get a german made filter like Hengst. no need for expensive bmw oil filter.
Checked coolant today, was at correct level but still reading low..still added lil coolant. maybe a bad sensor. What a bitch.
Took the car on a 25 miles trip, not overheating but coolant temp varies between 108 and 113..at one point it got to 116 under heavy acceleration. But temp gauge stays at 12 oclock.
When crossing it set between 108 and 111.
Are these temperatures too high for this engine?
Shouldn't pass 110, are you reading it from the LCD cluster? Gauge is a mechanical idiot light more or less, once it passes 120C it'll go straight into the red. Please drain the oil before doing anything else and going on long trips, and it also obviously helps cool the engine.
You can use Wix\Napa Gold filters if you need it for tomorrow. Just get it drained ASAP, no reason to chase your tail when the car is running on milkshake.
Replacee old today..coolant temp goes to around 110. And i some point it went down to 89 once cruising at higher speed then back up..but that one time it went that low.
It seem to get stay at 108-110 when cruising around 40 miles per hour.. but if going really slow or getting to a stop it get to 111 and few times to 113.
seems fine thats where mine have always run--right around there.
as long as it doesnt sit around or pass 115 c its OK
110c is the highest temp you should ever see unless air in the system or maybe fan clutch is bad...
Yes it definitely runs a lot cooler.
I drained about 10 quarts oil of oil. Isn't that too much?
Added 8.5 quarts of new oil mobile1 0w40 and the dip stick still read low. I get the right reading at about lil over 9 quarts.
The electric fan is bad. doesn't turn.
what year is car? i have fan for pre facelift
My efan doesnt work either and car still does not go above 110c... I bought an e39 aftermarket fan from ebay that will go in before summer for $99...
http://www.ebay.com/itm/152362829334
why would u go with cheap chinese junk aftermarket fan purp? i give that thing a couple months if it isnt already DOA lol
Didnt get any input on the 10 quarts oil. has anyone experience the above?
So i sucked out 1 quart of oil..went on another 25 miles ride.. coolant temp varies between 108 and 110..most of the time its at 110. Few times it got to 111 for few seconds then back to 110.
Hope i got it right this time.
How to check if thermostat is opening? If I put the ignition to open position, heat on high and fan on low, and open the extension tank and bleeder screw, Shouldn't I see coolant circulating and going back into the tank from the lil hole ?
On this car nothing is happening when I have both the cap off and bleeder screw off while the heat is on high and fan on low.
