Page 17 of 34 FirstFirst ... 789101112131415161718192021222324252627 ... LastLast
Results 401 to 425 of 832
Thread: Chikinhed's Mini Build
  1. #401
    Vancouver, B.C., Canada
    '97 M3
    Turbosmart Hypergate 45 max valve travel is 0.437".
    Tial MVR 44 max valve travel is 0.609".
    The external Turbosmart Hypergate I have installed has a brown/purple (7 psi) middle spring and a brown/pink (7 psi) outer spring as the box indicated.
    I have applied pressure to the EWG and to the IWG and both crack open at about the same pressure. The IWG may have opened about one psi sooner. The Tial opens a couple of psi higher but this should not be a factor. Having 14 psi springs in the WGs should allow for more than 22 psi.
    I have adjusted the preload on the IWG from 2 mm to 3 mm. I've got a couple more things I want to deal with before it comes off stands.
  2. #402
    '97 M3
    I finished up another round of 'To Do' list items on the M3 and did more troubleshooting. I increased the preload up to 3 mm on the IWG actuator and turned up the boost on the boost controller. Nothing changed. With the boost controller set at about 26-27 psi all I get is 21-22 psi initially and it tapers down to 18 psi by 5300 rpm. I guess the next thing to try is to remove the boost reference line from one of the waste gates to see if one is opening early. The external will be first. I also swapped in a new NTK O2 sensor for the AEM failsafe AFR gauge. I don't think the reading changed from the old sensor. It reads about 0.5 afr leaner than the Zeitronix at idle, maybe 1.0 at WOT.
    No definitive easy answers here. At least it drives and it's pretty quick but the boost taper is lack luster.
  3. #403
    Mar 2012
    Renton, Wa
    98 m3
    I feel like its the season of struggle, seems like everyones car is having troubles.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  4. #404
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by vollosso View Post
    I wish, Butters be bored.
    I should probably be careful saying that.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  5. #405
    '97 M3
    This whole process is like molasses. I've been bogged down with too many airplane projects to be able to dedicate any time to my car. Hopefully the I have a breakthrough soon.
  6. #406
    Mar 2012
    Renton, Wa
    98 m3
    If youre bored you should hit up reilly he has quite the puzzle lol.
    1989 535i - sold
  7. #407
    Manchester, N.H.
    96 332IS 6466 turbo
    I will shoot him a text.
    1996 332IS
    Built 3.2
  8. #408
    '97 M3
    I've disconnect the bottom port on the EWG and only get a steady 19-20 psi now with the EBC set to 28 psi. The car will have to go back up on stands again to do this test on the IWG. I need a Dyno with a pit underneath.
  9. #409
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by chikinhed View Post
    Your running a line to the top port of the EWG ?
    1996 332IS
    Built 3.2
  10. #410
    '97 M3
    Yes
  11. #411
    '97 M3
    I had a chance to go wot again and it is behaving the same as with the EWG hooked up.
  12. #412
    '97 M3
    I disconnected the hose from the top of the IWG and plugged it and now I get all the boosts at any EBC setting. EBC can't control the boost without the IWG hooked up.
    I thought, maybe, even though I had obsessively checked the routing, that I crossed the hoses to the EWG so I tried swapping top and bottom hoses to see if it was any better but this time the boost climbed insanely fast, so that isn't it.
    This is starting to point to weak IWG springs. The IWG gets installed on the turbo before the turbo gets installed. It will be loads of fun getting it out of there to check to see if it has the right springs. The box it came in says '14 psi' on it.
  13. #413
    Jul 2005
    PEI, Canada
    2001 330i
    So the top port of the IWG actuator opens that WG, and the bottom port of the EWG opens that WG?
  14. #414
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Yes. I run just one port on each wg and use those respective ports. My line from the boost control solenoid is teed.
  15. #415
    '97 M3
    Quote Originally Posted by PEI330Ci View Post
    Correct. The IWG connections are reverse to how an EWG operates per the install diagram.
  16. #416
    May 2003
    Irvine
    95 M3, 03 E55, 07 335I
    Painful having to remove the turbo to change the spring.
    At least it seems you found the issue.
    Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
    New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
  17. #417
    Mar 2012
    Renton, Wa
    98 m3
    I remember some testing a couple years ago and thinking everything under the heaviest spring was useless..
    1989 535i - sold
  18. #418
    Manchester, N.H.
    96 332IS 6466 turbo
    EFR is good stuff, wish it was louder.
    1996 332IS
    Built 3.2
  19. #419
    '97 M3
    I remember some testing a couple years ago and thinking everything under the heaviest spring was useless.. Sent from my iPhone using Tapatalk
    I'm using a Turbosmart IWG actuator where you can pick any psi you want.
  20. #420
    '97 M3
    I can faintly hear the turbo with my windows up, it's louder with the windows down.
  21. #421
    '97 M3
    Quote Originally Posted by Matutino View Post
    Painful having to remove the turbo to change the spring. At least it seems you found the issue.
    The IWG does come out without pulling the turbo if you are really patient.
    I have confirmed that the IWG has a pink/brown and a purple/brown spring combo installed = 14 psi.
    I have a nice Tial WG spring here that fits but who knows what affect it would have on the IWG. I could mess around with a spring tester and figure it out but I think I'm just going to leave the springs as they are and crank the preload up to to 6 mm and see if that helps... It should.
    Assembled spring force is initially at about 40 lbs. they recommend 2 mm preload which is about 50 lbs. 6 mm of preload brings the initial spring force up to about 60 lbs. I'll loose about half of my WG travel though by doing that. If I remove the purple/brown spring and install the yellow Tial spring then my initial will be 60 lbs and I'll have more travel to play with. It's a big bitch to swap it out if it's totally wrong thought.
  22. #422
    '97 M3
    Now it spikes to 25-26 psi, settles down to 23 psi and tapers down to 20 psi after 5500 rpm. I can still control it to 14 psi with the EBC off for the failsafe.
    This means that I may still have to install the Tial MVR in place of the TS Hypergate if it can do a better job of controlling the boost spikes.
    Edit:
    Looking at the datalog, it is spiking to 25 psi at 3500 rpm and comes down to 21 psi by 3650 rpm, stable until 5000 remand then tapers down to 17 psi by 5700 rpm and stays there until i lifted at 6900 rpm. Even on a lower boost setting, it peaks at 20 psi at 4600 rpm, drops to 16 psi by 5100 rpm then it drops at 6500 rpm down to 15 psi until redline.
    On a side note, it looks like the transient response is a bit slower than the open 0.82 GTX3582R was. I am only looking at one catalog though and its not under the same conditions as the GTX3582R logs. More testing required.
  23. #423
    Bellingham, WA
    e30
    Interesting. Geoff at full race might have some infos on the IWG if you search around or ask him. I assume you have already searched on the topic though.
    -Nick
    91 E30 M42 on VEMS
    Turbo Camshaft Thread
  24. #424
    Manchester, N.H.
    96 332IS 6466 turbo
    Put the MVR in. The turbosmart sucks.
    1996 332IS
    Built 3.2
  25. #425
    Apr 2012
    Tampa, FL
    E36,E38, and E46
    If you have an external ts wastegate they have a cap that you can put a wastegate position sensor on. Sensor is 10 bucks at junk yard. You can also get a linear magneto pot for the iwg.
    Do you see a point in the log where the iwg might be opening but cannot wastegate enough?
    you maight have better luck if you run the iwg to a lower boost on springs and only ebc the ewg. If you are trying to synch the signal pressure to trigger the valves together you should have no problems if the mass through the e and iwg is the same. Doesnt the mass change through the ewg change as the mass through the iwg is waste gated?
    when you run on springs only without the signal line the mass through the exhaust overcomes the spring. If the 2 wg were in parallel to wg flow then you have something more controllable but if they are in series to the flow the signal pressure would be the same but not the mass flow.
    If you had an iwg and ewg with the same spring force you should see the ewg open when the iwg is passing enough mass to act on the ewg valve + spring weight. Mass flow would take milliseconds or maybe seconds later. You might be able to balance the wgates by taking spring rate out of the one that gets delayed but you may also have to account for the area of the valve that exhaust mass is working against.
  1. My mini build thread for the 98iL
    By dburt86 in forum 1995 - 2001 (E38)
    Last Post: 05-04-2014, 01:30 AM
  2. Glove Box Power Ports Mini Build Thread
    By DrJomamachubby in forum 1988 - 1996 (E34)
    Last Post: 10-04-2011, 05:53 PM
  3. Almost there... Mini Build
    By onasled in forum Track Car Builds
    Last Post: 12-29-2010, 10:15 AM
  4. BMW/Mini builds great cars...in a crash
    By Fripp64 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-15-2010, 05:02 PM
  5. Mini build
    By rbodor3 in forum MINI (Cooper & Cooper S)
    Last Post: 07-17-2009, 03:40 PM
