I have my door panels apart. Many of the clips have come un-glued, and I peeled off the foam insulation. What is a good glue for putting those clips back on? And what should I use for the foam backing? I need something that's good for -40 to +40 Celsius.
The contoured black plastic bits around the edge that retain the clips? Some say Gorilla glue, I like epoxy which sets faster and is less mess.
The center insert has thin foam padding that disintegrates over time so I'm guessing that is what you mean. I have used a cotton(?) batting, I think it's called that, I purchased at a fabric and crafts store. It's about the same thickness as the foam, gives a slight cushion and won't disintegrate in my lifetime. Contact cement for re-attaching the covering.
I have had great success using gorilla glue.
I've had great success redoing previously gorilla glued ones with epoxy.
What epoxy?
I didn't think Gorilla Glue would be OK for temperature extremes like that - they don't mention anything on their website about it. Will it be OK? I only want to do this once...
I use 3M's window weld fast drying urethane adhesive. It sets quickly and has excellent properties against temperature extremes.
I haven't had a door panel repair come back when used in conjunction with new door panel clips.
I tried epoxy and the first time I pulled the panel back off, most of the plugs stayed in the door. Next time I will try Gorilla glue.
Epoxy for the clip holders. The longer set time, generally the stronger hold. I have used 30 min. With great success. However, for best results, let the reattached parts sit overnight at room temperature.
Glue for covers: Weldwood Landau Top Adhesive. It's got excellent heat resistance.
Padding: batting, as already noted, would be excellent. I would think it could shift and bunch up if not well attached on both sides (trim material and card backing).
I used liquid nails. It's held up great.
for the foam backed leatherette I have switched to HH-66 Vinyl cement with good results.
Technical Data:
Base: Thermoplasticelastomer
Color: Clear
Solvent: MEK-Toluene-Acetone Blend
Viscosity:Medium, 1100-1300 cps.
Application:Brush or Roller
Solids: 15% ħ 1% (Approximately)
Net Weight:8 Lbs. (Approximately)
Temperature Range: -30° to 180°F.
Tack Life: 2 5 minutes
Shelf Life:18 months or longer
Flash Point: 22° F.
'Sweetness Tres' M44, 1.9L Z3 5-Speed Roadster '97 Boston Green 66K Smiles Mine
'Sweetness Too' M52, 2.5L Z3 5-Speed Roadster, '00 Jet Black 165K Smiles 2022 Gone Ins Co Total in Jan 2022- Right Front Collision - Paid $8850 !!
'Ol' Black Betty' S52, 3.2L ///M3 5-Speed Vert '98 Cosmos Black 265K Smiles Wifeys
M50, 2.5L 525i E34 Tragi-matic '95 Sedan Alpine White III 238K Smiles Was Daughters Mine Again
'Gretchen' M30, 3.5L 535i E34 Tragi-matic '90 Sedan Glacier Blue/Indigo 144K Smiles 2018 Gone & I miss her
'Sweetness' M44, 1.9L Z3 5-Speed Roadster '96 Boston Green 264K Smiles Was Mine Ins Co Total in Jan 2013- Rear End Collision - Paid $4800 !!
Having something that has a little give to it is probably a good idea as well seeing as you will get a fair share of movement and shock when opening and closing the door. Also be sure to do good prep work and follow the adhesive manufacturer's instructions for application of the adhesive. I have seen a bunch of adhesive failures on brand new cars when I worked in automotive. Failures from the manufacturer which were then resolved by proper application of the materials used. All food for thought.
Photobucket sucks!
Long live the E34!
use thin head screws and put them through the card board AND the door. Those will hold the weight of the actually panel. Then use whatever glue everyone has recommended. I've used 3M adhesive only for it to all come apart in a Florida summer. 3/10 would not recommend.
'89 535i/5 Holset WH1E turbo
Follow my m106 megasquirt build thread here
Follow my R75/6 build here. Youtube - Dispatch Moto
I redid all the clips and reattached some of the vinyl materials as well. Both were done with Gorilla glue and have worked perfectly. I have even taken off the panels since and all of the plastic parts stay attached as they should.
Just saw this today at local fabric store: Performance Products High Temp Adhesive https://www.wsusol.com/p-46-adhesive...-can-each.aspx
Shop owner says he has lots of happy automotive and commercial applications customers.
Also, for padding of door cards the shop sells Flex-Form. It looks perfect for this application, and if I were embarking on the project myself, this is what I would use. If you can't find it call Fabrics Unlimited in Charlottesville, VA 434-973-5641. Ask for Andy. He sells the spray adhesive, too.
I ended up using JB-Weld brand "Plastic Weld" for the clips. I just glued them to the original glue, which was still there. I guess in a few years I'll know how good it was!
For holding the foam pieces to the door, I bought a roll of butyl rubber tape. Haven't used it yet.
