My engine is an s50 bored to 86.5 with je pistons and eagle rods. I bought a rebuilt head and notice that the valve springs are of the straight kind compared to what the OE head where the springs were tapered at the top. I used the original lifters and trays from the s50 head on this new rebuilt head. I'm have lifter ticking, and seems like it's coming from the lifters on 5 of 6 cylinder. I did take all lifters apart to clean them where they were all smooth when pressing them with my fingers then I loaded them to where they got stiff. My question is, do I need to use different lifters for that type of valve spring or do the s50 lifter be ok?.. I was told to drive the car and hopefully the lifter will adjust.
96 M3, GT4094R, Arrow Rods, CP Pistons, Elring HG, cutring 87mm, 10 mm ARP studs,MS3pro, EMC Intercooler, n54 6 speed with Motiv twin disk, ZT-2 wideband, Zionsville Radiator, X-brace, H&R springs with bilstien shocks, QTP electronic cutout, Line Locks, stock exhaust 455rwtq, 453rwhp at 14 psi 91 octane.......684rwtq, 681rwhp at 24 psi running flex fuel E60 at time of dyno tune.
Did you just put the motor together now? It sometimes takes 10-15 minutes of driving to get all the air out of the lifters. If you have straight single valve springs then its most likely a vanos M50 head.
sometimes you need to drive it to fully bleed the lifers. I had an S50 that sat for years, i couldn't get the lifters bleed until i drove it. You can always try the old "Italian tune up"
What oil are you using?
In my case I had to drive it a few hundred miles on the old oil (not sure what it had, possibly some cheap stuff for break in) after my headgasket failure (poossibly due to overheating). I had the head machined so it got dissasembled and built back up. At first I thought the lifters may have been misplaced or damaged during the overheat. No wanting to mess wiith the cut ring headgasket and itching to drive I decided to hold off on pulling the cams or head back off.
I changed oil to Total 10w-40, and noise improved significantly (I inspected the filter and oil filter housing for debris). A few hundred miles later it was quiet except on cold start, where it was still loud enough for people to look at me strange when I drove by pedestrians. My commute is about 1/4 mile out of my sub and into the starbucks parking lot, then about 5 miles of 50 mph to work. By the time I get to work the noise is almost gone.Then I switched to Castrol 60 oil and the noise is gone, even on cold start. I can hear my VANOS rumble upon cold start again, which is my "normal" lol. I have not checked lifter clearances to cam lobe since the first time, though.For awhile there I was looking into replacing all my lifters.
1989 535i - sold
1999 M3 Tiag/Dove - sold
