Results 1 to 13 of 13
Thread: Plugging vacuum ports
    May 2015
    Chicago, IL,United States
    1977 BMW 320i
    Does anyone have any suggestions for a cleaner/more-permanent way to cap vacuum ports than a rubber cap with a hose clamp (or the classic piece-of-hose-with-a-golf-tee)? Specifically, there are a lot of unused connections on the 'log' portion of my pre-facelift intake manifold that I would like to improve and forever remove from the list of possible vacuum leaks. Most importantly, the large port that is on the bottom of the log and is inaccessible when the intake is in-place.
    I was thinking that if I could find appropriately-sized metal caps that I could solder or epoxy them in place, so they could theoretically be re-opened in the future. Or maybe I should just weld them up, the odds of me ever using those ports again is very small.
    Jun 2015
    San Antonio, Tx
    1977 320i
    You pull out the sleeve and then drill and tap the hole for a plug. There is an excellent thread on it, which I don't have the patience to find on my phone.
    May 2015
    1977 BMW 320i
    So those ports are threaded in? That is great news, I will see if I can remove those port connections without damaging the threads. Thanks!
    Update: Oh wait, I see that by "excellent thread" you mean a forum thread, not threads in the aluminum. But still, it should be easy enough to do.
    Feb 2009
    District Nine
    sold 78 BMW 320i
    Plugging the big EGR hose nipple on the bottom of the log was a thread started by Bimmerknut.
    For the small hose nipples on the log, just use vacuum caps that are color coordinated to your car
    Tbd
    May 2015
    1977 BMW 320i
    Vacuum caps color-coordinated to my Sierrabeige car? A good idea. I will use a pre-chewed wad of Wrigley's Gum, perfect color-match. Then I can blow bubbles out of the tailpipe!
    Feb 2009
    District Nine
    sold 78 BMW 320i
    There you go!
    Tbd
    Wichita Falls, Texas
    1997 BMW Z3 2.8
    I accidently discovered an open nipple on the bottom of my post face lift intake manifold. Plugging it up resulted in a huge improvement in the car's driveability. Have no idea of the original purpose of the nipple, if any.
    Tacoma, WA USA
    '78 320is 83 320i R.I.P.
    Oh SNAP!!! German Engineering is IN DA HAUS YAH!!!
    May 2015
    1977 BMW 320i
    Thanks for posting the link! I had tried searching for the thread earlier, but didn't find it. This will be one of my weekend projects.
    May 2015
    1977 BMW 320i
    I am still waiting for the 5/8" tap to arrive, but I did do the smaller ports with a 1/4" tap. Just to be sure that it is sealed, I put RTV on the upper bolt threads. Looks much better than the caps-with-clamps that I had on there before!
    Oct 2016
    Santa Monica
    1981 BMW 320i
    Quote Originally Posted by John Adkins View Post
    Which nipple are you referring to?
    Nov 2020
    Magnolia, TX, USA
    1982 BMW 320i
    Perhaps referring to #9 on the attached real oEM image?
    When I purchased my e21 a couple of years ago it would barely stay running when they rolled it off the delivery truck. It started and ran very smooth other than trying to stall if you didn’t keep your foot tapping on the accelerator.
    I opened the hood and started looking for vacuum leaks, and just stumbled across a cracked plug under the intake manifold. I couldn’t see under the manifold, so I plugged it with my finger and it ran perfect.
    I got a new/similar plug at the hardware store and haven’t had an issue since. Think mine is red, or it was when I pulled it off.
    Jul 2020
    Kansas City, MO
    1986 BMW E30 325
    Just a side question, if you remove a vacuum cap from the intake manifold, and the cap is filled with oil, what can that be a sign of? Excessive blowby?
    80 320i / 82 320i / 85 735i / 86 325
  1. vacuum ports on brake booster
    By bmmrr in forum Forced Induction
    Last Post: 03-17-2010, 09:31 AM
  2. 318is Cap off vacuum port on injector?
    By fast84gti in forum 1991 - 1999 (E36)
    Last Post: 02-26-2009, 01:14 PM
  3. Open Vacuum Port
    By ldarmoore in forum 1975 - 1983 (E21)
    Last Post: 09-14-2007, 01:02 PM
  4. Vacuum Port on Intake Manifold
    By Microsa1 in forum 1976 - 1989 (E24)
    Last Post: 04-14-2007, 09:28 PM
  5. Vacuum ports on Tial 38mm
    By 5mall5nail5 in forum Forced Induction
    Last Post: 06-12-2006, 09:47 PM
