Page 14 of 15 FirstFirst ... 456789101112131415 LastLast
Results 326 to 350 of 370
Thread: Restoring a 2001 750iL that sat for 3 years
  1. #326
    Jul 2016
    Chicago, Illinois
    are slow
    It's out there and easy to find, that's all I'll say...
  2. #327
    Feb 2014
    MA
    2000 750iL
    Quote Originally Posted by masu3701 View Post
    Removing those broken maybe a pain. And i wont be able to remove the block of the car to be checked due to the fact that am working in my drive way.
    How do i put engine at TDC? I dont see the mark on the flywheel. Only 3 holes that are togther and another one far away. I see a mark on the block but now on the wheel.
    I was able to place the lock tool flat but not sure if am at tdc.
  3. #328
    Jul 2016
    Chicago, Illinois
    are slow
  4. #329
    Oct 2014
    NE
    2000 740IL
    Quote Originally Posted by XAlt View Post
    finally u stop spoon feeding this guy...........
  5. #330
    Jul 2016
    Chicago, Illinois
    are slow
    Quote Originally Posted by mooll View Post
    Bf.c is spoonfeed central. I'm fine with it though, everybody will eventually realize the power of google.
  6. #331
    Feb 2014
    MA
    2000 750iL
    While trying to loosen the clutch fan bolt using a long screw driver to hold it from rotating, the plastic pulley and the it bolts broken. Now the pulley is off in pieces.
    Is there a trick to remove this fan bolt in this case?
    Jul 2016
    Chicago, Illinois
    are slow
    Remember, reverse thread. Snap a pic if you can.
  8. #333
    Feb 2014
    MA
    2000 750iL
    Upade:
    was able to undo the exhausts from the under the car and removed the from timing cover. Oh boy..this engine is full of junks, so tick it looks like melted black plastic. Removed all the head bolts on one side and only 1 is broken. Some of them are very dry and 3 or 4 were socked in oil.
    That at one head is free to come out..can move it from the front but it's extremely hard to pull up. Requires a lot force.
    This engine looks like it will need a lot.
  9. #334
    Feb 2014
    MA
    2000 750iL
    What are you guys buying for spark plugs? the bmw are 17$ vs NGK 8$ on FCP Auro
  10. #335
    Dec 2013
    Chicagoland area
    EXOTICS
    NGK,exact same part, without the BMW logo.
  11. #336
    Feb 2014
    MA
    2000 750iL
    What other parts should I replace while the engine is apart ?
  12. #337
    Jul 2016
    Chicago, Illinois
    are slow
    The little OSV tubes and cooling system based on what you see. Remember, $8 renzosil gets the job done on the intake gaskets.
  13. #338
    Jul 2015
    Dallas, Texas
    98 750iL, 01 740iL
    coils, plugs, wires, OSV+CCV, vac hoses on both sides of intake that connect to back, assuming those are for the OSV+CCV, distributor caps/rotors
  14. #339
    Feb 2014
    MA
    2000 750iL
    After digging into this engine full of gunk and debris, broken head bolts etc, I came across a used motor out of a 2000 750 for $700 with 110k.
    Now the plan is to pull out the engine am working on rebuilding and put in the used one, then will continue to rebuild the other slowly as I get money and time.
    Whats the complexity of swapping engine? I don't have a lift.
  15. #340
    Jul 2016
    Chicago, Illinois
    are slow
    Should just drop down out of the subframe. Get somebody with a lift to take care of it.
    If you get the M73N for so cheap, just clean it up real nice, seal up the intakes, and use the other for spares.
  16. #341
    Feb 2014
    MA
    2000 750iL
    Whats a reasonable price to have someone with a lift install it?
  17. #342
    Jul 2016
    Chicago, Illinois
    are slow
    I'd get some quotes, and we'll see who has the best. Really depends on the market. While you wait, clean up the new engine.
  18. #343
    Feb 2014
    MA
    2000 750iL
    When I called around, the cheap side was $1000 to just drop and swap nothing else.
    Was thinking about just replacing the rear main seal and water pump while engine is out, then will deal with the other stuff once I can confirm that engine runs fine.
  19. #344
    May 2012
    1991 850i
    i just paid close to 2k to replace engine on my e60 n54b30 ... had a rod knocking
    used engine was from 335 ...slightly different , one of the turbos had to be swapped , some oil lines , coolant lines and oil pan
    on top of that i got new water pump , thermostat , rear main seal , oil filter gasket , oil pan gasket , valve cover gasket , spark plugs
    just various part came up to around 450 , water pump , thermostat and coil plugs i got of my old engine - only 5k miles
  20. #345
    Feb 2014
    MA
    2000 750iL
    Quote Originally Posted by pavrom View Post
    Yea the $1000 is just removing old one and i stalling new one..i will have to provide de parts i want to change such as water pump, stat, rear main seal and whatever i want to replace.
    For now the plan is to replace rear main seal, water pump/stat, spark plugs then once i confirm engine runs strong i will work on replacing the rest as i go
  21. #346
    Jul 2016
    Chicago, Illinois
    are slow
    1k sounds decent.
    They'll remount the trans, so you can go ahead and inspect it while it's out.
  22. #347
    Feb 2014
    MA
    2000 750iL
    1k sounds decent.
    Engine coming out of the car tomorrow...
    Rear main seal, valve cover gaskets, spark plugs, water pump are all being delivered tomorrow morning and will be ready to go on right away.
    Couldnt get the crank pulley bolt until wednesday next week. Can the old one be reused or a new one is a most?
  23. #348
    Jul 2016
    Chicago, Illinois
    are slow
    New crank jesus bolt, always.
  24. #349
    Feb 2014
    MA
    2000 750iL
    New engine installed Yesturday. Run good. Coolant temp still on the high side (113C), but temp gauge stays at 12 o'clock. May have to bleed it more.
    In addition to the coolant temp, am chasing a new issue with the brake. The pedal is very hard, have to floor it and fight with it to stop. Seem like i lost the pressure.
    Where to look. Is there a vacuum line going to it that I may have miss?
  25. #350
    Feb 2014
    MA
    2000 750iL
    I have no power to the DSC pre charge pump.
  1. Looking at a 2004 that has sat for 4 years.
    By GymRat in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 11-12-2015, 06:40 PM
  2. Replies: 6
    Last Post: 11-20-2012, 03:07 PM
  3. Purchased 92 325i that sat for 2 years....got some Q's
    By meen325 in forum 1991 - 1999 (E36)
    Last Post: 05-21-2009, 07:10 AM
  4. Trashed Black F-250 that sat for 7 months
    By zaxjax in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 10-17-2008, 08:08 PM
  5. Just bought an e36 that sat for a year... what now?
    By morganbressler in forum 1991 - 1999 (E36)
    Last Post: 08-08-2006, 10:30 PM
