Page 25 of 34 FirstFirst ... 1516171819202122232425262728293031323334 LastLast
Results 601 to 625 of 832
Thread: Chikinhed's Mini Build
  1. #601
    Bellingham, WA
    e30
    Quote Originally Posted by ba114 View Post
    M52b28tub is dual vanos isn't it?
    The Z3 is just plain old M52b28 except with an aluminium block like was standard for all of us aussies
    This is what I believe to be correct. The engine in the Z3 is not an M52tu. Those were in early E46 and E39, etc.
    Either way, I think the concern about the aluminum engines not being able to hold power is overblown. I have never seen any evidence it is not up to task!
    -Nick
    91 E30 M42 on VEMS
    Turbo Camshaft Thread
  2. #602
    A house
    '86 325e, '14 VW EPA
    Quote Originally Posted by PEI330Ci View Post
    The M54 guys have found that ARP makes a 12mm stud kit for the Barra engine that fits
    I use RB26 ARPs
  3. #603
    Vancouver, B.C., Canada
    '97 M3
    I have 11 mm ARP studs, would those not have enough thread area to not strip out the block?
  4. #604
    Jul 2005
    PEI, Canada
    2001 330i
    Quote Originally Posted by chikinhed View Post
    I think they would be fine.
  5. #605
    Apr 2006
    Minnesota eh?
    86 325es
    If you don’t torque the bejesus out of it it won’t stress the threads as much and you’ll still have more clamp load than 10’s. Like 80 or 90 ft lbs
  6. #606
    '97 M3
    I got the head off today. Holy f@ck what a tedious jigsaw puzzle that is with the Steed 2.0 and EFR 9180. The Steed 1.0 is the clear winner when it comes to pulling the head off.
    The head gasket does not show any signs of failure from the quick look I’ve had so far. The block is cracked from most of the stud holes to the adjacent coolant passages. That’s a bit of a kick in the junk but I was half expecting it.
  7. #607
    Mar 2008
    West Covina, CA
    97 M3/4/5, 98 M3/2/5
    Going to shell out for CA625+ ARP studs from VAC instead of 11mm again?
  8. #608
    '97 M3
    I have an old set of the 10 mm ARP 2000’s laying around that I could use if I don’t reuse the 11 mm L19 studs again.
    Something to note about the L19 studs. People have said that they are sensitive to corrosion but mine have been in there for 4+ years and still look like new.
  9. #609
    Apr 2006
    Minnesota eh?
    86 325es
    I think the issue with L19 is hydrogen embrittlement, not actual rusting. I don’t know much about it though. This is the 2nd case I’ve seen of a block cracking spontaneously when using 11mm L19’s. What were they torqued too?
  10. #610
    '97 M3
    I think they were torques to 95 lb ft but I’d have to go searching to find out for sure. I though MikeR went back to 10 mm ARP 2000’s because of the blocks cracking at the stud holes with bigger studs.
    Cracks.......
  11. #611
    Mar 2008
    West Covina, CA
    Might be interested in the L19 for my Euro S50B32 build before I just order new 2000 or L19.
    Sent from my SM-G935T using Tapatalk
  12. #612
    Vancouver, BC Ca
    1993 325is
    So is that last pic a crack in the head too?
  13. #613
    Jul 2002
    Long Island, NY
    98 Turbo M3, 04 E53 X5
    Mine cracked in the same spots using 11mm headstuds. This is the reason Im back at 10mm ARP2000s. When searching for a solution, I reached out the ARP to make the 625 custom age 10mm headstuds. Not running them yet, Ill wait til there is a problem.
    98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
    2017 Toyota Tundra Crewmaxx - Family Whip
    2011 Pierce 75' Quint - Fire Apparatus West Islip FD
  14. #614
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by NY98M3 View Post
    Were you using 2000's or L19's? What torque?
    It would be interesting if we could figure out a trend of why some crack and some don't. Me and Dmitry were just discussing this and I don't know how to make sense of it. He runs 12mm's, I run 11's. Lots of people used to run 1/2". A bunch of other people run 11's. Some crack and some don't and it doesn't seam to be directly related to power output or use.
    I know your Anthony cracked, now chickinhed's, and dmitry said that Avee had two blocks crack. I know Donnovan Marvin had one crack with 11's but it was during a catastrophic engine failure. Mike R ran 11's for awhile but I don't know if he stopped because of cracking.
    The blocks also crack in places other than the head bolt holes. I've seen them crack between cylinders and also down the side of the cylinder through the side of the block. The 87mm bores I think are much more prone to this. I also wonder if perhaps there is a problem with the casting of certain blocks.
  15. #615
    poconos pa
    e36 m3, turbo e36
    My block looked the same as Brads, s50 with 10mm arp 2000's. I had 5 stud holes with cracks.
    -sold...replaced by turbo e36
  16. #616
    Oct 2005
    Northern California
    95 M3, 15 Golf TDI wagon
    I bought the CA625+ head bolt kit since there seemed to be a lot of cracking issues with drilling the block for 11mm.
    -WTB: OEM Class 2 LTW GT wing with risers- Mazak
  17. #617
    '97 M3
    The cracks in the block look old, it’s hard to tell with the head cracks.
  18. #618
    poconos pa
    e36 m3, turbo e36
    Has your block ever overheated?
  19. #619
    Feb 2014
    Galt,CA
    2002 M Coupe
    You guys do realize that torquing an ARP stud with fine threads to 95 pounds is about the equivalent of torquing a headbolt to about 120 pounds? That puts a lot of stress on the block! Then you add combustion forces on top of that.
    Marty
  20. #620
    Huntsville, AL
    95 M3
    Is one of the cylinders steamed cleaned more then the other? It just appears that spark plug has some heavy carbon buildup for what should have some steam cleaning effects due to coolant leakage.
    WOT
  21. #621
    '97 M3
    The 11 mm studs with the higher torque happened in response to a blown head gasket...... or two...... in hopes of it not popping as easy. Unfortunately then the block cracks and the head cracks. The stock head gasket and o-rings work very well when clamped that tight.
    In the blocks 250,000 mile life it has experienced water pump failures, rad hose failures, heater hose failures, over boosting, detonation, many track days and sitting in traffic. There are a few ‘incidents’ ,trying to gain boost control, over the last year that I can think of that probably put more stress on the head stud holes then they should have.
  22. #622
    '97 M3
    I picked up a head and dropped it of with my head guy. The new used head will get pressure tested, surfacing, new guides, porting and and a valve job with the stainless/inconel valves and other fancy bits.
    I found an M52 block but the guy had thrown away the bearing caps......
  23. #623
    NY
    skateboard
    So much sadnesses
  24. #624
    Vancouver, BC Ca
    1993 325is
    My block has bearing caps!!
  25. #625
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by GG///M3 View Post
    So much sadnesses
    Its better to have boosted an blown up than never to have boosted at all.
  1. My mini build thread for the 98iL
    By dburt86 in forum 1995 - 2001 (E38)
    Last Post: 05-04-2014, 01:30 AM
  2. Glove Box Power Ports Mini Build Thread
    By DrJomamachubby in forum 1988 - 1996 (E34)
    Last Post: 10-04-2011, 05:53 PM
  3. Almost there... Mini Build
    By onasled in forum Track Car Builds
    Last Post: 12-29-2010, 10:15 AM
  4. BMW/Mini builds great cars...in a crash
    By Fripp64 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-15-2010, 05:02 PM
  5. Mini build
    By rbodor3 in forum MINI (Cooper & Cooper S)
    Last Post: 07-17-2009, 03:40 PM
