And so it begins..... Allow me to introduce myself. Technical individual here with 10+ years of basic wrenching experience and ever increasing skills and knowledge. So with that boring information out of the way I will tell you what I am up too. Oh and my "handle" I also have a mint 2004 Pontiac GTO 6spd that is red, purchased new has 40k on it. Garage kept.
I have a very clean 2001 740i Sport with 81k miles. Virginia car well kept. All was perfect! Except... one night last September while driving the heater hose coming off the rear manifold that goes into the heat exchanger for the HVAC system blew. Whether it was the hose that failed or the thermostat that failed in a closed position I am not sure. A diagnosis from BMW confirmed that the T-stat was not opening but this was after the engine overheated. Needless to say I pushed the 4.4 a little too hard during the overheat coolant loss process which has resulted in a head gasket failure. So yes my fault... I should have shut her down and had her towed everything would have been fine. The failure is causing exhaust to go into the coolant system which builds pressure. Not good, can smell the sweet burned gas in the coolant. So I figured great... Here is an opportunity. I like the 4.4 but in my opinion it falls a bit flat up top but I do enjoy its low end grunt. I could take the cheap way out and do the head gaskets, ensure the heads are not warped and the block is true.... but that would be too easy. So lets go find a 4.6 and give this 740i some real power... right?
Here we are the elusive 4.6 is on its way. Its a nice unit from a March 2003 BMW X5 4.6is with 92k on the clock. Plan will be to do the VANOS units (Dr Vanos) new timing chain and guides. Water pump and valley pan. Plus the necessary conversion bits to fit into the 740i (oil pump, pan, OSV, valve covers).
I do not have a schedule for this project and will be taking my time but I will share my progress updates with photos. And of course when I run into issues or have questions I will be reporting back. Inspired by Plattus and the excellent work on his 540i Touring. I will be following his lead in many respects, especially with the DME tuning post install. I too will enjoy the rarity that it will bring to the 740i and the OEM/Stock sleeper that only an extremely trained eye may be able to detect.
I plan to document everything as best as possible so that whoever wants to do this same swap in the future will have a resource. Thanks all stay tuned I look forward to your help and support and encouragement.
Here is the donor vehicle if anybody was interested. Negotiated price on the engine was $4500 as a reference w/ 6 month warranty + free shipping. Its a long block and includes all accessories and complete harness. Shipping weight 576lbs.
http://om.mmauto.com/om/fvn/item.asp?id=DD0548
The rare 4.6 swap.
subscribed
Subscribed with well wishes for a successful project.
"Let me tell you what Melba Toast is packin' right here, alright. We got 3:15 open differential with an M5 sway-bar outback, a 4.4 liter V-8 with Bosch sequential fuel injection, four cams, 32 valves, VANOS units using Beisan Systems seals, 10 to 1 pistons, a conservative 282 macht schnell horsepower, all planted to the earth with AC Schnitzer Type II Racing Wheels and Michelin PS2s at all four corners, an M5 rear sway-bar outback, and a Strong-Strut tower brace up front. We're talkin' some Deutschland muscle."
This should be pretty cool, I haven't seen any 4.6 swaps into a 740i. That'll definitely wake up the 740i and make it a heck of a lot sportier.
I've done chain guide jobs on the M62tub44 and M62tub46, so let me know if you need any advice.
For a proper conversion, you'll need to replace both oil pans (lower and upper), the CCV on the rear of the intake manifold, the oil separator behind the timing chain guides, punch out the freeze plug there, run a pipe from that OSV to the 740i CCV, and you'll also need to replace the driver's side valve cover with a 540i/740i one that has the breather hole sealed up. You can pull a lot of these parts from your 4.4 engine, except for the stuff that wears out like the OSV and CCV, those you should buy new.
Good luck!
1995 525i 5-speed - Thread
Subscribed. I'm liking the sound of this!
Biggest engine other than an Alpina M62TUB48 you can get in the e38 without going manual (S62). Looking forward to seeing this completed.
-Paul
2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers, Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
Sounds like a great swap!
2012 BMW M3 Coupe, 6MT (summer fun)|2017 Toyota Tundra 1794 MGM (DAILY)2015 BMW X5 35i, M Sport, AW/Mocha (Family hauler)
2006 BMW Z4 M Roadster, Silver Grey Metallic/Black
My friend has a few 4.6is engines for sale with new guides already...
A guy on here by the screen name of Bimmerfixr has his set up : E38 6spd, 4.6is, VF Engineering Supercharged, Dinan HFM/TB, 3:64Quaife, VAC Motorsport underdrive pulleys, SuperSprint headers/mufflers, Smile factor.
Avenging Angel: 2001 750iL Sport Schwartz II Metallic, too many upgrades to list here..
Kirsa: 2000 750iL Biarritz Blau Metallic, Born on 11/99. Sold 12/21/13
The Mistress: 1997 744iL Biarritz Blau Metallic, Sold 6/7/12. You will be missed Baby..
I thought the new X5's have a 4.8 also.....
http://i293.photobucket.com/albums/mm71/krallopian/darthSigTest2_zpsn6zkw5id.jpg[/URL][URL="http://www.facebook.com/pages/DFW7-Dallas-Fort-Worth-BMW-7-Series-Club/300942239566"]DFW7 on Facebook/URL]
"The Last Great e38" 2001 i Sport - Born'd on date 1/01 Cosmos/Grey - 32.8K miles - 2 1/2 " Custom Exhaust, Center “X”over , Modified OEM rear bumper, M5 style trunk spoiler, M6 OEM wheels, M3 Steering wheel with working paddle shift & CF trim, Bi-Xenon upgrade, 13mm Rear sway bar added, SS brake lines and bronze bushings, Cross drilled rotors and painted calipers, Akebono pads, Zionsville aluminum radiator & exp. tank with electric fan, Sprint Booster, BluTooth conversion, MKIV Nav., Custom wood cupholder, DUDMD Tune, Orien V2.5 LED Angel Eyes, Evans waterless. Recently added grey faced //M5 Cluster - all gauges functioning. Changed the grey carpet to black and topped off with GG Bailey front/rear mats[/SIZE]
-Paul
I wonder how hard an N62 swap would be.
Great engine, mind the bottom mounted oil filter and inherent VSS issues.
Theoretically doable. Most of the e53 modules are the same for M62tu and N62, so should be possible. Probably better to use one out of the e60 or e65 and use the N62 transmission with a hybrid driveshaft. Wiring shouldn't be too complicated, though easier in a facelift e39 than an e38.
Sent from my SM-N910V using Tapatalk
-Paul
I will say have been looking for 4.6 motors since October. They aren't impossible to find there are a handful available right now on ebay. Some are short blocks and some are long. I wanted a long block with everything on it for a lot of reasons. They are anywhere from $4-5k in price typically. They don't seem to sell too quickly. I called Bavarian Auto Recyclers a few times they had one with 79k a few months back they sold it and haven't had a 4.6 since. They dyno test the motors before they ship and such which is a nice service. Now finding a M62B48 that's a different story. http://www.rondaautoparts.com/ This place has one from a Z8 for $10k. Super low miles. No idea if they still have it or not. The M62B48 was also used in the Alpina E39 B10 V8S from I think around 2002 - 2003.
Doing an N63 swap seems quite a bit more challenging to me. Not something I would wan't to undertake. In my research I have not seen this swap into an E38/E39. I am pretty sure they use a different DME than the Bosch Motronic 7.2 that runs the 4.4/4.6/4.8 M62 variants.
Thats why I am a big fan of this swap. Its almost a 100% direct bolt in. Send my DME out to DUDMD for a rflash to the 4.6 engine mapping and should be good to go. With the 740i sports higher stall converter and 3.15 gears in the rear end I think this will be super nice on the highway.
An e38 4.6/4.8 naturally aspirated, with no turbo and a Factory look will be a fantastic build. 4.6 denoted on the trunk will be really special. I have 4.4 and 5.4. 4.4 just sits now. I'm interested in your 4.6 build. A low modification installation makes this very attractive. Can I retain the Automatic transmission? Not interested in the stick shift swap.
This makes me want to run out and buy an old X5 4.6 and gut it, solely for the purpose of putting it's heart in my '01 sport short. Yes, I love my car that much.
All kidding, but I'll follow this thread with interest.
AA
Aaron
Current
'13 528i xDrive M-Sport
'00 Audi 6 4.2 Sport - 6 sp conversion - 155k
'12 Audi Q5
'08 Silverado Duramax LTZ
Past
'10 - 128i Convertibel - sold
'01 740i Sport - sold 155k
'95 M3 Coupe
'95 M Roadster
'07 328i - sport, convenience - sold 176k
'95 S6 - raced and sold
'00 528iT - sport - sold
'95 993 C2-sport - sold
'06 M3 Vert - sold
'10 TDi Jetta Cup Edition - totalled
'02 996 Cab - sold
Your best bet for getting a cheap 4.6 is to find an X5 4.6 that either has a dead transmission or has had the chain guides go bad. I got my 2003 X5 4.6 with bad chain guides for only $3500! That's less than the engine usually costs on its own, plus you can part out the rest of the X5 to essentially make the engine free. I chose to fix my 4.6 though, because there are barely any left out there at this point.
Anybody know if the 4.6 used in the rovers is the same?
They're different
Looking forward to seeing this happen. Subscribed.
95 740i 99 750i
Subbed.
The World is ruled by Kings and Queens that blind your eyes and steal your dreams.
When answering my questions please use a qualifier if you are not sure.
The more I work on this car the less I respect German engineering.
When you speak in Absolutes you are always wrong!
Semper Fi
