Results 1 to 7 of 7
Thread: Reliability of mid run cars
    Dec 2007
    Mystic, CT
    2002, 320/6 Baur
    I have had an 04 645 convertible for an=bout 2 years. I purchased with about 70K miles and now it has 90K miles. The I Drive has been inconsistent about 5% of the time. It ate the first set of tires, transmission clunks occaissionally(maybe normal as this is the first bMW automatic I have had), and I have had to replace a headlight and repair top. I know that 2004 is first year. Did it get better a few years down the line like by 2006 or 2007?
    Jul 2016
    Chicago, Illinois
    are slow
    Service the transmission with a new filter and fluid. It's not normal to clunk.
    The main difference would be the improved valve stem seal design with the introduction of the 650, more agressive looks, and better iDrive (2009 to end of production). Overall, basically the same car.
    Dec 2013
    Chicagoland area
    EXOTICS
    Do as Xalt suggested, and service the trans. As for the eaten tires, check for worn suspension components, bushings, followed by a wheel alignment-set to less aggressive and more tire friendly specification #'s
    Dec 2007
    Mystic, CT
    2002, 320/6 Baur
    Thanks. I thought the transmission flush may be a good idea.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Dec 2013
    Chicagoland area
    EXOTICS
    Excellent websites, much info available, many thanks!
    Jul 2016
    Chicago, Illinois
    are slow
    Quote Originally Posted by lyonsfin View Post
    Don't flush, drain and fill + filter and related gaskets. Use the Ford fluid for the 6R80 or ZF Lifeguard6.
    Reset adaptations as said earlier, and you should see a change.
  1. *Rate The Reliablity of Your Car*
    By DarksideE36 in forum Forced Induction
    Last Post: 12-04-2008, 02:26 PM
  2. Replies: 18
    Last Post: 05-01-2007, 11:32 PM
  3. Need any kind of running car for < $400
    By TomC in forum Georgia sponsored by Harrison Motorsports
    Last Post: 03-15-2007, 07:38 PM
  4. The Joys of a used car, but good in the long run..
    By smulkeen in forum 1983 - 1991 (E30)
    Last Post: 12-22-2005, 04:49 PM
