Page 11 of 34 FirstFirst ... 23456789101112131415161718192021 ... LastLast
Results 251 to 275 of 832
Thread: Chikinhed's Mini Build
  1. #251
    Vancouver, B.C., Canada
    '97 M3
    Quote Originally Posted by Matutino View Post
    What gear 20psi at 3400rpm?
    4th
    I was actually having a hard time figuring out what gear I was in because it behaves differently than the old set up.
  2. #252
    '97 M3
    The clutch is fixed, commence beating.
  3. #253
    May 2003
    Irvine
    95 M3, 03 E55, 07 335I
    Need some data logs and feedback
    Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
    New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
  4. #254
    '97 M3
    I fixed the TPS issue. I still get hop in the wet, I'll try it out in the dry soon hopefully. I don't feel like there has been any compromises in performance just access to a whole bunch more power going from the open T4 GTX3582R to the divided EFR 9180.
  5. #255
    Mar 2012
    Renton, Wa
    98 m3
    Have you thought about softer springs in the rear?
    Excited to hear your feelings on the efr vs the gtx!
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  6. #256
    New Westminster, B.C.
    1994 840ci,'97 M3
    Quote Originally Posted by vollosso View Post
    Brad i got a set of softer springs if you wanna try em...
  7. #257
    '97 M3
    I don't want to compromise the HPDE and autoX for drag capability. I gots my priorities.
  8. #258
    Manchester, N.H.
    96 332IS 6466 turbo
    Speaking proper English ain't one of dem ?
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  9. #259
    '97 M3
    Quote Originally Posted by Butters Stoch View Post
    You didn't catch my accent in that?
  10. #260
    Manchester, N.H.
    96 332IS 6466 turbo
    Did-ja catch mine ?
    1996 332IS
    Built 3.2
  11. #261
    Bellingham, WA
    e30
    That says a lot right there!
    -Nick
    91 E30 M42 on VEMS
    Turbo Camshaft Thread
  12. #262
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by wazzu70 View Post
    The steed V2 is VERY impressive. I'm getting crazy spool with a 900hp turbo. Spooling like a gt35r, maybe better.
    1996 332IS
    Built 3.2
  13. #263
    '97 M3
    We still need a bit more tweaking with the code but we have a guy on the job. I'm donating a flex fuel sensor to forum member Xoboof so that we can get it dialed in. The ethanol is reading about 30% high and the temp needs the decimal point moved to the left one spot......
  14. #264
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    271°c sounds like a safe operating temp XD
  15. #265
    '97 M3
    I was at 13 psi this morning, no creep. The roads were a bit damp and traction was an issue with the NT-01's. This afternoon I turned it up to 23 psi in the dry with OAT of 70°F and its pulling pretty hard but traction is definitely an issue in the lower gears. I'd like to sneak it up to 24-25 psi and see if it's still happy.
  16. #266
    '97 M3
    Quote Originally Posted by rajicase View Post
    Ya, that better not be the actual temp of the fuel in the return line.
  17. #267
    May 2003
    Irvine
    I did a pull at 19PSI in 3rd gear and had no traction whatsoever, I soiled my pants and came back home... this is after adding 3 gallons of E85 to equal a full tank.
  18. #268
    Feb 2012
    1995 BMW M3
    No imagine adding 18 gallons of e85 to equal a full tank
  19. #269
    '97 M3
    You should all come to a Dyno Day I'm trying to organize up here in Vancouver.
  20. #270
    Bellingham, WA
    e30
    Brad, make sure to post the dyno day. I would love to come hang out. Might be able to get a friend to bring an E92M3 to fill a car slot too
    -Nick
    91 E30 M42 on VEMS
  21. #271
    Manchester, N.H.
    96 332IS 6466 turbo
    On my way.
    1996 332IS
    Built 3.2
  22. #272
    '97 M3
    Hey Matutino, check this datalog out. Fifth gear pull from 2000 rpm, boost controller set to about 21 psi...... Steed + EFR 9180 doin' work......
    Based on the logs on WG spring pressure of 13-14 psi, I am seeing up to 15 psi so there may be a bit of creep.
  23. #273
    Vancouver, BC Ca
    1993 325is
  24. #274
    Jul 2005
    PEI, Canada
    2001 330i
    If Cam was still around...there'd be a paragraph of expletives....
  25. #275
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    So 20 psi at 3100 in 5th? And this is with the eboost set to 21 with a gate pressure below that so the WGs have just opened? Makes it even better -- you can make the test look slightly better by setting your eboost Gate Pressure past the test boost level.
    Do the test in 4th. My turbo system and motor are similar to yours, and my rough testing from a 2000 rpm steady cruise in 4th, nailing it and lifting at 3000 and reading the eboost peak hold gave me 18 psi at 3000 in 4th. No fancy logging so its just a ballpark but I repeated it a few times and its in that range. This is with the eboost gate pressure set to give 19 psi peak boost so the wastegates are open several psi before I hit that 18 psi. To me, the 0.92 IWG EFR 9180 on twinscroll steedspeed feels a lot like the 0.82 GT3582R on open boostlogic in terms of response, but obviously makes more power. It is really a great combination. I am going to try to get to the dyno.
  1. My mini build thread for the 98iL
    By dburt86 in forum 1995 - 2001 (E38)
    Last Post: 05-04-2014, 01:30 AM
  2. Glove Box Power Ports Mini Build Thread
    By DrJomamachubby in forum 1988 - 1996 (E34)
    Last Post: 10-04-2011, 05:53 PM
  3. Almost there... Mini Build
    By onasled in forum Track Car Builds
    Last Post: 12-29-2010, 10:15 AM
  4. BMW/Mini builds great cars...in a crash
    By Fripp64 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-15-2010, 05:02 PM
  5. Mini build
    By rbodor3 in forum MINI (Cooper & Cooper S)
    Last Post: 07-17-2009, 03:40 PM
