Results 1 to 7 of 7
Thread: Problem with replacement E90 Cluster
    san diego, CA USA
    2007 328i, 1996 319 Ti
    Hello,
    I have a question regarding my 2007 BMW 328i's instrument cluster. I replaced it with a used one due to some malfunctions on the original one. Everything works fine on the replacement and the mileage reads correctly (with the exception of the dot), but the thing is that the Service Intervals do not seem to work, they are all displayed in an amber color as and there is no mileage or dates on them they just have "------" in their place and they display "km" beside it....which is weird because everything else is in miles. Is there something I need to "code" or "reset"? The red service warning always pops up when I start and turn off the car.....kind of annoying now
    Thanks a million!!
    Bryan Miranda
    Sep 2003
    Birmingham, UK
    BMW 850 and E55 AMG
    They'll sync up only if the cluster VIN matches the rest of the car.
    There's a possibility to that when the VIN is changed in the cluster, the mileage might go up to the cluster mileage which could be higher than what you are seeing (from the CAS Milage)
    Giftschrank Projekt
    Dec 2012
    North Carolina
    2009 335i M-Sport Coupe
    Instrument cluster swaps require replacing or reprogramming the EEPROM chip with a hex editor. If the cluster had lower mileage than the car, you just need to erase the vin from the EEPROM, then use NCS Expert to code the cluster. Unfortunately getting at the EEPROM requires opening the cluster and removing the needles. At a minimum you will need a chip programmer ($40), and a K+DCAN cable ($20). The other option would be to desolder the EEPROM chip from the old cluster and solder it into the new one, or pay a local electronics shop to do it. You'll need software and the K+DCAN cable to get the needles back on right, and to do the coding. I'm happy to answer any question, or point you towards more detailed information.
    san diego, CA USA
    Thanks for the response!!
    I think at this point I'd probably buy a chip and solder it on. I'm a bit curious to try the editing software but it might be quicker to use a new chip. How much do they cost? Whats it called and where can I get it? Thanks a lot!
    Bryan
    Quote Originally Posted by RocketSurgeon View Post
    Jul 2004
    Houston, TX
    36 Cylinders
    Won't a WinKFP reflash write the VIN?
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jul 2016
    Ua
    Bmw
    If change used cluster for f series can change vin and milage by e-sys ?
    Pa soft can change vin number and milage to e90 ??
    Any one have diy for read or change eeprom ???
    Mar 2017
    RU
    f20
    Quote Originally Posted by Decobmw View Post
    e-sys on E chasis?
    Pa soft cant do it, only programmer wich can write m35080 d080
    if you read eeprom i can change vin and milage
  1. Problem with M instrument cluster in a 328i M52
    By Sicko in forum 1991 - 1999 (E36)
    Last Post: 08-23-2010, 10:26 AM
  2. Problem with replacing the corner light.
    By mack89 in forum 1999 - 2006 (E46)
    Last Post: 01-24-2009, 11:18 AM
  3. Replies: 7
    Last Post: 08-09-2007, 04:34 PM
  4. problems with the guage cluster
    By nj318i in forum 1991 - 1999 (E36)
    Last Post: 11-16-2006, 04:46 PM
  5. problems with my gauge cluster
    By sprammer325is in forum 1991 - 1999 (E36)
    Last Post: 12-01-2003, 11:08 PM
