thats a MUCH different scenario then flooring it on a inertia type dyno.
so if it makes 5 psi at 2500rpm on a inertia type dyno, what would happen if you brake boosted it in 5th gear at 2500rpm?
Maybe this is all true. I could see a 3582 spooling pretty quick, but jesus.
328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
9.20 at 150 on 22psi
Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
1.06 ts is basically same if not smaller than .82 open. I think something is either wrong with big boost leak, timing or that turbo. I'll try to get some low rpm pulls on mine to compare to yours. You should be ahead of me in spool as my turbo is a bit bigger. But I have a 1.0ar basically same as you.
Text me your logs, and I will duplicate the conditions and log.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Every person I spoke to disagrees with the statement that .82 is the same as divided 1.06.
The only similar set up is CESs with standard gt35r and stock cams, my set up has a bigger wheel and bigger cams and the difference is 300 rpm which makes sense.
I will text you the logs
20 psi at 3200 in 4th from a 66mm turbo on a pump gas tune cammed S52 seems great to me. Might be in the 625 rwhp range. When is the dyno?
How are you guesstimating whp?
I would hope for more than 625
1996 332IS
Built 3.2
If I was at 660 whp at 24-25 psi ont the GTX and I'm at 21 psi on the efr, 625 whp might be right.
I don't think a twinscroll turbo or manifold makes any more peak power than open ones. Might even make less. But I do think the bigger turbo is more efficient in both the compressor and turbine in the 600+ rwhp power level than the smaller one you had before. CES made about 690 rwhp SAE at about 20 psi with a 1.45 back housing on race gas with a race gas tune. I think you should make less than that on pump gas with a 0.92 housing. My conservative guesstimate is 625 rwhp SAE Dynojet at 20 psi. Might get 650, but I'd rather be excited than disappointed so I choose the lower end of the range.
I guess 643whp at 20 psi. Chikin do a give away; anyone who guesses right within +/- 1whp wins something.
Something strange is happening with my new set up. The AMS-500 is still set at 7 for low boost and 13 for high boost. You add those numbers to the spring pressure to get the max boost pressure settings. I'm guessing that with the new manifold and the new waste gates (14 psi springs) that something isn't right. I should be seeing 21 psi and 27 psi but I'm only seeing 18 psi and 21-22 psi. I use to see 20 psi and 24-25 psi with the old set up and those settings on a 13 psi WG spring. I will have to do a boost leak check to make sure that I don't have a boost leak somewhere but that is a big difference.
I think Steed should modify the manifolds to accept this......
http://www.turbosmartdirect.com/Prod...psi-Black.html
I don't want another TS WG. Don't think much of them. Poor boost control compared to Tial. But there is a WG out there in 50mm that fits a 44mm flange. It's not compact so it will have clearance issues to the SAP tray but I think the taller WG have more piston movement and open more and may flow more. I forget who makes it. Maybe JG Tool or something like that.
These used to be the rage, but I never see them on here. Reaction time is supposed to be fast. Not sure if thats the issue or the gate is just not big enough.
http://www.synapseengineering.com/v4/wg/
What are you referring to Nick?
The new AMS-500 V2 looks pretty awesome.....
Any chance that controller needs to be set up differently for dual WG? You could try a 4 port actuator. Or maybe 2 three port actuators. Are you using efr solenoid or Mac? Efr has small internal passages. I doubt 14 psi springs are not holding 22 psi.
1996 332IS
Built 3.2
