Page 11 of 13 FirstFirst ... 2345678910111213 LastLast
Results 251 to 275 of 323
Thread: Another rear deck speaker upgrade.
  1. #251
    Apr 2017
    Stamford, CT
    2014 Ford Focus ST
    So I used high density foam around the speakers and I am getting a rattling from the speakers. I tested them in the car without bolting down but the speakers themselves are rattling. I'm assuming that's different than chuffing, correct?
  2. #252
    West Palm Beach, FL
    06 Audi A8L Quattro
    Looks good.
    Chuffing as I know it to be is the sound of air rushing through openings that it aren’t supposed to be there. Cracks in the box, open screw holes, loose speaker etc.
    Make sure to test each speaker outside the box to make sure they are not damaged before installing them.
    It looks like your foam was very thick and when you screw the speakers in the speaker frames are slightly distorted or twisted. This could cause voice coil rubbing.
    You need to Troubleshoot where the rattling is coming from: box to car, speaker to box, speaker...
    Some of the boxes I would find have cracks near the bolt holes at the inner speakers due to age. Those I would seal up with hot glue.
  3. #253
    Apr 2017
    Stamford, CT
    2014 Ford Focus ST
    Quote Originally Posted by dville View Post
    Looks good.
    Thanks @dville. I tested the speakers before mounting and had no issues. I will remove all of the screws and see if the rattling is still there, then begin further trouble shooting.
    I loosened the screws to give the speaker a more uniform fitment around the rubber and still had the rattling. I will keep working on this one and appreciate your support!
    Thanks,
    John
  4. #254
    Apr 2017
    Stamford, CT
    2014 Ford Focus ST
    @dville went through your photo bucket pics - did you add polyfil to your speaker cavities? If I recall correctly, I was informed to remove the foam in the middle of the speaker deck and only make the inner pockets deeper.
  5. #255
    West Palm Beach, FL
    06 Audi A8L Quattro
  6. #256
    Nov 2011
    Orlando, Florida
    98 740I 00 740IL 08 R1
    So 4 ohm monsoons in the doors is recommended also? Thinking about buying 8 and swapping all the 5.25’s out of my DSP car.
  7. #257
    West Palm Beach, FL
    06 Audi A8L Quattro
    Quote Originally Posted by Boosted96GSX View Post
    That’s what I did! 👍👍👍
  8. #258
    Apr 2017
    Stamford, CT
    2014 Ford Focus ST
    That’s what I did!
    What tweeters did you use for replacement?
  9. #259
    West Palm Beach, FL
    06 Audi A8L Quattro
    Quote Originally Posted by jjc034 View Post
    Did not change those.
    Only the eight 5.25” speakers
  10. #260
    Apr 2017
    Stamford, CT
    2014 Ford Focus ST
    Are they not as prone to heat and cracking?
  11. #261
    Nov 2011
    Orlando, Florida
    Thanks dville!
  12. #262
    West Palm Beach, FL
    06 Audi A8L Quattro
    It’s the foam surround on the 5.25” speakers that gets damaged with age.
    The others worked fine.
  13. #263
    Dec 2011
    Lancaster CA
    e34,e38,e39,e46,e70,e90
    OK Dville, and all others that have these installed, I have a question.
    About 6 months ago I did this mod on my sons e39 540i, posted here https://www.bimmerforums.com/forum/s...-Deck-Speakers
    one thing I realized was that the Monsoons were not performing well in the small sealed boxes of the e39 and I drilled a hole in the boxes to let them breath, and the Monsoons came to life.
    In in the original mod here you had cut out the sub box to fit the outboard speaker, allowing the box to breath. I did the same when I did the mod on my 740iL. Sounded great. Now I want to do the same on my DINAN 7. However, now you reform the box and keep it sealed.
    Im wondering, is the box big enough to let the speakers breath ok, or does it still need a vent? Has anyone done a side by side comparison?
    My old set in the iL still works great, although one speaker may be a bit loose and crackling after all that high volume bass for about 2 yrs now.
  14. #264
    Apr 2017
    Stamford, CT
    2014 Ford Focus ST
    Quote Originally Posted by kouks View Post
    I reformed the inner speaker cavities and removed the foam in the center, which helps them breathe a bit. Now that my new monsoons are breaking in, they sound pretty darn great. No chuffing using HDF and nice low.
  15. #265
    West Palm Beach, FL
    06 Audi A8L Quattro
    Quote Originally Posted by Nurburgringer View Post
    Bill - it's going to take you more than an hour to get a sub-box out of one at a pick-and-pull
    I’ll share a secret for removing the sub box from a junkyard car in 5 minutes:
    Remove headrests (20 second job).
    Remove c pillar trim (30 second job if they are already messed up).
    Remove speaker grilles.
    Cringe and then basically break up the cardboard rear deck trim by prying the rear of it towards the front of the car.
    Then I use a battery powered socket to unbolt the box, slide forward and unplug, then remove.
    I take the speakers out so they don’t charge me for them, but I keep the screws.
    The E38 box has a large opening in the middle under the sub box that vents into the trunk.
    Keeping the back of the speaker sealed only reduces the effective opening into the trunk.
  16. #266
    Dec 2011
    Lancaster CA
    Thats what I was looking for. The Monsoons are made as open speakers in the doors and need to breath. They use their shell to create better bass. We are basically replacing the shell with the rear deck, but they still need to breath.
  17. #267
    West Palm Beach, FL
    06 Audi A8L Quattro
    I
    The entire door of the VW is the box.
    The speaker is sealed with foam and riveted to a metal plate in the VW with the window regulator and other stuff on it.
    The metal plate is sealed to the door opening with some gasket sealant goop.
    The windows opening are sealed with rubber seals.
    The door becomes a fairly large “box” after its all put together.
    I know this because I had a 2004 Jetta with a Monsoon system, and the doors would really thump with bass to no end.
    I was jealous of this when I got back in my E38.
    This is what started me with getting Monsoons to work in my E38.
  18. #268
    West Palm Beach, FL
    06 Audi A8L Quattro
    Read your thread on the E39. Nice work.
    Same as I did, experiment until you are satisfied.
    The designers of the factory system do calculations of the volume of the box and select a speaker with specs along with a final box size that is best for the application. We don’t have that luxury, so experimenting is the low cost option.
  19. #269
    IL
    2000 740i sport
    Just installed brand new 4ohm monsoons using the method of just expanding the middle holes not cutting and removing all of the foam in the box. Im not super impressed and expected a bit more bass. Maybe I did something wrong? Any tips to get it tuned right?
    Sent from my SM-N960U using Tapatalk
  20. #270
    Dec 2008
    Washington, NC
    01 330 CiC, 05 X3 3.0
    I wsn't that impressed with mine, either, but I've had real subs in my cars for decades. I just got a smaller box for 2 10's and put them in the front of the trunk.
  21. #271
    IL
    2000 740i sport
    Quote Originally Posted by ConvGeorge View Post
    That's probably why I feel the way I do as well... They definitely sounded better in my old jetta. If i open the trunk there is alot of bass going into there via the port in the box. Wish that was going into the car instead...
  22. #272
    IL
    2000 740i sport
    So I found a good CD and it does in fact make a big difference for heavy bass tracks. I was basing mu feedback listening to the radio and I am pretty impreased with higher quality audio like CDs. Im hoping when I retrofit streaming a bluetooth module it will be just as good if not better...
  23. #273
    Apr 2017
    Stamford, CT
    2014 Ford Focus ST
    Quote Originally Posted by purplecty View Post
    Wait a little for them to break in. I wasn't impressed either at first and then BOOM... crazy good bass out of those little guys.
    I'll send you my dsp settings next time I'm in Mr. Green.
    Also either use cassette adapter or Bluetooth for best fidelity.
    Thanks,
    John
  24. #274
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    The problem with the rear speaker deck is that the bass is rolled off above 40Hz - and that means that you get very little action from them until you play a CD with prevalent sub-bass - try some Pendulum, in particular Propane Nightmares from In Silico - that will move some air!
    My BMW Repair YouTube Channel
  25. #275
    Jul 2016
    San Diego
    1998 E38 750iL
    Quote Originally Posted by Timm View Post
    That also explains why I'm so happy with how the Monsoons play really low bass... when a song comes on where a bass note starts higher and then just drops to the bottom of the frequency range (40-20-10hz) they bring it right out. Really impressive.
  1. Enlarging Rear Deck Speaker Holes
    By 10kken in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 02-24-2003, 07:31 PM
  2. rear deck speakers for 94 325
    By joe325i in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 11-24-2002, 10:12 PM
  3. E36 M3 Rear deck speaker help
    By havenlock in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 11-11-2002, 12:06 PM
  4. what are my rear deck speaker options?
    By 1995red318i in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 05-23-2002, 12:05 AM
  5. 4" rear deck speakers...how hard to replace with 6x9's?
    By Sacramento M3 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-23-2002, 01:42 AM
