Page 27 of 34 FirstFirst ... 2171819202122232425262728293031323334 LastLast
Results 651 to 675 of 832
Thread: Chikinhed's Mini Build
  1. #651
    Vancouver, B.C., Canada
    '97 M3
    “Five days” says the machine shop. Grumble, grumble grumble. It’s been over a month now. Maybe they mean five days when they eventually start on it?
  2. #652
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Hmmm maybe
  3. #653
    Apr 2006
    Minnesota eh?
    86 325es
    For most places it seams that 5 days means it will be done in 5 days 2 years from now.
  4. #654
    '97 M3
    I guess I’m doing ok then. The engine shop will be done tomorrow but the head won’t be done until next week. I managed to slice the palm of my hand open so my hand is off line for a week or so until it heals and get the stitches out.
    Phil, my hand damage will slow the S54 oil pump mods. I just need to make a fixture to mount to the milling machine but I can’t even hold a pen right now..
  5. #655
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    It pains me to see that hand. I am in absolutely no rush on the oil pump — could be months before I get bored enough to even think about changing the pan and pump.
  6. #656
    Vancouver, BC Ca
    1993 325is
    I managed to slice the palm of my hand open.
    As if you needed any more delays in getting stuff done. That royally sucks. Well, those can can, do. Those that can't, teach! ;p
  7. #657
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    LOL
    At least he's smiling.
  8. #658
    '97 M3
    I have all my engine parts back except the oil pumps. The head looks good. My head guy posted up some pics on his Facebook page.....
    https://m.facebook.com/story.php?sto...00009637093303
  9. #659
    '97 M3
    My hand has healed enough that I could lift the engine parts. Yay! So I got a bit done on it. Coolant passages at #6 cylinder have been cleaned up with die grinder, block masked and painted, new frost plugs installed, all rings file fitted, new piston oilers installed, ARP main studs, bearings and crank installed for checking main bearing clearances. Some how the little baggy with six piston pin circlips has gone missing so that’s going to be a show stopper until I can get more
  10. #660
    Jan 2019
    Connecticut
    E92, E46, E36
    I was reading through and I saw the talk of using e46 fenders to modify the body, I'd be interested to see how that looks when its done
    Sent from my SM-G960U using Tapatalk
  11. #661
    Oct 2005
    Northern California
    95 M3, 15 Golf TDI wagon
    Looks awesome!
    This is a 2.8 right?
    -WTB: OEM Class 2 LTW GT wing with risers- Mazak
  12. #662
    Vancouver, BC Ca
    1993 325is
    The block is from an M52B28, but I think it's getting all 3.2 guts.
    You made my old block look WAAYYY too pretty. I liked it better when it was all rusty and greasy/oily!!
  13. #663
    '97 M3
    Yes, 3.2L, 87 mm 8.5:1 CP pistons, Eagle rods, S52 crank.
    The block got hot tanked and media blasted. Not a speck of rust left on it anywhere. It was actually kind of pricey but the results were nice. No prep required before painting essentially.
    The engine shop didn’t have the missing circlips so I’ve ordered some along with some fancy Vibra-Techniques engine mounts. I want this thing back in the car so bad and can’t wait to smell that fresh engine smell on first start up.
  14. #664
    '97 M3
    I found an old dyno run from a few years ago showing turbo vs super charger vs built NA. This explains why I like turbos.
  15. #665
    Vancouver, BC Ca
    1993 325is
    Ya, ya, ya... I'm working on that!
  16. #666
    '97 M3
    It wasn’t a dig at you personally, more of a dig at people that say they like the smooth, cough non existent cough, power band of NA or supercharger.
  17. #667
    Vancouver, BC Ca
    1993 325is
    HEY! I ran a 13 flat with my NA power!!!
  18. #668
    NY
    skateboard
    Here is my analysis on this graph. With each increase in power sadness is increased as well exponentially. “Weep not over my words”.
    ― George Orwell
  19. #669
    Vancouver, BC Ca
    1993 325is
    Quote Originally Posted by GG///M3 View Post
    There was a moderately significant amount of sadness in my case. Clearly not as much as Brad though!
  20. #670
    Jun 2005
    New England
    I’d rather go fast with some sadness than slowly. I have been spreading my sadness out over the past 14 years so the average is ok.
  21. #671
    NY
    skateboard
    ― George Orwell
  22. #672
    Apr 2006
    Minnesota eh?
    86 325es
    The awesomeness makes it worth it 100,042%
  23. #673
    '97 M3
    I’ve had NA engines window the block, I’ve had super chargers poop the bed and crack heads, a little ‘winter maintenance’ on the turbo engine does not make me sad knowing I’ll end up with even more power and that awesome smell of a fresh engine on the first start...... You smell that? Do you smell that?... That’s a fresh engine, son. Nothing else in the world smells like that. I love the smell of a fresh engine starting in the early morning. The smell, you know that smell, the whole garage. Smells like... victory. Someday this car's gonna start...
  24. #674
    Vancouver, BC Ca
    1993 325is
    You mean the fresh smell of engine oil all over the engine bay and the bottom of the car, right?
  25. #675
    Bellingham, WA
    e30
    Brad, can you bottle some of that smell up and send it my way? I forgot what it smells like!
    The amount of smiles per km (mile) your car has given you is worth the small phases of sadness!
  1. My mini build thread for the 98iL
    By dburt86 in forum 1995 - 2001 (E38)
    Last Post: 05-04-2014, 01:30 AM
  2. Glove Box Power Ports Mini Build Thread
    By DrJomamachubby in forum 1988 - 1996 (E34)
    Last Post: 10-04-2011, 05:53 PM
  3. Almost there... Mini Build
    By onasled in forum Track Car Builds
    Last Post: 12-29-2010, 10:15 AM
  4. BMW/Mini builds great cars...in a crash
    By Fripp64 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-15-2010, 05:02 PM
  5. Mini build
    By rbodor3 in forum MINI (Cooper & Cooper S)
    Last Post: 07-17-2009, 03:40 PM
