Page 5 of 13 FirstFirst 12345678910111213 LastLast
Results 101 to 125 of 323
Thread: Another rear deck speaker upgrade.
  1. #101
    Everett, WA, USA
    '01 740i, '93 300ZX TT
    Quote Originally Posted by Nurburgringer View Post
    Do the 8ohm monsoons not fit?
    Check and recheck your wiring or unplug one at a time until the buzzing goes away via process of elimination. To answer your question, I believe they only make 4 ohm and 2 ohm versions, no 8.
  2. #102
    Jul 2016
    San Diego
    1998 E38 750iL
    Are all the speakers inside the box wired individually? You can combine speakers in series to increase the resistance the amp sees (so 2x 4ohm speakers = 8ohms load, or 4x 2ohm speakers).
  3. #103
    St. Charles, MO, USA
    1996 & 2001 BMW 740il
    That's odd I have no such sounds from mine. I can crank it up really loud without any issues
    "Lead by example, follow by choice."
  4. #104
    Feb 2013
    Houston TX
    99 528i Sp, 01 740i Sp
    Quote Originally Posted by PiotrC70 View Post
    Could do, but I'm hearing it from each speaker so seems like something affecting all of them?
    ok thanks, forgot that it was 2 and 4, not 4 and 8.
    Quote Originally Posted by Aitch View Post
    Doubling up each pair would indeed get that wires impedance to 8, but wouldn't the total still be 16 to the sub? Before I do any more disassembly though I'm going to listen to a few more CDs at lower bass levels and see if it's still bothersome.
    Quote Originally Posted by thrawn5499 View Post
    You're running with DSP off, correct?
    What bass level?
    Last night's listening/tuning session convinced me that anything over 50% bass was too much. Even 50% overpowered the mids and highs, and also was tiring.
    But I only listened to the one REM album so need to try some others.
  5. #105
    West Palm Beach, FL
    06 Audi A8L Quattro
    Yes they are wired individually.
    So you can NOT do that in this case.
    Each speaker in the rear deck is driven by a separate amp circuit with no shared grounds.
  6. #106
    Feb 2017
    Pittsburgh, PA
    1998 BMW 750il
    Faceplate distortion and cone movement is pretty normal for subs, especially in a sealed box. when you're moving the cone that much, some sound is inevitiable. I wonder if a small square of Dynamat or similar on the underside of the mounting plate would help.
  7. #107
    Feb 2013
    Houston TX
    Is the box really sealed?
    I popped the trunk last night, and reaching up under the box could feel air movement so I think it's ported out of the bottom.
    Could still hear the buzzing sound with the trunk open when I put my head close to the speakers, but again now that I've adjusted the bass level down below 50% it isn't audible in >90% of the songs I've listened to.
  8. #108
    Oct 2014
    NE
    2000 740IL
    box IS sealed.
  9. #109
    I agree with mooll, I thought my box was sealed, but I may have missed it. Maybe yours is supposed to be sealed and is not, or maybe some were and some were not depending on year. I am sorry I don't have an answer on this. As far as I know dville has done more of these than anyone else so maybe he will chime in.
  10. #110
    Jul 2016
    San Diego
    1998 E38 750iL
    Isn't this a port in the backside which feeds to the trunk?
    From the thread where dville describes his adventures fettling the boxes. https://www.bimmerforums.com/forum/s...eakers-Choices
  11. #111
    Not sure now, but isn't that a port from the interior of the car to the trunk to relieve pressure when the doors are closed? I am not sure if the speakers connect to that. again I might be wrong.
  12. #112
    Mar 2004
    Tyler, Tx
    '01 740i Sp, '07 335i
    For you guys looking for good albums - years ago before I lost most of my hearing and being recently divorced I spent an evening in a stereo store (for those in KC, KA) Beattys, I walked out with just over $3K in sound equipment. The deal maker was listening to a Jazz album "Jazz at the Pawn Shop" a two record album for those that remember what those are. They were playing it on some nice equipment, including some very expensive MagnaPlaner speakers. The album was a $35.00 Digital Master but I can still remember the sounds from that album and I wore it out years ago...... If I could still hear those sounds I would look it up on CD now. It has very subtle sounds of silverware rattling at a sidewalk cafe and some very good backgrounds, a good jazz example.
    http://i293.photobucket.com/albums/mm71/krallopian/darthSigTest2_zpsn6zkw5id.jpg[/URL][URL="http://www.facebook.com/pages/DFW7-Dallas-Fort-Worth-BMW-7-Series-Club/300942239566"]DFW7 on Facebook/URL]
    "The Last Great e38" 2001 i Sport - Born'd on date 1/01 Cosmos/Grey - 32.8K miles - 2 1/2 " Custom Exhaust, Center “X”over , Modified OEM rear bumper, M5 style trunk spoiler, M6 OEM wheels, M3 Steering wheel with working paddle shift & CF trim, Bi-Xenon upgrade, 13mm Rear sway bar added, SS brake lines and bronze bushings, Cross drilled rotors and painted calipers, Akebono pads, Zionsville aluminum radiator & exp. tank with electric fan, Sprint Booster, BluTooth conversion, MKIV Nav., Custom wood cupholder, DUDMD Tune, Orien V2.5 LED Angel Eyes, Evans waterless. Recently added grey faced //M5 Cluster - all gauges functioning. Changed the grey carpet to black and topped off with GG Bailey front/rear mats[/SIZE]
  13. #113
    Feb 2013
    Houston TX
    Yeah that's what I remember seeing when the box was out. I don't know if 2 or all 4 are ported to it, but if you reach in under the rear shelf with a bass-heavy song on, you'll feel air movement in time with the beat.
  14. #114
    West Palm Beach, FL
    06 Audi A8L Quattro
    The box is one large connected cavity with a large port into the trunk (on 1997? and later cars). Not sure what year the port holes began
    There are 2 pieces of sponge on either side of the port that I usually remove with needle nose pliers.
    There should be no buzzing or rattling if you test the box outside the car.
    You have to tighten the box to the rear deck before testing it or it will surely make a racket.
  15. #115
    Jul 2012
    North Carolina, USA
    1997 BMW 840Ci, 1985 Fer
    Delivered today…
    Sent from my iPhone using Tapatalk Pro
    Matthew M.
    North Carolina, USA
    1997 840Ci | 2001 740iL | 1985 308GTSi Quattrovalvole
  16. #116
    Jul 2016
    San Diego
    1998 E38 750iL
    Nice, mine are due to arrive tomorrow.
  17. #117
    Jul 2012
    North Carolina, USA
    As the guys have said, really terrific quality.
    Matthew M.
    North Carolina, USA
  18. #118
    Jul 2016
    San Diego
    1998 E38 750iL
    Quote Originally Posted by BobieM View Post
    Nice, glad to hear it. I'm hoping to get mine in this weekend, then re-dye the rear deck black and get it all buttoned up again.
  19. #119
    Jul 2012
    North Carolina, USA
    Sounds like a good plan. I'm looking forward to getting to work on it Saturday morning. After the shade repair, the speakers are the only broken bit back there now.
    Matthew M.
    North Carolina, USA
  20. #120
    Nov 2016
    Hansville, wa
    2001 750il Chrome line
    Did mine in the car with some foam and screws with washers. They sound killer! The best part was I was done in two hours. On to the valley pan.
    Attachment 594503Attachment 594504
  21. #121
    West Palm Beach, FL
    06 Audi A8L Quattro
    Now that's a shortcut!!! ��
    Any pics with the grilles installed ?
  22. #122
    Aug 2015
    Cologne, MN
    03 M3 00 740i 98 528i
    Can someone post a pic of where a guy is supposed to cut these rings off exactly?
    2000 740i - 149K - Dville Monsoon rear deck speaker upgrade, GROM audio Bluetooth
    1998 528i - 204K - GROM audio Bluetooth setup, Drilled/Slotted Rotors, BSW Stage One speaker kit, Facelift Xenon's with Angel Eyes
    2003 M3 - 210K - BMW Euro Cross Drilled Rotors
  23. #123
    Feb 2013
    Houston TX
    Quote Originally Posted by dville View Post
    Now that's a shortcut!!! 😀
    Seriously! Impressive work with such little space to work in.
    MN - go back to Thrawn's posts on page 1 or my post on 2-17 and you'll see where to split the joint.
  24. #124
    Aug 2015
    Cologne, MN
    Awesome, will do.
    Thank you sir!
  25. #125
    Nov 2016
    Hansville, wa
    The finished product. Did the heat gun glass jar trick to get the inboard speakers in.
    Attachment 594559
  1. Enlarging Rear Deck Speaker Holes
    By 10kken in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 02-24-2003, 07:31 PM
  2. rear deck speakers for 94 325
    By joe325i in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 11-24-2002, 10:12 PM
  3. E36 M3 Rear deck speaker help
    By havenlock in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 11-11-2002, 12:06 PM
  4. what are my rear deck speaker options?
    By 1995red318i in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 05-23-2002, 12:05 AM
  5. 4" rear deck speakers...how hard to replace with 6x9's?
    By Sacramento M3 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-23-2002, 01:42 AM
