Page 12 of 34 FirstFirst ... 2345678910111213141516171819202122 ... LastLast
Results 276 to 300 of 832
Thread: Chikinhed's Mini Build
  1. #276
    Vancouver, B.C., Canada
    '97 M3
    It's not an e-boost, it's an AMS-500 so it works a bit different. I'll turn the boost up a bit and retest in 4th.
    I was doing the same test though with the open T4 GTX3582R and was seeing 20 psi at 3170 rpm but I think I was at a higher boost setting, I'll have to confirm. It's pretty safe to say that with this turbo/manifold combo that I have a slight gain in spool over the the old set up. Now I just need to turn up the boost and get it on the Dyno to see if there has been a hp gain to justify that huge amount of work and expense. I'm kinda butt hurt from all the work I did on it all winter/spring and am running out of steam. There are a few little things left that need to be dealt with to bring it back up to DD standards. Hopefully I get some more time soon to attack them.
  2. #277
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    I would like to see the efr on an open manifold on our cars to see how much of a benefit the new steed is responsible for.
    If someone wants to donate an efr to me I will be test mule
  3. #278
    Sep 2008
    Toronto, ON
    6465 328ti
    Quote Originally Posted by rajicase View Post
    I have a .88 t4 open EFR9180 on a spa.
    I got plenty of logs. Maybe I'll upload later since I'm curious myself
  4. #279
    Manchester, N.H.
    96 332IS 6466 turbo
    I have no EFR and I'm getting the same spool. The manifold is pretty crazy.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  5. #280
    '97 M3
    The manifold definitely helps. The EFR size is big but the turbine is light making up for the size difference if they are spooling the same.
    Brand Turbo Comp Ind Comp Exd Comp Trim Turb Ind Turb Exd Turb Trim Flow
    BorgWarner EFR 9180 67.7 91 55 80 74 86 94
    Precision PTE 6466 G2 64.4 86.6 55 74.2 66 79 90
    Garrett GTX 3582R 62.5 82.5 57 68 62.2 84 75
    Note: If viewing in the app, tap on the post and this will all make more sense.
  6. #281
    Sep 2008
    Toronto, ON
    6465 328ti
    Went through my logs, nothing really worth comparing...
    Guess I'll just go out and log some.
    4th gear test and I'll stomp on it at 2k and see how it builds
    Targeting 20-22psi
  7. #282
    Bellingham, WA
    e30
    Really cool to see some test results. I agree it would be interesting to come TS steed to open T4 with similar setups to see which item is the golden ticket. Also compare to Garrett and Precision to see if its the turbo or the mani or its all the same
    -Nick
    91 E30 M42 on VEMS
    Turbo Camshaft Thread
  8. #283
    May 2003
    Irvine
    95 M3, 03 E55, 07 335I
    Nice spool, will do a 5th gear pull today to compare.
    You are running a .92 turbine housing? Big difference with my 1.06...
    Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
    New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
  9. #284
    '97 M3
    Yes, .92 IWG divided.
  10. #285
    May 2003
    Irvine
    No laughs here, I see 6 PSI around 3k ... dont get to see full boost until 3600/3800 at low boost and appears 3800/4000k at high boost based on the logs?
    Looking back at CES 1.06 they see 10PSI with this housing at 3500, I see the same as them.
    I do have to say that at 21PSI this car is scary fast and makes me feel like a chicken, I have no traction in 2nd, 3rd and while doing the first fe pulls lost traction around 4k while a 4th gear pull, Im not kidding when I say is scary fast and never been like this before.
    I do see a 4PSI boost creep.
  11. #286
    '97 M3
    I don't like your turbo my friend.
  12. #287
    May 2003
    Irvine
    Quote Originally Posted by chikinhed View Post
    Im deciding either
    A- Spend $400 and go T3 divided .82 ar with a T3/T4 adapter and keep the same turbo
    B- Buy a turbo like the one you have.
  13. #288
    '97 M3
    Quote Originally Posted by Matutino View Post
    Im deciding either A- Spend $400 and go T3 divided .82 ar with a T3/T4 adapter and keep the same turbo B- Buy a turbo like the one you have.
    Hold off until I get it on the dyno. It's a lot of work to change turbos and I'd like to see what the actual gains are.
  14. #289
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    There better be gains going from a 62mm to a 66mm compressor and big jump in turbine. I would think you would add 10% or more to the 660 rwhp you got with gtx3582r at the same 25psi.
  15. #290
    Manchester, N.H.
    96 332IS 6466 turbo
    Wasn't john breaking like 500 TQ at 3200 or something crazy with the gtx. I think he was making more than 10 psi at 3500
    1996 332IS
    Built 3.2
  16. #291
    Jun 2005
    New England
    He did hit 500 lbs at about 3200 with the Efr8374, with a race gas tune. Maybe close to that with the box. He had 1.05 and 1.06 housings.
  17. #292
    Manchester, N.H.
    96 332IS 6466 turbo
    Looking at the graph I posted, both the gtx and the EFR hit 20+# before 3500 rpm. The EFR smoking the Garrett tho.
    1996 332IS
    Built 3.2
  18. #293
    May 2003
    Irvine
    GTX on race fuel vs a GT on 91, apples to oranges to compare.
    On their last GT35 with 1.06 housing hit 10psi at or about 3500 rpm
  19. #294
    Jun 2005
    New England
    Wouldn't a 10 psi wastegate spring open at maybe 6 psi, delaying response? It supposed to give 10 psi though that varies in the real world and it looks like there are a few psi creep, which seems to be common with this twinscroll manifold and a twinscroll turbo.
    I'd be more interested in a test with the WG spring being held closed. Like setting the boost controller for 25 psi and testing response to 20 psi. It seems like turbos sometimes respond better the faster they are spun.
  20. #295
    May 2003
    Irvine
    When they used the eboost at the Dyno they saw 10psi at or around 3300rpm which would make sense as I have the upgraded wheel to flow more thus lower spool and bigger cams that moves the power band to the right, my guess is that those 2 explain the 300rpm difference hitting 10psi
  21. #296
    '97 M3
    My open T4 GTX3582R hit 10 psi at 3100 rpm on the Dyno.
  22. #297
    May 2003
    Irvine
    Make sense, GTX with .82ar and smaller compressor wheel than what I have
  23. #298
    Aug 2012
    CT
    Twin turbo LS E36 M3
    Im sorry, im probably way wrong but i cant see these turbos spooling this fast on an inertia type dynojet. Where are the RPM pick ups? Coming off the actual engine or is it wheel speed? I mean all the graphs posted are showing 5 psi at 2500rpm.
    Thats more then i can make on antilag at 2500rpm.
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
  24. #299
    '97 M3
    RPM is taken from coil wire.
  25. #300
    Jun 2005
    New England
    Quote Originally Posted by dburt86 View Post
    I don't have any fancy logging equipment. If I cruise at 2000 rpm in 4th, floor it and lift at 3000, the peak hold on my eboost2 shows about 18 psi. I did not look to see what I was making at 2500, but I am making positive boost pressure by then.
  1. My mini build thread for the 98iL
    By dburt86 in forum 1995 - 2001 (E38)
    Last Post: 05-04-2014, 01:30 AM
  2. Glove Box Power Ports Mini Build Thread
    By DrJomamachubby in forum 1988 - 1996 (E34)
    Last Post: 10-04-2011, 05:53 PM
  3. Almost there... Mini Build
    By onasled in forum Track Car Builds
    Last Post: 12-29-2010, 10:15 AM
  4. BMW/Mini builds great cars...in a crash
    By Fripp64 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-15-2010, 05:02 PM
  5. Mini build
    By rbodor3 in forum MINI (Cooper & Cooper S)
    Last Post: 07-17-2009, 03:40 PM
