Greetings fellow BF.com FI
Last summer was pretty good. Car worked OK, Wastegate was too small so the tune was very conservative after 5k rpm....
But still Got 630hp and 810nm/600ft-lbs
After abusing last fall... did some parting out... Sold M50NV intake and M54 intake cams for friends Drifter project
Well what then, Decided to order bigger 60mm wastegate, E-throttle from ls7, Deatschwerks FPR, New An-lines from fuel, New mac valve for wastegate.
Then some new Rims
Looks Okay to me
Before Xmas dropped manifold for friend to weld new WG flange
Good old TIG weld
Sprayed some Coating of VHT Flameproof
Manifold back at it and Tested how new ''World's'' best 60mm WG would fit.
And cause i cant stand gates vacuum line... All are done by AN-4 and fittings.
Turbo to below WG port, Top of can to MAC valve
MAC Valve switched place to Strut tower...
Original Fuel lines were, rotten so they decided to go retirement
Nice things to own King E36... AN-8 Straight to OEM places
Jaa suodatinta perään
And for 2k19 Engine setup:
M50B28 Engine
M52b28 Head with Vanos
Maxxspeedingrods H-beams https://www.maxpeedingrods.com/
M52B28 pistons
S52B32Us cams (anyone have good timing for these??) or just stock?
Garrett GTW3884R with T3 1.15ar Twinscroll
Maxxecu race Standalone Engine management( Controls VANOS, etc..)http://www.maxxecu.com/
Bosch EV14 2200cc Injectors from https://www.finjector.com/
Wahlbro 450lph In-tank Fuel pump
New INA 33mm or (35mm) Lifters
HKS style 60mm WG
ARP headstuds + ARP Main Studs
Hopefully to see 500whp with 24psi And e85 corn juice
very nice car and impressive numbers, also on the ALU M52 bottom end, makes me more confident about my M52!
can I ask what head bolts/studs you used when you where on stock ALU M52 bottom end?
Thank u sir! First Page 530hp/650nm were on alumium Block... 1.1bar of boost back then and Stock(Febi Bilstein was manufacturer) head bolts, M50NV Conrods with ARP bolts. Bolts ain't really the issue... Block threads are. There are Timeserts for ALU block that should solve the issue.
thanks! I know it is the threads, but this seems to only happen after overheating. durin 34 celcius weather this year, my e36 stayed at the right operating temperature while pushing it pretty hard at 0,8bar. I am changing my GT28 to a HX35 now, so was hoping I could up the boost a bit. 400hp at 1bar would be nice! and it seems I can do that on stock bolts. was thinking about going for the raceware studs for the M54 otherwise. I don't want to timesert the engine since my power goals for now is only 400hp and it is a lot of work.
thanks a lot for your input! appreciatie it!
No e85 for me, its hard to get around here. 98RON or even 102RON is easily available here. will be tuning on 98.
Is yours Montreal blue btw? Paint looks in great condition!
Yes it is Montrealblau! Should polish it again in summer
Yeah! We might have just hit 500whp mark last year.... Debeaded tyre so dyno did say 430whp LOL
It is possible to hit 800 crank @26psi , if i that Garrettmotion boost adviser is right
Do u have any good timing for those s52 cams?
So finally today arrived parts from states. Hot boiii cams
Now all I have to do is just put it together.. These were last parts. Oh and got Dash-8 adaptors To Flexfuel sensor. From www.finjector.com
Decided To not assembly Supertech valvesprings yet. Sticking with 33mm Ina lifters and Oem B28 springs. Those are good to 7500rpm at least.
Dreaming Forged pistons and 6870 precision maybe In future.
So got the timing advice from sweden... Intake stock and Exhaust 1.5mm open TDC. Sounds about good... Well see..
Sooo.... Been running this car now like few months, after got it finally Dynoed. Same tuner as Last time, good and professional tuning.
Final numbers, 720hv/820nm of torq. Around 22psi.
And Finally decided To use Maxxecus Traction control Mode, n boost control by gear. 1-2 is 12psi of boost and 3 To 5 is 22psi.
All seems To work nice... Great once again
Nice! any video's/pics?
Yeah! Nothing much upgrades here, still rocking same 3year ago build "budget" engine, and it has had seen some abuse.
I did upgrade the driveshaft for CV joint model, from e36 3.0 m3 tho.
Upgraded smaller exhaust housing for gtw3884r now 1.00ar T3 twinscroll.. Finally seeing 1bar boost @~4k
Also did 4port Mac valve for boost control, but haven't tested it yet, curious To find out difference In boost pickup.
Pull @22psi
This year curious To find out what does 28psi do for powercurve
It has been nice summerdaily To be honest, lot of smiles
And King of engines
Few vids of Last year bimmerparty
https://youtu.be/FcFqjwp5E80
https://youtu.be/c1k3BK8xfTc
LOLLIES
that M50 angels drawing is cool! like your shifter too.
this makes me want a montreal blue sedan!
How is the Mac valve handling the heat from the turbo being so close? I’m trying to figure out where to put mine.
Hey Matuh, how have you found the MaxxECU? I'm looking for something that's ideally plug and play for my M52B28 E36 compact and they seem to fit the bill. How did you find tuning, features and options? Got any knowledge comparison to other ECU options?
