The plan is to graft on larger fender arches, like the e46 330i front fenders,
    Reading back, my comprehension needs work.
    So you plan to mimic the E46 lines.
  7. #807
    NY
    skateboard
    Quote Originally Posted by et89 View Post
    Correct
    Nope it still looks like an e36
    ― George Orwell
  8. #808
    Feb 2017
    Stevens PA
    1998 M3, TT stg2
    Close but itís actually an F33C which is an aerobatic Bonanza. Apparently its the last aerobatic Bonanza built.
    I have to get new 18x10.5 wheels and I canít decide between the ARC-8ís or the SM-10ís. Let me know what you guys think.....
    I am biased on the dished ARC-8s personally. They just look so aggressive and fit the E36s style so well. I get compliments all the time on them. I just wish I could run the fronts without spacers and clear the Stoptechs. Had to roll all 4 corners and run some negative camber on all too. 18x9s ET30 on all 4 corners
    Here they are on mine
    Bill
  9. #809
    Vancouver, B.C., Canada
    '97 M3
    Iíd like the same lines/look as stock with larger arches to accommodate the tires. Think Hard Motorsport flares without the seams or screws. I would like to figure out how to reduce the exposed frontal area of the front and rear tires..
  10. #810
    Vancouver, BC Ca
    1993 325is
  11. #811
    NY
    skateboard
    It looks like you have the v2 flares.
    This is from the link posted earlier.
    ― George Orwell
  12. #812
    Nov 2016
    Long Island, NY
    A few
    I'm pretty sure the E36 in the photos that jakermac posted used E46 M flares. It's too much IMO. The Estoril one above is much more OEM looking.
  13. #813
    Sep 2017
    Netherlands
    e36 328i turbo
    Quote Originally Posted by R.Thomas View Post
    The estoril one uses E46 Non-M front fenders.
    I want to do the same to my rear fenders.
    like this great example:
    http://www.speedhunters.com/2017/12/...t-cohesive-m3/
    I am just to much of a pussy to do it myself, and too broke to pay someone for it, so that might take a long time.
    Very curious to see how the job on yours will end up Chikenhed!
  14. #814
    '97 M3
    The estoril M3 is local to me but Iíve never seen it other than in photos. I believe he is running 285ís but says he can fit 295ís. IMHO the front of the front arches doesnít look right, like they had to do something funky to get the front of the e46 arch to work. Iíve given the shop one e46 front fender to cut up and see if they can use it but the owner said that itís most likely that they will just make the arches instead as they will fit better. When you take an arch that is not meant to fit and you try to make it fit then you end up with thing looking not quite right like the estoril M3 or the Lang M3 above. That said, we donít know all the challenges ahead to fit the tires or the vision my body guy has from the info Iíve given him, which does include pictures of both cars and pointing out their flaws. One of the constraints I gave him was that the flare canít go into the gas door.
  15. #815
    Sep 2017
    Netherlands
    e36 328i turbo
    The estoril M3 is local to me but I’ve never seen it other than in photos. I believe he is running 285’s but says he can fit 295’s. IMHO the front of the front arches doesn’t look right, like they had to do something funky to get the front of the e46 arch to work. I’ve given the shop one e46 front fender to cut up and see if they can use it but the owner said that it’s most likely that they will just make the arches instead as they will fit better. When you take an arch that is not meant to fit and you try to make it fit then you end up with thing looking not quite right like the estoril M3 or the Lang M3 above. That said, we don’t know all the challenges ahead to fit the tires or the vision my body guy has from the info I’ve given him, which does include pictures of both cars and pointing out their flaws. One of the constraints I gave him was that the flare can’t go into the gas door.
    Sounds very good! The black one in the speedhunters article is for me the one that did the best job of the 3 cars mentioned here. It is below the gas door as well, which makes it look like it is stock.
    Doesnít look like he can fit 295¬ís though.
  16. #816
    NY
    skateboard
    Thatís because that human is a stance human.
    They like wide wheels with thin tires. A special kind of human
    ― George Orwell
  17. #817
    Sep 2017
    Netherlands
    e36 328i turbo
    Also known as a ďstancy nancyĒ, as the OP likes to call it.
    https://www.bimmerforums.com/forum/s...-upgrade/page2
    I laughed out loud when I first read that post.
    My first e36 was a bit stancy Nancy.
  18. #818
    Likely a Airport Bathroom Toe Tapper, w/ tapatalk
  19. #819
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Any details on the driveshaft?
  20. #820
    '97 M3
    Quote Originally Posted by rajicase View Post
    What kind of details would you like?
  1. My mini build thread for the 98iL
    By dburt86 in forum 1995 - 2001 (E38)
    Last Post: 05-04-2014, 02:30 AM
  2. Glove Box Power Ports Mini Build Thread
    By DrJomamachubby in forum 1988 - 1996 (E34)
    Last Post: 10-04-2011, 06:53 PM
  3. Almost there... Mini Build
    By onasled in forum Track Car Builds
    Last Post: 12-29-2010, 11:15 AM
  4. BMW/Mini builds great cars...in a crash
    By Fripp64 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-15-2010, 06:02 PM
  5. Mini build
    By rbodor3 in forum MINI (Cooper & Cooper S)
    Last Post: 07-17-2009, 04:40 PM
