Results 1 to 5 of 5
Thread: 24# fuel injectors
    Amityville,, New York
    1989 325 m50 shrick cams
    Post 24# fuel injectors
    I have a 95 325is m50 engine worked out with bigger light weight pistons, double valve springs with titanium retainers, aluminum flywheel with m3 clutch, headers, and i am putting a set of shrick cams and a chip,
    Do you guys think that putting the M3 24Lb injectors will be fine ??
    P.S : The only reazon I dint build an M3 engine is cuz i had 2 m50 engines
    Jul 2004
    Houston, TX
    36 Cylinders
    Just make sure the tune is adjusted for that injector size, thats all.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    That's what i figured, Thanks
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I would use an S52 or M54 3.0L crank, not just bore for bigger pistons. Go for 3.0 or 3.2L. 24 lb injectors are probably fine but if you are buying a tune it probably specifies the injectors and hfm to use. 24 should be fine.
    Thank u
  1. 24# Fuel Injectors? What chip???
    By 95M3theo in forum 1992 - 1999 M3 (E36)
    Last Post: 01-04-2007, 04:30 AM
  2. 24# fuel injectors
    By Bav///Man in forum 1992 - 1999 M3 (E36)
    Last Post: 05-21-2005, 12:19 AM
  3. 24 # Fuel Injectors
    By themadhatter in forum BMW Parts For Sale
    Last Post: 01-18-2005, 08:43 PM
  4. 24# fuel injectors
    By chas in forum 1992 - 1999 M3 (E36)
    Last Post: 03-04-2004, 01:37 AM
  5. FS--24# fuel injectors for euro HFM
    By back_in_black in forum BMW Parts For Sale
    Last Post: 05-21-2003, 09:13 PM
