Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 82
Thread: M62TUB46 swap into 2001 740i Sport Project
  1. #51
    Nov 2011
    Greedland
    99 540i6, 02 X5, Tundra
    Quote Originally Posted by redgtocruiser View Post
    Looking for guidance / consensus and feedback on using an 88C thermostat over the standard 105C thermostat here on my build with the 4.6. Would like feedback from those that have actually used the 88C thermostat for a longer period of time.
    I've had the 88c for a couple months now very happy with it!
    I bought a second for my 4.6
    E85 fueled, Eaton m112 supercharged 4.5L M62TU, TTV racing flywheel, Spec stage 2+ clutch, 88c thermostat, eibach sway bars, wavetrac 3.15 lsd, m5 steering box, Quantum 340lph fuel pump, Dinan camber plates, some powerflex bushings, Supersprint headers, M5 cats, 2001 gas pedal upgrade and many other things done. all diy by me
  2. #52
    May 2013
    Memphis, TN
    2001 740i Sport
    I have had an 80c installed for over 2 years...very pleased with results. I consider this a must do...
  3. #53
    Oct 2016
    Upstate NY
    2001 BMW 740i Sport
    Next question... while I have the 4.6 out and accessible... I am assuming it would be a good idea to do the front crankshaft seal and rear main seal. Thoughts? I am assuming this are must do items will the engine is accessible. Easy to do? Special tools?
    Rear Crankshaft Cover w/ Seal, Part# 11141745093
    Rear Main Seal Flange Gasket, Part# 11141736521
    Crankshaft Seal Front, Part# 11141275466
  4. #54
    Nov 2011
    Greedland
    You already have to take lower timing cover off, definitely do the seals too. I am
  5. #55
    Jul 2014
    Pasadena, CA, US
    2001 BMW 740iL
    Crosspost from another thread and I would like to ask a quick question if I may.
    I am finishing up my M62TUB46 installation as well. It is from an 8/98 build e39 Alpina B10 into a 4/00 build e38 740iL.
    My big question is, can I use my old DME for now? I plan to add the tune in time, but would like to get on the road asap.
    Thanks!
  6. #56
    Mar 2013
    Sonora, ca
    2001 740il
    Quote Originally Posted by tkbartscherer View Post
    Thanks!
    I would pm dudmd
  7. #57
    Sep 2014
    Chicago, Il / Denver, Co
    '01 DINAN7 '03 M5
    Quote Originally Posted by purplecty View Post
    She looks pretty! I'm not sure anyone actually completed this swap to my knowledge...
    Been done on E39
    Instagram.com/nordmanmg
    Your current situation is not your final destination
  8. #58
    Feb 2012
    Bottom of a Bottle
    96 740il, XJS & CBR1000F
    Quote Originally Posted by NordmanMg View Post
    Been done on E39
    What hasn't been done on e39? Turbine? :P
    The World is ruled by Kings and Queens that blind your eyes and steal your dreams.
    When answering my questions please use a qualifier if you are not sure.
    The more I work on this car the less I respect German engineering.
    When you speak in Absolutes you are always wrong!
    Semper Fi
  9. #59
    Mar 2013
    Sonora, ca
    2001 740il
    Quote Originally Posted by Hueristic View Post
    Cummins 12v
  10. #60
    Nov 2016
    Charlotte, NC
    '02 540i-6, '97 540i-6
    FWIW, I can offer short-term feedback. I just installed an 88C thermostat from ECS tuning in my '02 540. The thermostat did not have a wiring connector, but my car doesn't seem to care that the wire isn't connected to anything. (No codes.)
    When driving easily, practically coasting in cool weather, I've seen the operating temp as low as 91C. While driving at highway speeds in 40-60F weather, the temp stays at 93C. So I think of it as a low 90's thermostat, which is fine with me. In summertime stop and go traffic with the AC on, I'm sure the temp will climb higher (unless I modify the fans). But at least I know the thermostat will let the temp drop lower when the car is moving.
    I hope that helps.
  11. #61
    Oct 2016
    Upstate NY
    2001 BMW 740i Sport
    Quote Originally Posted by R Shaffner View Post
    I hope that helps.
    Pretty sure that is not the desired method to be running around with the Thermostat not connected to the DME.
  12. #62
    Nov 2011
    Greedland
    There's no wire going to my thermostat, wiring in a dummy resistor is only needed if you get a code
    How's the progress on your build?
  13. #63
    Mar 2013
    Sonora, ca
    2001 740il
    Pulled the trigger yesterday bought 4.6 will 83,000 on it guess I'm about to be n the club
  14. #64
    Oct 2016
    Upstate NY
    2001 BMW 740i Sport
    Quote Originally Posted by Sundaycruzer View Post
    I am pretty sure you bought that shortblock that was for sale on ebay correct? Hardly any 4.6's for sale at the moment.
  15. #65
    Mar 2013
    Sonora, ca
    2001 740il
    Yeah talked him down to 3500 shipped. Says there's paper work will see. I'm going to do similar by rebuilding failure parts and replacing seals maybe start with n62 throttle body and 4 in. Maf then super charger later.
  16. #66
    Mar 2013
    Sonora, ca
    2001 740il
    I haven't seen any suggestions of mods. M60 intake, n62 throttle body, Vw maf. There's gotta be someone that's done more than a SC to this motor
  17. #67
    Jul 2016
    Chicago, Illinois
    are slow
    It's an M62, you pay for every little bit of HP.
  18. #68
    Mar 2013
    Sonora, ca
    2001 740il
    Quote Originally Posted by XAlt View Post
    That goes for every motor in existence. I'm asking for actual mods that have been done and what to expect. Before I waist time on mods that don't matter.
  19. #69
    Alpine 7even's Avatar
    Alpine 7even is offline The King Of E38 Custom BMW CCA Member
    Mar 2011
    Haymarket VA
    e38 iL, F-e38 iL, e23 L7
    For those supercharging a 4.6 on a stock trans beware. I'm at 462hp at 12psi with punched up tune and smaller underdrive pulley and VF have warned me against going any higher then that. From what I'm told the 5hp24, even with high stall and stage 4/5 dinan shift map, can only handle around 500hp before it starts to eat itself.
    Once my trans dies I'll be swapping to 6spd. Then I'll be doing the aftercooled rms intake man.
    Current engine mods:
    VF supercharger kit (modified tune and smaller pulley from vf)
    Dinan maf
    Dinan TB
    4 screw M60 manifold
    Full stainless exhaust
    S62 headers
    Dinan stage 4/5 trans tune
    Paddle shifters by AMG
    -2000 iL Individual. VF Supercharged at 12psi, Dinan MAF and TB, 6spd 420g swap, Euro under body guards, strong strut, N62 engine cover, Hydro trunk, Full suspension mods, Brembo F+R big brakes, custom headliner/interior, Bi-Xenon headlights, wide screen nav/mk4, Custom splash screen (I make them), coded video module with custom made harness, reverse camera, Intravee II, factory rear screen entertainment console, rear comms armrest, rear blower, seat back tables and writing tablet, all euro options coded on etc.
    -1997 iL. Pioneer 8500nex double din/Avic navigation, swc and dsp still functional. Reverse camera, full suspension upgrades, leather dash, console and door cards, rear blower, Re-upholstered seats, facelift sport contour seats, heated steering wheel, 750 front brakes, custom cup holder replacing the front ash tray, all euro options coded, headliner in black, rear headliner MID console.
  20. #70
    Mar 2013
    Sonora, ca
    2001 740il
    Quote Originally Posted by Alpine 7even View Post
    Dinan maf
    Dinan TB
    S62 headers
    Have you ran it on a dyno to see what rwh you have. The whole reason I want to stay in the m62 family is to keep the automatic. But I'm taking notes on your mods
  21. #71
    Feb 2012
    Bottom of a Bottle
    Have you ran it on a dyno to see what rwh you have. The whole reason I want to stay in the m62 family is to keep the automatic. But I'm taking notes on your mods Sent from my iPhone using Tapatalk
    5hp30 has 560nm torque max as opposed to 440nm on the 5hp24, not sure if you can retrofit one.
    Semper Fi
  22. #72
    Mar 2013
    Sonora, ca
    2001 740il
    What originally had a 5hp30
  23. #73
    Mar 2011
    Haymarket VA
    Any 98 or older e38.
  24. #74
    Mar 2013
    Sonora, ca
    2001 740il
    Duh, just serviced my buddy's 95 totally forgot. That would be difficult to mod I imagine
  25. #75
    Mar 2011
    Haymarket VA
    Wouldn't be easy. But not impossible
  1. S54/6 speed Swap into 2001 4 door 325i/5 speed sport
    By yammaxx in forum Engine Conversions
    Last Post: 08-05-2015, 10:29 AM
  2. Would you buy a 2001 740i Sport.... with a manual swap?
    By Desert Fox in forum 1995 - 2001 (E38)
    Last Post: 04-08-2015, 12:15 PM
  3. Replies: 13
    Last Post: 07-06-2013, 11:37 AM
  4. Lowering a 2001 740i Sport?
    By JLe38 in forum 1995 - 2001 (E38)
    Last Post: 02-09-2004, 02:42 PM
  5. 255's all around on 2001 740i sport
    By dc91gt in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 12-20-2003, 05:21 AM
