Could you put one of these in place of the Turbosmart IWG actuator?
http://www.tialsport.com/index.php/p...mvinewsrelease
It may not for you because your running a quicker spooling 62mm turbo. But, coming from a 6466 with a known great tubular manifold 666, I was seeing 22-24 psi by 4500 now I can see 25 psi by 3700 and 21# by 3400. For those running bigger turbos, this manifold is the best spent money.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
I disconnected the bottom port on the IWG. With EBC off I get 13 psi, Tial EWG spring pressure. With the EBC on and set to a target boost of 22+ psi the most I get is 17 psi which is the current IWG spring pressure.
Next trouble shooting option is to disconnect bottom and top ports on the IWG and see if just the Tial EWG can control the boost.
Edit: With both IWG ports disconnected the Tial MVR EWG can't control the boost under at least 26 psi, the IWG is required. With EBC off it over boosts, with EBC on it over boosts faster.
I could probably band aid it by installing a 25 psi spring in the IWG and hope that the Tial will give me something lower than that but I don't think it will.
I think the best option at this point is to try an eBoost2 with a 4-port boost solenoid because, according to Seb at NLR Systems, the maker of the AMS-500, I can't use a 4-port solenoid with the AMS-500 and it won't hold the boost stable with a leaking Turbo(not so)smart IWG.
Patiently waiting for more parts......again
One more idea for the night. I hooked both ports of the IWG back up and increased the preload on the IWG valve by another 2 mm and I turned the high boost setting up to 25 which should be WG spring pressure plus 25 psi. It spiked up to 24.7 psi for a split second and settled back at 21 psi until 6000 rpm then it fell to 18 psi and slowly climbed back to 19 psi by 6800 rpm. I might try a couple more mm of preload tomorrow. I don't like the initial boost spike. It could cause the ECU to pull timing.
Here is a log from last night.
Is that bottom trace exhaust back pressure? What fuel?
1000+RWHP, Lab22 Built Turbo S54 - BMW Half Mile Record Holder
Interesting afr's. Are those accurate?
1989 535i - sold
1999 M3 Tiag/Dove - sold
I have three different AFR's from three different gauges.
Zeitronix reads the richest at 9.6-10.5 at WOT (with old and newish sensors)
AEM failsafe reads 11.5-12.0 at WOT (with old and brand new sensor)
Innovate reads 12.5-12.9 at WOT (with same old and newish sensor as was used with the Zeitronix and both were fresh air calibrated)
Which one would you believe?
Could the boost be dropping off at 5800 rpm due to vanos or is just the exhaust back pressure pushing the WG open?
1989 535i - sold
can you log pressure signal to wastegates at the wastegates....possibly in the same log to correlate the numbers?
I'd be scared to run that car at 20+ #.
Put the zetronix sensor first in the stream and change the values to lambda. See what happens.
Do all the sensors read 14.7ish at idle ? Only in boost do these read differently ?
1996 332IS
Built 3.2
Have you tried only running the external waste gate and leaving the IWG open?
Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
1996 332IS
Built 3.2
The IWG is losing too much pressure from the top side (EWG term) of the IWG. There is no seal where the shaft comes out of the canister which is leaking pressure to control the WGs.
I need to do what Bry suggested to confirm what is going on. I've discussed this with NLR Systems and they said a leak would cause boost control issues. I've just emailed Turbosmart to ask if a seal can be installed or if they have another solution for me. We will see what their support is like.
I was doing pulls the other night and when it hits 25-26 psi in 4th it squats and pulls pretty hard. This 17-20 psi stuff is now boring, I want the 25 psi for DDing.
Turbosmart ewg...
if you look at the outside of the wg between the cast ss elbow and the aluminum housing for the diaphragm you will see 3 spacers like triangle. If you pressurize the housing air leaks from those spacers the seal on the inside of the housing is blown. 3 screws on the inside each with a seal underneath them they go through the spacers you can see from the outside. They attach the top half to the bottom half (housing to stainless elbow).
second place they leak is the valve that is being driven by the diaphragm. Its a brass bushiing for a valve lke in a head. Ive seen them have way too much clearance and have blow by. An easy way to solve the valve leakage temporarily is pick p silicone lube. Work the lube up and down the valve stem and it will temporarilyhold pressure.
Or retrn it if its leaky.
Tonight I moved the fuel pressure transducer over to the line from the boost solenoid to the top of the WG and this is what is going on....
It looks like the WGs might be doing what they are being told to do. I'm not sure if it is because of the added volume in the boost control lines but boost was going a bit higher, up to 26 psi, vs a couple of days ago at 24 psi.
I forgot to mention that the bottom plot is now reading the boost control pressure to the top of the EWG.
You don't have any way to log the duty cycle at the solenoid do you? Looking at the pressure trace going to the EWG it looks to me like you have a controller problem.
1996 332IS
Built 3.2
I'll borrow a othe AMS-500 from Avee. It's almost acting like the line to the EBC is pinched.
At least you have a place to look to solve your issue. Better than just guessing
Duty cycle would help. It should be something like 12 volts that you may be able to scale tomthe proper voltage range for an analog input. The pressure signal to the ewg looks like its either muddy from distance, volume, or hose expansion. It could be a leak as well. Double or triple the p or proportional and double or triple the i or time variable. Have it make bigger corrections half as often. look at the second pull. The boost pressure has a crisp transition from the pressure increase to the constant pressure. If you have a derivative set it to 0. Doubling p and i should eventually lead to instability but if its a controller problem you could see the signal pressure get crisper.
duty cycle is correlated in a round about way to the air pressure being added to the springs. the math isnt right but here is an example. If the system is fairly rigid and sealed and you have 10 psi at the valve and 50 percent duty you should get 5 psi to the wg. So by extrapolation if you have a 5 psi leak and you want 5 psi of force to help the spring 100 percent duty is you number.
p is how much to correct by every i seconds. If the leak is in range of the controller you can duct tape it. You can also tune out friction and flutter blah blah blah.
Pressure of both valves plotted together does the same but can show you how compressibility, friction.....affects each other and then there are ways to duct tape or minimize those. Duty will show you ....
thinking about this you may get better response if you tune boost the boost controller with the pressure signal at the wg instead of the manifold. But pressure in the manifold will probably be unstable with the setting you have now. You would need to minimize p and set the time to maybe 500ms or so.
anyways need more data
