Page 22 of 23 FirstFirst ... 121314151617181920212223 LastLast
Results 526 to 550 of 551
Thread: Chikinhed's Mini Build
  1. #526
    Vancouver, B.C., Canada
    '97 M3
    On an up note Iím seeing 20 psi in 3rd and 4th by 3175 rpm. The four port is doing work.
  2. #527
    Vancouver, BC Ca
    1993 325is
    Quote Originally Posted by chikinhed View Post
  3. #528
    Bellingham, WA
    e30
    Quote Originally Posted by vollosso View Post
    I was worried about 1800 hah.
    I’d get that sorted before boost. 12.9 is really asking for it.
    What do your plugs look like?
    Edit: By the way I’m not trying to disrupt, just thought I’d comment the concern.
    I see huge jumps in knock correction after cars get above 12.3. I recommend people set their failsafes to 12.3 now.
    If the engine is going lean and misfiring your lambda readings will bounce around too. Just something worth checking if you have not already.
    -Nick
    91 E30 M42 on VEMS
    Turbo Camshaft Thread
  4. #529
    '97 M3
    Woot! Woot! I have a revision but canít load it until later tonight. More datalogging to come.
  5. #530
    Jun 2005
    Concord, NH
    08 E90M3; 99 E36M3 Turbo
    I want to read about 25 psi from the EFR9180. I never go more than about 20.
  6. #531
    Louisville, KY
    turbo m3
    Iíd get that sorted before boost. 12.9 is really asking for it.
    Edit: By the way Iím not trying to disrupt, just thought Iíd comment the concern.
    When should one worry about EGTs on a gas motor? Letís say measured before the turbine and after.
  7. #532
    '97 M3
    Max EGT for an EFR is said to be 1742įF. For other turbos the max is usually around 1750įF and special race turbos can go as high as 1925įF.í Anytime you heat a metal near its limit it will fatigue faster. I set a personal limit around 1600 - 1650įF.
  8. #533
    Mar 2012
    Birmingham, AL
    99 m3
    Quote Originally Posted by BadBoostedBmwM3 View Post
    Well egt location is specific and if itís not in the correct spot temps are really not accurate.
    Generally temps run between 1100-1400f.
    On super high performance stuff think 1000-1500hp, with nitrous, upwards of 1600. Ethanol is cooler by at-least 100f.
    For a high boosted 4-cycle application, on pump gas, anything above 1650f would be a concern for me. I would hard stop before 1700f. In the end, an engine likes what it likes if you make peak power by pushing hotter that works.
    I guess I didnít post this earlier an accident.
    As you have multiple cylinders merge, temps raise. If youíre running your egt lower or after merge it will be different.
    As you leave stoich temps drop. In both directions.
    1989 535i - sold
    1999 Tiag/Dove M3 - sold
    1998 Turbo Arctic/black - current
    2004 TiAg/Black - Current
    PTE6870 | 1.15 ar | Hp Cover, Custom Divided T4 bottom-mount, 3.5" SS exhaust, Dual Turbosmart Compgates, Turbosmart Raceport BOV, 3.5" Treadstone Intercooler, 3.5" Vibrant resonator and muffler, Arp 2k Headstuds | Main studs | 87mm Je pistons | Eagle rods | 9.2:1 static compression, Ces 87mm cutring, Custom solid rear subframe bushings, Akg 85d diff bushings, 4 clutch 3.15 diff, 14mm diff bolt conversion, Poly engine mounts, UUC trans W/ enforcers, 22RPD OBD2 Stock ECU id1700 E85 tune, 22RPD Big power Transmission swap w/ GS6-53
  9. #534
    '97 M3
    I should clarify that the temps Iíve been talking about are TIT or turbine inlet temperature which can be slightly lower than EGT because it is measured farther away from the exhaust port. EGT is usually the temp of a single cylinder and TIT will be the sum of multiple cylinders. My probe is mounted just before the turbine flange on the TS Steed for cylinders 1-3.
  10. #535
    '97 M3
    The revision has brought it down into the low 10ís. Power feels down but itís safer. Jordan is on it. I have to get Jordan a proper log with load so he can work his magic.
    A bit more fine tuning of the eBoost2 and Iím getting a fairly stable 23 psi with an initial spike to 24. I need to look at data logs of boost to fine tune it more.
    Once the tune and boost are sorted a bit better then its going back to the dyno to see what she has got.
    I had it out on some twisties tonight, what I actually built it for, and it just blows me away what it can do. Iím in love again.
    Iíve been scared to do a hard launch, just incase all the rear subframe attach work didnít fix the hop, but......... she is tight. Those poor RE71Rs got lit up a bunch of times from a launch, first at 2000 rpm, then 3000 rpm and then close to 4500 rpm just to be brutal. Nice smooth black stripes and only a slight remenisant feeling of hop as it was bouncing off the rev limiter (not hop). Yay, I finally won that battle. Screw you hop! (Iíll post this in my rear subframe thread for some closure)
  11. #536
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Nice! The 4 port solenoid is much better at controlling boost, i converted my truboost to a 4 port and the difference is amazing.
    Ive had luck with r888r 275 radials, no spin from a 40 in 85 degree weather boosting 30-31lbs.
  12. #537
    '97 M3
    If I ever get flares on my car Iíd like those or the 295s.
  13. #538
    '97 M3
    I took the car to the Ridge Motorsport park near Seattle today. The EFR was amazing on the track. I kept the boost down to 18 psi and it still had gobs of power on the road course. Water temps were under 220įF and oil temps were less than 240įF. I went through six gallons of 50/50 water/meth.
    The water cooled brakes version 1.0 seemed to work great. I had no brake issues at all. I filled up my washer reservoir with water after each run. I need a check valve though as it leaks out the nozzles when the tank is full. I used the headlight washer pump and hoses for the system and itís triggered by the brake light switch. I even get a low washer fluid warning when itís getting low.
  14. #539
    Jun 2005
    Concord, NH
    That is a lot of meth to use in one day!
  15. #540
    '97 M3
    Itís probably close to 25% water/meth to fuel when itís spraying from the exit of each corner to the entry of the next I have two 0.8 nozzles just after the MAF and a 0.3 right at the compressor inlet. I do need to fine tune the Aquamist but in the grand scheme of things I will still go through a boat load of water/meth at constant WOT.
    A couple of days ago I connected up a fuel pressure sender to the openOBC. I also installed a new front lip, switched to a new ZT-2 and changed to 15W50 Mobile 1. Since I was wiring the cooling for the brakes I figured Iíd do all the other wiring st the same time.
  16. #541
    Bellingham, WA
    e30
    Nice, how did you like the Ridge? I haven’t been there yet but it looks like a great track.
    Take your car to Spokane or Oregon Raceway Park to see how well the setup does in the hot weather!!
    -Nick
    91 E30 M42 on VEMS
  17. #542
    '97 M3
    I thought it was hot at the Ridge yesterday. I was seeing 105įF on the OAT, even at 5 pm when when I was driving away from the track it was 90įF. The car handles the heat pretty good. I actually have a Stewart WP install that has a lot of cavitation damage that you obviously wouldnít see unless you pulled the pump off. I have a new pump, Iíll post pics of the removed pump once itís off.
  18. #543
    Oct 2005
    Northern California
    95 M3, 15 Golf TDI wagon
    The water cooled brakes version 1.0 seemed to work great. I had no brake issues at all. I filled up my washer reservoir with water after each run. I need a check valve though as it leaks out the nozzles when the tank is full. I used the headlight washer pump and hoses for the system and it’s triggered by the brake light switch. I even get a low washer fluid warning when it’s getting low.
    Water cooled brakes?
    -WTB: OEM Class 2 LTW GT wing with risers- Mazak
  19. #544
    '97 M3
    My local road race course is really hard on brakes. Even with 3" ducting to the center of the front rotors, titanium shims between the pads and pistons in the calipers, the Castrol SRF brake fluid is getting hot and squishy and I burnt 1/2 way through $500 worth of brake pads. Water cooling has been around for a long time. These guys sell a kit for GTRs - http://www.willallracing.com.au. Australian V8 super cars use water cooled brakes as well.
  20. #545
    '97 M3
    Here is a no traffic lap I did at the Ridge Motorsport park on Sunday.....
    https://m.youtube.com/watch?v=NZrhrrUSnbQ
  21. #546
    Bellingham, WA
    e30
    Mission is hard on brakes for an E30 with an M20. I can only imagine what its like for your car at that power level!
    -Nick
    91 E30 M42 on VEMS
  22. #547
    Def's Avatar
    Def is offline Lead Disagreement Eng PE
    Aug 2002
    SW22, Volt
    Nice - I need to make it out there.
    What group did you run with at Ridge?
  23. #548
    '97 M3
    A group was full and I hadnít driven the track before so I accepted the spot in C group. After lunch I was in B group. The group putting on the event has open passing anywhere with a point by which is not like any other HPDE group Iíve been with. They were mostly all Ďtunerí cars.
  24. #549
    Def's Avatar
    Aug 2002
    SW22, Volt
    I was more asking what organization put on the event, not necessarily run group.
    Looks like BMWCCA does some occasional 1 day events, actually most orgs do one day events in the area, which is new to me. Everywhere in the SE and TX region is a 2 day weekend event, and quite a bit cheaper than here!
  25. #550
    Bellingham, WA
    e30
    Def, didnt realize you relocated!
    -Nick
    91 E30 M42 on VEMS
  1. My mini build thread for the 98iL
    By dburt86 in forum 1995 - 2001 (E38)
    Last Post: 05-04-2014, 01:30 AM
  2. Glove Box Power Ports Mini Build Thread
    By DrJomamachubby in forum 1988 - 1996 (E34)
    Last Post: 10-04-2011, 05:53 PM
  3. Almost there... Mini Build
    By onasled in forum Track Car Builds
    Last Post: 12-29-2010, 10:15 AM
  4. BMW/Mini builds great cars...in a crash
    By Fripp64 in forum General BMW sponsored by Intercity Lines
    Last Post: 12-15-2010, 05:02 PM
  5. Mini build
    By rbodor3 in forum MINI (Cooper & Cooper S)
    Last Post: 07-17-2009, 03:40 PM
