Page 2 of 34 FirstFirst 12345678910111227 ... LastLast
Results 26 to 50 of 832
Thread: Chikinhed's Mini Build
  1. #26
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    You can also notch the SF and welded a reinforcement plate on top. I run my vacuum line through the SF. Even if the treadstone part fits, you would still want at least 1/4 inch clearance to allow for engine movement.
  2. #27
    Austin, TX
    S13, Turbo M3
    Quote Originally Posted by wazzu70 View Post
    Also there is this recirc cover. Not sure if its lower profile or not.
    http://www.full-race.com/store/efr-s...-cover-2.html/
    These are about the same total distance with the fitting screwed in as the nipple. I have installed one of these on a 7163 I can measure today for total length if need be. It will be similar to the length of the plastic barb, but you can run the fitting off at a 90* instead of having to push a hose on straight.
    Mike
    IG: @mikevanshellenbeck
  3. #28
    Jun 2005
    New England
    The stack height will be about the same, but as is, the straight version does not allow you to install the vacuum hose. At least with the right angle, you can install the vacuum hose. But the end of the fitting will be almost right at the SF and if there is engine movement, you will be banging the expensive turbo against the SF, something I would not want to do. I think you will need to notch or section the SF less with the treadstone fitting. I looked into threading a right angle fitting into the plastic cover, but would not have gained enough space. Maybe with the correct fitting it would work. I broke the nipple off on my 8374 test fitting it and installed a brass barb into the plastic fitting, but had more room in that application.
  4. #29
    Vancouver, B.C., Canada
    '97 M3
    Quote Originally Posted by Matutino View Post
    Can you do extra motor mounts?
    Now that I have a template I can probably make a few extra arms.
    Quote Originally Posted by 3literheater View Post
    I'm interested to see if either one of those recirc covers will work. Since you can see how things are fitting do you think it is possible to send the hot side over the subframe?
    I'll rotate the compressor housing and take some pictures for you. The arm I made goes higher near the block for the compressor boost pressure fitting. It would be nice to have a banjo fitting at the spot as well so that there is more clearance for the boost reference hose. With the straight fitting, there would only be about an inch that it would have to do a 90° bend if the mount came lower. The fittings has straight threads and uses an aluminum crush gasket.
    My mount arm sits about a 1/2" closer to the compressor housing than the Rallyroad arm in the picture. I'm trying to keep the distance from the arm to the poly mount stud short.
  5. #30
    Geigertown, PA
    95 M blk/blk
    Looking good, im a week or two away from fitting my steed and 8374 also. If we are using the internal recirculating valve would we need a draw through tune and maf?
    96 328i ITR Racecar
    95 M3 blk/blk - hillclimb project - http://forums.bimmerforums.com/forum....php?t=1798796 - Retired to street duty after two awesome seasons!
    2002 325XiT - daily
  6. #31
    Apr 2006
    Minnesota eh?
    86 325es
    ^^^ no blow through will be fine
  7. #32
    May 2003
    Irvine
    95 M3, 03 E55, 07 335I
    Quote Originally Posted by chikinhed View Post
    Sounds good, let me know how much $$ and I'll gladly PayPal you for 1
    Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
    New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
  8. #33
    Mar 2012
    Renton, Wa
    98 m3
    If you want to send me critical dimensions i can have some plasma/laser cut.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  9. #34
    '97 M3
    I finished up the engine mount arm tonight. I just need to paint it and install.
  10. #35
    Jul 2005
    PEI, Canada
    2001 330i
    Is that Meth nozzle holder a new addition?
    Looks great!
  11. #36
    '97 M3
    Quote Originally Posted by PEI330Ci View Post
    Is that Meth nozzle holder a new addition? Looks great!
    The meth nozzle holder is new. There is a guy from Toronto selling them on eBay. It comes with sharp edges so I streamlined all surfaces exposed to air flow.
    http://m.ebay.ca/itm/Pre-Turbo-Compr...=1848247090012
    I have been spraying pre turbo for a while but from a spot about 15" upstream of the turbo.
  12. #37
    '97 M3
    Quote Originally Posted by vollosso View Post
    If you want to send me critical dimensions i can have some plasma/laser cut. Sent from my iPhone using Tapatalk
    Thanks for the offer. Let's wait to see the CES offering first.
  13. #38
    Oct 2005
    Northern California
    95 M3, 15 Golf TDI wagon
    That motor mount looks pretty good man!
    -WTB: OEM Class 2 LTW GT wing with risers- Mazak
  14. #39
    Mar 2012
    Renton, Wa
    98 m3
    Yeah, just let me know. I can probably get something like a run of 10 cut and welded in like 2 weeks.. plasma cut ms would be pretty cheap too..
    1989 535i - sold
  15. #40
    '97 M3
    I started on the down pipe and the waste gate piping......
  16. #41
    May 2003
    Irvine
    Nice progress... I need to learn how to weld to speed up my build.
  17. #42
    Manchester, N.H.
    96 332IS 6466 turbo
    Buy a cheap 120-140amp flux core mig welder, auto darkening helmet, angle grinder and an abrasive chop saw. Go to pep boys or auto zone and spend $10 in tail pipes. Cut them up and weld them back together.
    If you do 20 cuts and just can't get the hang of it, or you don't like it sell the crap on CL and call it a day. At least you tried.
    If you find you love it , can't get enough of it, then sell it and buy quality machines.
    But you could get everything you need to "get the job done" for around $400-500 max.
    Sure it won't be rainbow colored stacked dimes but you can seal the pipe and say you did it.
    I personally think every single person in this section should AT LEAST have the above.
    Unless you just have money to burn and pay someone labor.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  18. #43
    May 2003
    Irvine
    I use to weld long long ago, I learned welding when I was 13 years old, but have not done it for at least 25 years.
    Any good 20-140amp flux core mig welder from harbor freight? I can go pick one today and give it a try
  19. #44
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Don't get a harbor freight AC flux core wire welder. It will make you hate welding.
    I have a Hobart 140 mig welder and it's a great entry-mid level welder.
  20. #45
    Manchester, N.H.
    96 332IS 6466 turbo
    Home depot carries Lincoln, also Thermal ARC is decent.
    You can get one for under $300 iirc. I've been thinking about buying a new mig, I currently have a couple of them. If I do , I'll sell you one cheap.
    1996 332IS
    Built 3.2
  21. #46
    Jun 2005
    New England
    Try an Eastwood 140A Mig that can run gas or flux. 120V, $249 on sale, $299 regular price. I have one.
  22. #47
    Manchester, N.H.
    96 332IS 6466 turbo
    Great welder for the money.
    I have tries his eastwood, it works rather well for the money. Maybe stay away from the HF stuff. But Eastwood is a solid unit.
    1996 332IS
    Built 3.2
  23. #48
    May 2003
    Irvine
    Do you have a link so I get the right one.
  24. #49
    Apr 2012
    Tampa, FL
    E36,E38, and E46
    There is also a great 200 psi 2 stage pump on ebay. 12vdc and something like 5 gpm and less than 30 bucks. (For the nozzle if you dont have one)
  25. #50
    Geigertown, PA
    95 M blk/blk
    Fabrication looks great man. What sizes are you running for the exhaust and wastegate pipe, 3" and 1.75"?
    96 328i ITR Racecar
    2002 325XiT - daily
  1. My mini build thread for the 98iL
    By dburt86 in forum 1995 - 2001 (E38)
    Last Post: 05-04-2014, 01:30 AM
  2. Glove Box Power Ports Mini Build Thread
    By DrJomamachubby in forum 1988 - 1996 (E34)
    Last Post: 10-04-2011, 05:53 PM
  3. Almost there... Mini Build
    By onasled in forum Track Car Builds
    Last Post: 12-29-2010, 10:15 AM
  4. BMW/Mini builds great cars...in a crash
    By Fripp64 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-15-2010, 05:02 PM
  5. Mini build
    By rbodor3 in forum MINI (Cooper & Cooper S)
    Last Post: 07-17-2009, 03:40 PM
