Page 8 of 15 FirstFirst 123456789101112131415 LastLast
Results 176 to 200 of 370
Thread: Restoring a 2001 750iL that sat for 3 years
  1. #176
    Feb 2014
    MA
    2000 750iL
    Quote Originally Posted by XAlt View Post
    Thermostat is electronically controlled. As long as it gets up to temp fairly fast, it's doing its job.
    Yes it does get up to temp OK.
    I am somehow concern about the 110 coolant temp while its cold season right now. Am thinking It will go higher when the weather get warmer
  2. #177
    Jul 2016
    Chicago, Illinois
    are slow
    Quote Originally Posted by masu3701 View Post
    As long as the fan clutch is doing it's job, and you get a new aux fan you'll be good.
  3. #178
    Feb 2014
    MA
    2000 750iL
    When does the aux fan suppose to kick in? Does it turn on while driving? or only in traffic or while the ac on?
  4. #179
    Jul 2016
    Chicago, Illinois
    are slow
    -AC on above 45F
    -Past a certain temp (I think 105C)
  5. #180
    Feb 2014
    MA
    2000 750iL
    -AC on above 45F
    That could be a reason to why the coolant temp going high. The aux fan doesnt turn at all
  6. #181
    Feb 2014
    MA
    2000 750iL
    Haven't completely sorted the issue with my cooling system. Now am having major misfiring codes.
    Getting these codes:
    P0300 (Random Multiple Misfire)
    P0307 (Cylinder 7)
    P0308 (Cylinder 8)
    P0309 (Cylinder 9)
    P0310 (Cylinder 10)
    P0311 (Cylinder 11)
    P0312 (Cylinder 12)
    P1270
    P1456 ( I know its heated Cats)
    P0141 ( Oxygen sensor bank 1 and 2)
    P0161 (oxygen sensor)
    P0136 (oxygen sensor)
    Where to start. Please help
    NOTE: All the cylinders are on the same side of the block
  7. #182
    Jul 2016
    Chicago, Illinois
    are slow
    Since the cat was gutted, I assume it was just running extra rich and not misfiring until now, get the DUDMD tune once you've solved this. Both O2s should in theory still be functional. Don't worry about the 110C for now.
    Coils, spark plugs dist cap and rotors are the first part, then the plugs. It's fairly a ancient setup and dates back to the M20 era. After that, fuel supply would be the next culprit.
  8. #183
    Feb 2014
    MA
    2000 750iL
    Well I can't do much when the coolant temp gets up there. now its getting to 111-115. have to always turn engine off to let it cool off or it will go to red.
    When it comes to the misfiring, I remember opening the oil cap and pulling oil dip stick when engine was running. Thinking that that may have turn the CEL. Deleted code. will see if they come back.
    Can someone help me out straightened up the cooling system. Am not bleeding it right. Can hear the water circulating while driving. e
  9. #184
    Jul 2016
    Chicago, Illinois
    are slow
    Yeah, that might be it. I'd start suspecting the fan clutch and water pump at this point.
  10. #185
    Feb 2014
    MA
    2000 750iL
    How can I test both the fan clutch and water pump?
    When am driving with slow acceleration the temp seem to stay around 108-111.
    Once I start giving it more gas that's when the temp start rising higher. Or I should say sometime the temp is fine , and then will just go up and up
  11. #186
    Dec 2013
    Chicagoland area
    EXOTICS
    Been trying to trace a coolant leak but cant find it. I would top it off, drive for a bit, then coolant would be low next time I check it.
    Did compression test, losing pressure very slowly but cant find any leaks. Any suggestions?
    Perform a cylinder leakdown test on misfiring cylinder bank.
  12. #187
    Dec 2015
    DMV
    00 BMW 750
    P0307 (Cylinder 7)
    P0308 (Cylinder 8)
    P0309 (Cylinder 9)
    P0310 (Cylinder 10)
    P0311 (Cylinder 11)
    P0312 (Cylinder 12)
    P1270
    Don't quote me on this, but I think the P1456 could just be the ekat module under the passenger seat. I had the P1459 and it was taken care of by replacing the module. In your case though, you could probably just get the DUDMD tune to code that module out of the system in order to run after market cats.
  13. #188
    DUDMD's Avatar
    DUDMD is offline BMW Maniac Supporting Vendor
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Replace oxygen sensors if you haven't done yet, only the front/primary o2 sensors affect engine running, the rear o2s just check for cats and don't affect anything else.
    You could also have a bad distributor, coil pack, maf, or a huge vacuum leak on that bank. So get a smoke test done for both banks to rule out any vacuum leaks, as those are common on the v12 and are hard to find without the use of a smoke machine.
    Performance Tuning and EWS Delete for MSS52/MSS54/MSS54HP/MS41/MS42/MS43/ME7.2/M5.2
    Virgnize DME service available to unlock DME to sync to another vehicle on EWS3 vehicles 98+. M5.2.1, M7.2, MS42, MS43, MS45, ME9.2 and more.
    Easiest way to contact me is to send me a message on my facebook page "DUDMD Tuning"
  14. #189
    Feb 2014
    MA
    2000 750iL
    Quote Originally Posted by DUDMD View Post
    I belive code P1270 is related to the maf sensor.
    I did try to find a vac leak using carb cleaner but no luck. Will try smoke test
  15. #190
    Oct 2014
    NE
    2000 740IL
    sent u an email masu with pics of that 5hp30 lmk if u got it and if ur interested.
  16. #191
    Feb 2014
    MA
    2000 750iL
    Quote Originally Posted by MIKYZZ4 View Post
    Did the head leak test.. turned yellow
  17. #192
    Feb 2014
    MA
    2000 750iL
    <img src="https://www.bimmerforums.com/forum/attachment.php?attachmentid=595283"/>
    <img src="https://www.bimmerforums.com/forum/attachment.php?attachmentid=595282"/>
    How accurate are these tests? Mine turned yellow right away, even before engine start getting worm.
    What would my options be if it got bad head gaskets?
  18. #193
    Dec 2013
    Chicagoland area
    EXOTICS
    If it turned from blue to yellow right away, that indicates that combustion gases are entering the cooling system.
    The symptoms of a failed headgasket. Seems like you had a lot of bubbling too.
  19. #194
    Feb 2014
    MA
    2000 750iL
    Yes it was bubbling
  20. #195
    Dec 2013
    Chicagoland area
    EXOTICS
    I'm afraid your headgasket has failed. To bring this engine back from the dead, you are going to have to ask someone who is more familiar with a v12.
    I think this is a project you should pass on, but if you have the guts, knowledge and $$$-Good Luck!
  21. #196
    Kansas City, MO
    2x01 750, 01 740
    Head gasket parts are expensive, especially if you replace the intake manifold gaskets too.
    That's about all there is to say on the subject.
    See my E38 parts for sale on eBay: click here!
    PM me here for a 5% discount on any of them!
  22. #197
    Jul 2016
    Chicago, Illinois
    are slow
    If you choose to part out, put in some HG snake sealant, drive it until the wheels fall off and even then you can probably recoup your losses without the ekat.
    board75596 did the job on his car and is around sometimes. But honestly I don't think it's worth it unless you're really planning on keeping it and it looks like it was overheated for a fairly long period of time. The other option would be to get the M73 out of the silver car, refresh the cooling\igniton components and replace it, which is probably more feasible.
    Quote Originally Posted by psjr View Post
    You can also do it like the M70 guys, speyshul sealant and call it a day.
  23. #198
    Feb 2014
    MA
    2000 750iL
    <img src="https://www.bimmerforums.com/forum/attachment.php?attachmentid=595313"/>
    Does that sealant stuff work?
  24. #199
    Jul 2016
    Chicago, Illinois
    are slow
    In theory, yes. It's not optimal and can take collateral, flush the crap out of the water after compression has been been restored. How long it lasts may vary but there's nothing to lose at this point.
    Some guy on E46fanatics used Moroso 35500 on a built S50 and raced a car for about a year on it, so I'd use that.
  25. #200
    Jul 2016
    Chicago, Illinois
    are slow
    But yea, flush it hard with tap water. It doesn't work with antifreeze at all until it's sealed.
  1. Looking at a 2004 that has sat for 4 years.
    By GymRat in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 11-12-2015, 06:40 PM
  2. Replies: 6
    Last Post: 11-20-2012, 03:07 PM
  3. Purchased 92 325i that sat for 2 years....got some Q's
    By meen325 in forum 1991 - 1999 (E36)
    Last Post: 05-21-2009, 07:10 AM
  4. Trashed Black F-250 that sat for 7 months
    By zaxjax in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 10-17-2008, 08:08 PM
  5. Just bought an e36 that sat for a year... what now?
    By morganbressler in forum 1991 - 1999 (E36)
    Last Post: 08-08-2006, 10:30 PM
