Brake lights, signals, and windshield wipers all stop at random and usually at the same time. From 5-20 mins up to hour at a time. Help please, almost died a few times due to this random wiper stop and rear ended from no brake lights.
Ever figure this out? I just noticed my brake lights are no longer working on my '84 728i. I'm digging in to this today. Brake pedal switch is suspect but I thought I would search the issue first to see whats been said and no real good info showed up. Several documented cases but no solutions.
Happy New year BTW!!
'84 728i Delphin Metallic, '84 745i Polaris Metallic, '85 745i Bronzitbeige Metallic, '86 535i Arctisblau Metallic,
'86 524td Bronzitbeige Metallic (euro'd), '87 535is Diamantschwarz Metallic, '88 528e Luxorbeige Metallic, '89 635csi Bronzitbeige Metallic
"Zhe Porsche drivah on zhe Autobahn; he vould know, sooner or later, vhat kind of 5 series zhat vas"- Albert Biermann, ex-VP Engineering BMW ///M, on the e28 M5
My issue was resolved with a replacement (used) pedal switch. Upon removal the original switch made grinding noises when depressed and did not have continuity when tested with a multi-meter. By contrast the replacement was smooth, silent and had good continuity.
I hope this helps fill in the search gaps.
- knock on wood - hasn't happened again since posting - knock on wood - what's this pedal switch, I'll look into it. Could be same thinf
