Page 14 of 34 FirstFirst ... 456789101112131415161718192021222324 ... LastLast
Results 326 to 350 of 827
Thread: Chikinhed's Mini Build
  1. #326
    Manchester, N.H.
    96 332IS 6466 turbo
    I turned the boost to what should be 28-29 psi and the max boost is still only 21-22 psi. I either have a big boost leak or the Turbosmart waste gates are being pushed open with 14 psi springs. The boost is also tapering off from 22 down to 19 psi.
    Post how you have the WG line routing. The TS IWG lines are should be reverse from normal
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  2. #327
    Vancouver, B.C., Canada
    '97 M3
    Having the IWG hoses routed backwards would give me some weird inverted boost creep thing going on.
    Psst, Butters, update your signature.
  3. #328
    '97 M3
    I double checked my WG routing. At first I thought I had the EWG hooked up backwards but caught myself. Both WG's are hooked up per the drawings. Next will be a boost leak check.
  4. #329
    Aug 2012
    CT
    Twin turbo LS E36 M3
    hook the boost source to the IWG and see if it hits target
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
  5. #330
    '97 M3
    With the boot controller off I am getting 14 psi which is what each WG has for springs. It's acting like I have too weak of a spring in the WG and its being pushed open.
    Another issue is that my EGT is higher (1700F vs 1620F) than it was with the GTX3582R . I did remove the pre compressor WI nozzle but it was only a 0.3. I doubt that would have that big of an affect on the EGT's but I might be wrong. I may have to retard the exhaust cam a bit to bring the EGT back down.
  6. #331
    Apr 2006
    Minnesota eh?
    86 325es
    Is it pulling timing due to not having the meth? retarding the timing with increase the EGT
  7. #332
    '97 M3
    It's possible but the 0.3 nozzle hardly affects the mixture or IAT.
  8. #333
    '97 M3
    After being at 22 psi for awhile, going back to 13 psi is lame. I don't recommend it.
  9. #334
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Low boost is for the birds.
  10. #335
    '97 M3
    Quote Originally Posted by rajicase View Post
    There are some that "only want 350-400 whp". I don't get it.
  11. #336
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Is your boost refrence on the turbo or on the intake manifold?
  12. #337
    '97 M3
    Quote Originally Posted by E36 HateR View Post
    Boost reference for the boost controller and WGs is on the turbo. Boost gauge and BOV reference is on the IM.
  13. #338
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Ive seen a few setups where moving the reference to the IM eliminates the boost drop and boost spike.
    It may help.
  14. #339
    '97 M3
    Ive seen a few setups where moving the reference to the IM eliminates the boost drop and boost spike. It may help.
    I can see how it would if I had a restriction in my system giving me a pressure differential across the Intercooler or piping. If anything I have improved the piping on the new set up. I'll try to find some time today to boost leak check it. I'm also having wonky AFR readings to the point that I've had to turn the boost down. I really want to nail this issue down so I can crank the boost up and see what she can do with the 'big turbo'.
  15. #340
    May 2003
    Irvine
    95 M3, 03 E55, 07 335I
    Your afrs where really rich, thenlog showed 10 to 9.
    Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
    New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
  16. #341
    '97 M3
    Quote Originally Posted by Matutino View Post
    Then I did a pull a couple of days ago and it was in the 12's. It's all over the place.
  17. #342
    '97 M3
    I must have been tired when I did my fuel pressure adjustment setting it at 51 psi at idle with the vacuum line still attached. Too many late nights.
    I've adjusted it and reset adaptations.
    Edit. I wasn't tired. The little gauge at the FPR is reading 10 psi higher that the Zeitronix. No I have to try to confirm which one is correct.
  18. #343
    May 2003
    Irvine
    What is your procedure to set up fuel pressure
  19. #344
    '97 M3
    I disconnect and plug the FPR vacuum line, idle the engine, adjust to 51 psi on the gauge and verify the pressure through the Zeitronix. After the winter maintenance I noticed the reading on the FPR gauge was high so I had turned it down to read 51 psi again. I did replace one of my fuel pumps and though that it may have affected the pressure but maybe the gauge is messed up.
  20. #345
    '97 M3
    I did more data logging. I was seeing 25 psi briefly and then it was dropping back down to 20 psi as the rpm climbs. The AFR's hit bottom at wot at 9,6 afr. Maybe the Zeitronics pressure transducer is wrong. I'll need to confirm what the issue is.
  21. #346
    Bellingham, WA
    e30
    I hate the "which data source is correct" game
    -Nick
    91 E30 M42 on VEMS
    Turbo Camshaft Thread
  22. #347
    Aug 2012
    CT
    sounds like over shoot from the controller. Can you adjust any of the PID settings in it?
  23. #348
    '97 M3
    Quote Originally Posted by dburt86 View Post
    The AMS-500 is a simple controller. The only adjustments are boost above spring WG spring pressure and rate of boost increase. It seems to me that I can get close to target boost if I haven't put any heat into it as the boost drops shorty after and it stays low if I go wot again shortly after. My gut is telling me to try more preload on the IWG actuator.
  24. #349
    '97 M3
    Based on my Datalog last night with the idle fuel pressure set to 51 psi according to the Zeitronix I was getting <9.6 AFRs at WOT.
    This morning I set it to 51 psi on the gauge and get 12.0 AFRs at WOT.
    The Zeitronix fuel pressure plot had a lot of noise, not a smooth line.
    Another thing I noticed while logging with BMWlogger (OBD2 data) was that the battery voltage was not stable. It was swinging between 13.2 and 13.9 volts. The openOBC is only showing a swing from 13.7-13.9 volts......
  25. #350
    Toronto, Canada
    E36 Turbo
    The voltage for a power pull doesn't seem problematic to me, and you're within a common range. Just my 2 cents.
    E36 DYNO TUNING WIRING PARTS
  1. My mini build thread for the 98iL
    By dburt86 in forum 1995 - 2001 (E38)
    Last Post: 05-04-2014, 01:30 AM
  2. Glove Box Power Ports Mini Build Thread
    By DrJomamachubby in forum 1988 - 1996 (E34)
    Last Post: 10-04-2011, 05:53 PM
  3. Almost there... Mini Build
    By onasled in forum Track Car Builds
    Last Post: 12-29-2010, 10:15 AM
  4. BMW/Mini builds great cars...in a crash
    By Fripp64 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-15-2010, 05:02 PM
  5. Mini build
    By rbodor3 in forum MINI (Cooper & Cooper S)
    Last Post: 07-17-2009, 03:40 PM
