Page 10 of 34 FirstFirst 1234567891011121314151617181920 ... LastLast
Results 226 to 250 of 832
Thread: Chikinhed's Mini Build
  1. #226
    Oct 2005
    Northern California
    95 M3, 15 Golf TDI wagon
    ^^I thought those were all NLA?
    -WTB: OEM Class 2 LTW GT wing with risers- Mazak
  2. #227
    Vancouver, B.C., Canada
    '97 M3
    Quote Originally Posted by 3literheater View Post
    That would suck, let's hope not.
  3. #228
    Oct 2005
    Northern California
    Well I have looked on their website several times and it always says not available.
  4. #229
    '97 M3
    We should work on that. There seem to be a steady flow of people that are interested in purchasing the openOBCs and as more and more options get figured out on these, more and more people will want them.
  5. #230
    Oct 2005
    Northern California
    I think its pretty cool, but I have a day job and that thread is way too long to read haha.
    I don't have the time to read through it and figure it out.
    Pretty cool that you did though.
  6. #231
    '97 M3
    You don't have to read through the whole thread. There is some key info in there but it's in the last ten pages probably. There is an Idiots Guide to programming it and a Wiki. The code revisions can be had at Github and random people have modified the code and are more than willing to share what they have done.
  7. #232
    '97 M3
    Not much time for progress but I got the hot pipe made and x-brace installed last night.
    Ya, I know, it's dirty under there. I'm working my way forward.
  8. #233
    How close is that to the sway bar? It looks like its hitting.
  9. #234
    '97 M3
    Quote Originally Posted by White94RX View Post
    It's close, 5/16 or more away. My intent was to keep it tight for ground clearance.
  10. #235
    As long as they don't hit each other, I guess all is well!
  11. #236
    Mar 2012
    Renton, Wa
    98 m3
    It would flex away under load anyway.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  12. #237
    '97 M3
    I got distracted from working on my car after picking up some pussy......
    8 week old Maine Coon with 24 toes.
  13. #238
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Quote Originally Posted by chikinhed View Post
    Maine coons are pretty bad ass pussies. Got a buddy with one. Got a name ?
  14. #239
    '97 M3
    Quote Originally Posted by rajicase View Post
    No name yet. I'm taking suggestions.
    My daughter doesn't know she has a kitten yet, she is away until tomorrow. She is going to freak out when she sees him.
  15. #240
    May 2003
    Irvine
    95 M3, 03 E55, 07 335I
    I vote for "chikinhed" !!
    Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
    New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
  16. #241
    Bellingham, WA
    e30
    Your daughter is going to love the cat!!
    -Nick
    91 E30 M42 on VEMS
    Turbo Camshaft Thread
  17. #242
    Phoenix,AZ
    99' 323is, 99' 328is
    Thanks for the offer. Let's wait to see the CES offering first.
    How about post the same so we can all make our own?
    She's built like a steakhouse but handles like a bistro
  18. #243
    '97 M3
    Quote Originally Posted by JimsR View Post
    I actually wanted to try the mount arm/poly mount combo first before doing so, just incase I find an issue with it.
    I'm getting close to finishing (more like at my wits end with all this awesome weather). My list of things to do is still huge but I'm just trying to complete everything that requires it to be on stands before insuring it for the season.
    I'm down to this:
    -Install water cooling for front brakes
    -Repair LH brake duct
    -Replace steering guibo with u-joint
    -Attach rear ABS wiring to control arms
    -Make air deflectors for rear brakes
    -Adjust rear spring heights for new arms
  19. #244
    Ship, Pa
    Red Sled, RC51
    Water cooled front brakes?
    Sent from my SM-N920V using Tapatalk
    "Believe nothing you hear, half of what you read"
  20. #245
    '97 M3
    13 psi is pretty good but I've been driving a Sienna.
  21. #246
    '97 M3
    20 psi is also pretty good.
  22. #247
    '97 M3
    23 psi pretty good not too bad. Star specs are not happy in fourth.
    The NT-01's will have to be installed soon.
    I just replaced the twin disc and it's not fully disengaging when I step on the clutch making it hard to get in gear. I've got an exhaust leak at the center muffler somehow. My fuel pressure was higher from the new Walbro I guess.
    It's nice to be back in the seat. That thing is not like normal cars.
    I just looked at the datalogs and it appears I was only getting 70% TPS. It was looking like I was getting 20 psi by 3400 rpm but will require more datalogging to confirm.
  23. #248
    '97 M3
    I physically checked the position of the throttle butterfly and it was wide open. I swapped in a different TPS and we will see how that works.
  24. #249
    Mar 2012
    Renton, Wa
    98 m3
    Its always something isnt it? I was driving my car yesterday and i feel like something is wrong with the fpr... and im sure ill go through a diff after i fix that.. then a trans..
    1989 535i - sold
  25. #250
    May 2003
    Irvine
    What gear 20psi at 3400rpm?
  1. My mini build thread for the 98iL
    By dburt86 in forum 1995 - 2001 (E38)
    Last Post: 05-04-2014, 01:30 AM
  2. Glove Box Power Ports Mini Build Thread
    By DrJomamachubby in forum 1988 - 1996 (E34)
    Last Post: 10-04-2011, 05:53 PM
  3. Almost there... Mini Build
    By onasled in forum Track Car Builds
    Last Post: 12-29-2010, 10:15 AM
  4. BMW/Mini builds great cars...in a crash
    By Fripp64 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-15-2010, 05:02 PM
  5. Mini build
    By rbodor3 in forum MINI (Cooper & Cooper S)
    Last Post: 07-17-2009, 03:40 PM
