If you leave it at 500 rwhp, the issues are fewer.
500 whp is not acceptable at this point unfortunately. I got to drive a GT3 Porsche a couple of weeks ago and the lack of acceleration, comparatively, was a let down. That’s a car I’ve looked up to for years now. The throttle pedal should be able to invoke fear.
Sorry for not reading through the entire thread but why the switch to 11mm studs in the first place? I see so many people doing bigger studs for 6-800whp and I just don't understand why? 10mm studs and a cut ring has done me and everyone else I know just fine at 700+. I seem to see bigger studs causing more problems than they fix.
The question is specific to using an aluminum block.
The most prevalent use of aluminum blocks with FI is with the M54 engine.
M54 engines have some bad history with over-heating; they anneal if you go over 230 degrees water temp, and the head bolts pull out. As a result, numerous companies have come up with re-thread kits for the M54 block. A few racers decided to go for 11mm had studs while they were at it. To be clear, the 11mm stud and re-threading of the block was to address an already weakened block, or the possibility of overheating and weakening.
FI people grabbed onto the idea of stronger thread engagement, and stronger head studs, without evidence of there being an issue with upgraded 10mm head studs. (With or without timecerts)
In this case Brad said he is running 11mm studs in his iron block M52. He did this in an attempt to get more clamping force.
Yes my o-ringed iron block did predate the cut ring. My 11 mm stud choose was a result of many BF FI peeps, including myself, wanting more clamp force in an attempt to reduce head gasket failures on the iron block. The 11 mm studs did a wonderful job but the torque that they were torqued to was probably too high for the threads in the block. I might add that the engine didn’t come apart because of the cracks in the block or because of a failed head gasket; it was the cracks in the head that were weeping coolant. Just enough to smoke more on start up. I was still boosting hard until I pulled the head.
The 10 mm ARP stud torque procedure has reduce torque to 75 lbft from the 85 lbft and the rotational torque method which was probably up around 100+ lbft if you were to measure it. My guess is that they were having the 10 mm studs stretch beyond the max limits at the higher torque rendering them not reusable. I plan to reuse the 11 mm studs again but at a reduced torque than last time, closer to 85 lbft than the 100 lbft I did last time.
I am considered going to the cut ring gasket instead of o-rings but I would prefer that the head gasket pop over cracking the head.
I finally pulled the engine last night. Life and work make progress on the car painfully slow. Now I have to figure out what parts I need. The bearings all looked good so the crank will just need a polish. I may or may not use the pistons again as I’ll need HD wrist pins and new rings.....
I’ve inspected and measured the important stuff. Pistons, rods and crank are all still good. I’m going to install beefier wrist pins for insurance. New rings, bearings, gaskets and other random bits are ordered, now all I need is a new block.
The new head is getting new guides, valve job and porting and the stainless/inconel valves, springs and Ti retainers out of the old cracked head.
Fwiw my new block is 1/2” 8740 chromoly arp’s.
(Stainless oring because I now have a fancy head I don’t want to loose.)
1/2” studs allow you to completely cut a full thread and there were a few other tricks to help with the block strength.
1/2” arp (not 2k) is ~60% more preload versus the standard 10mm arp2k.
Food for thought.
1989 535i - sold
1999 M3 Tiag/Dove - sold
Maybe bore comes into play? Is Vollosso using an 84.5mm bore or an 86.6 or 87mm bore?
Seams to be pretty hit or miss. I've seen cracked blocks with 11mm, 12mm, and 1/2". Others seam to not ever have issues. I have 11mm studs in mine and have never cracked a block but I also have the threads sunk about 1/4" deeper into the block. The nice thing about 11mm is you just chase out the existing threads and they fit through the head gasket, dowels, and head without modification.
The cracking is definitely more prevelant in 86+mm bores
Yeah, this motor is 84.5 although you have enough clearance with any bore. It’s all how you prep, bore and cut the threads.
We changed the counterbore and thread depth.
1989 535i - sold
I found the torque PDF that I used for torquing my 11 mm L19 studs and it says 105 lbft. That is probably too high for the strength of the block based on the results that we are getting. I will use the 11 mm studs again but am going to keep the torque down to 85 lbft this time. ARP has revised the ARP2000 10 mm stud torque, again, down to 75 lbft this time.
The engine is at the machine shop now getting cleaned, decked, bored, SS o-ringed, re-threaded for 11 mm head studs, oil pump chain tensioner dowels installed and S54 oil pump machined for high volume oil pump gears. I'm also putting in upgraded 0.200" wall thickness wrist pins 'just in case'. The head should be done soon I would suspect but my head guy knows that the block won't be done for a bit. The machine shop said five days but I know better than to believe them. If I get it back in the next three weeks I'll be amazed.
I had a little look in the ports of my Steed 2.0 and there is some cleaning up at the WG port that could happen to increase flow. It's too bad its not built for a 60 mm WG and its also too bad that it only dumps four of the six runners. I can spend some time in there and make it a little bit better.
I've booked the M3 to go into the body shop mid Feb for some mods and paint. The goal is to come out shiney, meatier and lighter.
....and those wheels....I love how those wheels don’t fill out the arches...... and how you can still see the stock arch under the rears.....ya, that’s the one.
I had to buy a minimum of 100 of those kits to get the deal though, I figured y’all would want one as well.
I’m going to supply the ‘body guy’ with an e46 fender and he will see if it’s going to work for what I want. He’s thinking that he may end up making the all the flares from scratch out of steel. I’d like to fit a 295 all around but have it look stock.
Interested to see how the E36 fenders come out...I need to do this on mine in the rear but I got a quote of $5K to do it. I aint paying that much.
98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
2017 Toyota Tundra Crewmaxx - Family Whip
2011 Pierce 75' Quint - Fire Apparatus West Islip FD
