Page 13 of 15 FirstFirst ... 3456789101112131415 LastLast
Results 301 to 325 of 370
Thread: Restoring a 2001 750iL that sat for 3 years
  1. #301
    Feb 2014
    MA
    2000 750iL
    WHere to buy the cam locking tool?
  2. #302
    Jul 2016
    Chicago, Illinois
    are slow
  3. #303
    Jul 2016
    Chicago, Illinois
    are slow
  4. #304
    Dec 2013
    Chicagoland area
    EXOTICS
    The best, from what we're told in these forums:https://www.germanautosolutions.com/..._bmw_tools.php
  5. #305
    Jul 2016
    Chicago, Illinois
    are slow
    Quote Originally Posted by MIKYZZ4 View Post
    The best, from what we're told in these forms:https://www.germanautosolutions.com/..._bmw_tools.php
    They don't offer the M40\M7x set though IIRC.
    The last link appears to be a Japanese-made tool, fairly high quality. Nevermind, they're based in Cali.
  6. #306
    Feb 2014
    MA
    2000 750iL
    I will need 2 correct?
  7. #307
    Jul 2016
    Chicago, Illinois
    are slow
    Quote Originally Posted by masu3701 View Post
    Yea.
  8. #308
    Feb 2014
    MA
    2000 750iL
    Quote Originally Posted by XAlt View Post
    Yea.
    Then this one will be expensive if I have to get 2.
    http://www.ebay.com/itm/Master-Camsh...rue&rmvSB=true
  9. #309
    Jul 2016
    Chicago, Illinois
    are slow
    Nah, that's all the tools for various engines.
    http://www.autotoolsexpress.com/item/1277691/
    https://shop.ktcautotools.com/produc...-bmw-c020-c022
    https://www.amazon.com/BMW-Camshaft-.../dp/B011DV3JQ6
    Just these.
  10. #310
    Feb 2014
    MA
    2000 750iL
    Will get 2 of the one on amazon. it comes from US, so may get it sooner
  11. #311
    Feb 2014
    MA
    2000 750iL
    Tool ordered.
    Broke 1 fuel injector while removing the fuel rail. The plastic robber on those injectors are so dry they crack easily.
    Any recommendation on injectors?
  12. #312
    Jul 2016
    Chicago, Illinois
    are slow
    The injectors are actually specific to the M73N, you can't put in a mustang injector like the pre-98, so they are pretty pricey. I'd go reman for the broken one.
    http://www.ebay.com/itm/Fuel-Injecto...dYlrFV&vxp=mtr
    http://www.ebay.com/itm/BMW-E38-750i...9UJHav&vxp=mtr
  13. #313
    Feb 2014
    MA
    2000 750iL
    Yea i just need 1. Will replace the o rings and maybe the plastic tubings
  14. #314
    Feb 2014
    MA
    2000 750iL
    Before these machine shop kill me with their pricing, can someone point out the parts I MUST replace/recondition and what I can leave with when taking the heads to machine shop.
    Is it necessary to also service the block? or just the heads?
  15. #315
    Jul 2016
    Chicago, Illinois
    are slow
    Just the heads, sometimes it might not even be warped, take a good look. Inspect each gasket and support gaskets, the set is pretty expensive.
  16. #316
    Feb 2014
    MA
    2000 750iL
    Yea didnt want to go too crazy on this, but at the same time I dont want to do it twice.
  17. #317
    Jul 2016
    Chicago, Illinois
    are slow
    Yea,
    Avoid the intake gaskets and just use $12 Renzosil.
    $25 each Victor Reinz head gaskets.
    The support gaskets are tricky, Elring seems to be avaliable overseas for about $200 each.
  18. #318
    Feb 2014
    MA
    2000 750iL
    Yea,
    Support gasket?
  19. #319
    Jul 2016
    Chicago, Illinois
    are slow
    Support gasket?
    The head gasket set.
    https://www.ecstuning.com/b-genuine-...t/11129068137/
    http://m.ebay.com/itm/HEAD-GASKET-SE...%257Ciid%253A2
    Minus the machining,
    $50 for the head gaskets
    $12 sealant for the intake
    $250-300 for the other stuff.
    $70 on the bolts
  20. #320
    Jul 2016
    Chicago, Illinois
    are slow
    If the head checks out, you can save on the set.
  21. #321
    Feb 2014
    MA
    2000 750iL
    Found more loose head bolts and another broken one on both sides..
    When Calculating the cost of all the gaskets and machine shop work, am thinking about going the used engine swap route.
    Found an engine from LKQ for $900.. came out of a 1998 750 with 127k on it.
    Will ths engine be interchangable with the year 2000? If so i may considere getting it and just do the valve gaskets, and other lil things.
    Any suggestions?
  22. #322
    Jul 2016
    Chicago, Illinois
    are slow
    Moving a Pre-1999 M73 to an N is a job you don't want. Injectors, Alternator, ECU, recoding, etc
    I'd go forth with the job, just save money on the gaskets. It might not even be warped.
  23. #323
    Feb 2014
    MA
    2000 750iL
    Machining shouldn't be that bad, and that's if they find anything.
    Removing those broken maybe a pain. And i wont be able to remove the block of the car to be checked due to the fact that am working in my drive way.
  24. #324
    Jul 2016
    Chicago, Illinois
    are slow
    Lift the heads. Extract them, inspect, and see if they really do need to be machined. Resurfacing shouldn't be too bad.
    Just get them checked, you're either very close or very far away from getting the main event.
  25. #325
    Feb 2014
    MA
    2000 750iL
    Where can I download the BMW TIS software for the 7 Series?
  1. Looking at a 2004 that has sat for 4 years.
    By GymRat in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 11-12-2015, 06:40 PM
  2. Replies: 6
    Last Post: 11-20-2012, 03:07 PM
  3. Purchased 92 325i that sat for 2 years....got some Q's
    By meen325 in forum 1991 - 1999 (E36)
    Last Post: 05-21-2009, 07:10 AM
  4. Trashed Black F-250 that sat for 7 months
    By zaxjax in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 10-17-2008, 08:08 PM
  5. Just bought an e36 that sat for a year... what now?
    By morganbressler in forum 1991 - 1999 (E36)
    Last Post: 08-08-2006, 10:30 PM
