Results 1 to 3 of 3
Thread: 2012 750i Misfire
    Feb 2017
    Immokalee, FL
    2012 bmw 750i
    2012 750i Misfire
    Hello everyone I have a 2012 750i that I recently had new heads put on. I start the car and have 5 codes and they are. (150402 Ignition, cylinder 3 combustion time too short) (140402 misfire cylinder 4 exhaust gas damaging after startup) (142002 Misfire tank fill level too low) (140801 combustion misfire, cylinder 8 injection will be switched off) (140601 misfire cylinder 6 injection shutdown) Car will start but idles like crap. Any help/advice will be greatly appreciated!
    Feb 2017
    Immokalee, FL
    2012 bmw 750i
    No answer so far, have swapped coils and injectors around and misfire does not jump.
    Dec 2012
    North Carolina
    2009 335i M-Sport Coupe
    Why were new heads required? Was there cylinder or head damage? Did you use new or used heads? What index are your injectors? You may need to do a compression or leakdown test.
  1. 750i Misfire only cylinder 2
    By Testosteroneric in forum 2002 - 2008 (E65, E66)
    Last Post: 02-15-2017, 12:43 PM
  2. 2012 750i issues could use some input
    By hmedeiros0912 in forum 2009+ (F01,F02,G11,G12)
    Last Post: 08-12-2015, 10:07 PM
  3. 2012 750i issues, anyone else?
    By hmedeiros0912 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-18-2015, 04:21 PM
  4. Replies: 1
    Last Post: 02-13-2014, 01:57 PM
  5. 2012 750i no fog lights?
    By AJ750i in forum Lighting sponsored by BAVToys
    Last Post: 11-29-2011, 09:20 AM
