Results 1 to 25 of 54
Thread: Power Steering help
    Cebu, Philipinnes
    1991 BMW 735i E32
    Power Steering help
    It looks like i need to buy a new POWER STEERING PUMP. I have looked on Autozone and realoem.com. I am not looking for an original oem part, but I am looking for a high quality aftermarket part. Any help would be great. I want to keep this cat forever and want a top end aftermarket part. Ideas? Thanks
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    What is the reason you need a new power steering pump? Leaks? I have a new seal set on stock, can send that over to Cebu from Japan.
    FCP has remanufactured pumps https://www.fcpeuro.com/BMW-parts/73...86&m=20&page=1
    also check rockauto , they have a lot of reman parts and probably also power steering pumps. Basically the pump lasts very long. The main shaft seal has to be replaced, some o-rings and the profile rings inside the pump. Have already repaired a lot this methid. My kit fits your pump from ZF with a shaft diameter of 19mm and is for single pumps as well as tandem pumps (in case the car has LAD)
    Nov 2012
    staten island
    1994 BMW 740i (e32)
    Hey Shogun.. it appears my leak is coming from the steering pump filter housing.. the site won't let me post up a pic. My mechanic said somebody JB welded it shut and he can't access.. he recommend I replace the the filter housing. Any suggestions, part number? Thank you
    Is there any way I can send you pic??
    Jan 2005
    Japan
    Just upload a pic on a free upload and post the link here. You can also upload the picture on the forum. Try first the testing forum.
    When you reply, click on the right side "go advanced" and then you have the option to upload a picture.
    Test forum https://www.bimmerforums.com/forum/f...hp?123-Testing
    Richmond, Virginia
    '88 735i, '06 RSX
    I may have to do this as wel...replaced PS reservoir, worked great initially but soon after, clunk clunk clunk returned with stiff power steering and squealing.
    Jan 2005
    Japan
    Remember there is a filter inside the power steering reservoir and a small, but very important mesh filter at the bottom of the power steering gear on top of the Servotronic Control Unit; Torque Converter, not shown in realoem
    see my website, fixes>>>steering>
    Steering has become heavy at low speeds
    Steering is intermittently heavy at low speeds (servotronic electronic unit has failed?)
    the power steering bump rebuoild is on my website under fixes >>hydraulics
    Richmond, Virginia
    '88 735i, '06 RSX
    Quote Originally Posted by shogun View Post
    I haven't been able to located this in my car yet. Do I have to drain the PS fluid before attempting to extract this mesh screen?
    Jan 2005
    Japan
    There are 4 bolts holding the torque r# 18, 2 short ones, 2 long ones, the 2 long one hold the unit http://www.realoem.com/bmw/enUS/show...diagId=32_1899
    when you remove the torque converter from the steering gear bottom, you need a oil catch pan, as all Pentosin will flow out.
    I do not know how the PS fluid container looks at your car, on my 750 11/88 it looks like this, there you can see the filter http://www.realoem.com/bmw/enUS/show...diagId=32_0623
    Nov 2012
    staten island
    1994 BMW 740i (e32)
    I finally figured it out, Here it is..somebody appeared to have JB welded it closed.. was wondering what this housing name is #s10-13 on system diagram
    1994 740i 87k.. Till death do us part out.
    Jan 2005
    Japan
    That is additional filter, not all E32 have , it is for E32 with ASC+T, unfortunately only available as complete item
    11 Oil filter 1 34511159665 $314.22
    maybe you first get a new o-ring and change that one
    13 O-ring 40X3 1 34511159421 $3.07
    14 FILTER CARTRIDGE 1 34511159666 $62.30 https://www.ecstuning.com/b-genuine-...h/34511159666/
    http://www.realoem.com/bmw/enUS/show...diagId=32_1917
    filter cartridge is also very expensive, you can try to clean it with brake cleaner, did that once.
    Nov 2012
    staten island
    1994 BMW 740i (e32)
    Thank you for quick response Sho!
    Cebu, Philipinnes
    1991 BMW 735i E32
    Shogun,
    I went to the BMW DEALERSHIP here in the Philippines and they wanted over 3,000 dollars for a new pump (exchange hydro steering gear). They did not know whether my car is German or Japanese made. Can you help? They deleted the part numbers so i couldn't research for myself. I don't know if my car is self leveling or not. Can you help me pls. There are no leaks. Should I just have the dealership flush the liquid and check the filter before I buy this pump from America? And could you help me find the part number so I know what to buy? Thanks Shogun!
    My car information is.....
    DA41911GB41 7' E32 Saloon 735i L A 1989/12
    Jan 2005
    Japan
    DA41911 : That is a EURO spec 735i, not L, production date 12/1989, no LAD
    based on the VIN AT-VANE PUMP ZF up to 08/1990 32411130556 $618.56 exampples of new/reman http://www.partsgeek.com/catalog/199...ring_pump.html
    VIN WBAGB41030DA41911
    Type code GB41
    Type 735I (EUR)
    E series E32 ()
    Series 7
    Type LIM
    Steering LL
    Doors 4
    Engine M30
    Displacement 3.50
    Power 155
    Drive HECK
    Transmission AUT
    Colour LAZURBLAU METALLIC (294)
    Upholstery (0226)
    Prod.date 1989-12-14
    Vehicle upgrades
    High-End sound system
    S401 Lift-up-and-slide-back sunroof, electric
    S428 Warning triangle and first aid kit
    S458 Electr. front seat adjustment
    S472 Armrest, front, driver/passenger
    S494 Seat heating driver/passenger
    S510 Headlight aim control
    S534 Automatic air conditioning
    S540 Cruise control
    S570 Reinforced power supply
    S652 Radio Bavaria C II
    S676 HiFi speaker system
    L801 National version Germany/Austria
    If there is no leak, no need to buy a pump now, but if you want, there are used ones, reman ones by other companies and AT ones from BMW = reman by ZF.
    Copy the VIN decoded details, in case your dealer next time has a question. They always can check for the numbers here www.realoem.com
    Cebu, Philipinnes
    1991 BMW 735i E32
    I got the part number.... 32131139745. Could you help me located a place to buy? Realoem.com is expensive.
    There was no leak, but the linkage connection was loose to the steering pump. That is what is causing the noise.
    Jan 2005
    Japan
    That number is ended and is not a pump but a Rmfd hydro steering gear 09/1989 32131139745 , in case you need a gear, you need Rmfd hydro steering gear from 09/1989 32131139747 http://www.realoem.com/bmw/enUS/show...diagId=32_0268
    So what do you need? power steering pump or steering gear?
    Both are in my opinion waste of money to store them now, just for the case that you need them many years later.
    If the pump needs seals, there are seal sets, if the steering gear leaks, there are seal kits. It is not advisable to store now for many years.
    If other things fail, then buy a remanufactured one and send the damaged one back to the selling co. as core.
    Nov 2015
    Pgh, Pennsylvania
    1990 735i 3.5/automatic
    Ah ow!! I'm going to be replacing my return line soon. While I have my reservoir off, I better see about these filters. I am sure mine have never been changed.
    Sounds like the filter in the reservoir might not be hard to find. But the mesh one your talking about. Does the pump have to come apart to replace it?
    Not trying to thread jack. But starting a whole new thread seemed stupid when it can all be done in one.
    Richmond, Virginia
    '88 735i, '06 RSX
    Quote Originally Posted by TonyPa View Post
    The filter is 10-15$ by itself, a new reservoir + filter is 20$ on fcpeuro. I just went ahead and replaced the whole unit for that price. Besides, old BMW plastic isn't exactly the most reliable.
    I too have trouble finding this stupid mesh filter.
    Nov 2015
    Pgh, Pennsylvania
    Ohhh if it's that cheap. I'll be more than happy to buy the new reservoir! Thank you. Especially with the filter coming with it. I'll order it with my new return hose.
    I dunno where my mesh one would be?
    Also...how did you get your fluid out....without a huge mess?? Lol
    Jan 2005
    Japan
    no, as I said, the mesh filter is at the bottom of the power steering gear on top of the Servotronic Control Unit, you have to remove the servotronic control unit at the bottom of the STEERING GEAR, it has 4 bolts in total, 2 long ones hold it at the steering gear, when you remove this control unit, all power steering fluid will come out of the steering box. See my website, there are pics. fixes>>steering
    Nov 2015
    Pgh, Pennsylvania
    Ohhhh I was,thinking on the pump. It's on the steering box. I see on your website now what you were talking about.
    Looks like what is,on my sink faucet. My steering is a tiny bit heavy since I poured that synthetic tranny fluid in. Probably cleaned stuff up and clogged my screen. But only at very slow,speed so nothing to complain about.
    Can this be done with the steering box on the car?
    I don't know how much room there is.
    I am going to get that apart this week then. I want to replace my return hose. Might as well try and get that screen out and clean it.
    I'm just going to refill the system with old fashioned Dex3 this,time
    Jan 2005
    Japan
    yes, of course. Have a look here which 2 bolts you have to remove and which tool you need, star https://www.ecstuning.com/b-genuine-...t/32411134770/
    this is the small filter https://c1552172.ssl.cf0.rackcdn.com/296405_x800.jpg
    Nov 2015
    Pgh, Pennsylvania
    The first link took me somewhere strange?
    The second one did take me to an image of the mesh screen.
    Richmond, Virginia
    '88 735i, '06 RSX
    we need a power steering dedicated thread pinned uptop haha.
    I used a turkey baster, sucked out as much fluid out of the reservoir as I could, undid the lines (one of them was a bitch to get off), some spilled of course, but not a huge deal. fitted new reservoir, added synthetic ATF fluid, turned steering wheel from side to side maximum amount a few times, and my "clunk clunk" went away. However, it is back now.....no loss in PS fluid level so I'm chasing other demons now it seems. Joys of E32 ownership.
    I do not know where this power steering gear or servotronic module is.
    Cebu, Philipinnes
    1991 BMW 735i E32
    Jan 2005
    Japan
    So if you need a power steering gear box for your E32 735i (and not a power steering pump, as mentioned before), it will fit. But a bit pricey with US $105.99 for a used 1988 steering gear box, you can get a fully reman steering gear box here for:
    List price: $449.63 What does this price mean? You save: $156.46 (34% off) Now:US $293.17 Remanufactured-OEM-Genuine-Power-Steering-Gear-Box-Gearbox-Fits-BMW-735-750
    http://www.ebay.com/itm/Remanufactur...3D162174201900
  1. Power Steering Help
    By Jackoosh in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-04-2006, 01:18 AM
  2. Power Steering, Help!!!
    By MP525i in forum 1983 - 1991 (E30)
    Last Post: 10-06-2005, 02:06 PM
  3. Newbie Power steering help
    By bassistvp in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-01-2005, 02:42 AM
  4. Stupidly added brake fluid to Power Steering!! HELP
    By baigeman in forum 1991 - 1999 (E36)
    Last Post: 04-10-2005, 08:00 PM
  5. Lost my power steering. Help!
    By Canon in forum 1991 - 1999 (E36)
    Last Post: 10-27-2003, 03:34 PM
