Rad support is done for, one fender, the hood and probably half the front suspension. You have a perfect donor car to fix that Cali car. Shock towers don't look mangled from here.
Doesn't look too bad to fix if you get it cheap, and you won't have to worry about the HG.
So I decided I will start taking the engine apart and see how far I can go. Nothing to lose at this point.
If it turns out bad I will use it as a practice/learning play ground.
Side note: Even with a bad head gasket, this engine drives incredibly smooth. Cant even tell it has issues, which makes me think the head is not the issue, but how else would
combustion gas enter the cooling system ??? And the oil dip stick is clean, not milky at all.
It's the head if it failed the combustion gas test. The reason for no oil contamination?, possibly due to only a coolant passage being affected near the area of gasket failure, and not an oil passage. You'll notice this once you examine the head and block decks.
Yes, and the combustion gas bubbles you've observed confirms it.
A real leakdown test can absolutely confirm gasket failure and path of combustion gas escape.
Awesome! Glad to see you going this route. As you say, nothing to really loose at this point. Especially if its not currently your DD. You can even spread the cost of the expensive parts out over time if thats the case.
In the end, you'll learn a lot and have a freshly re-built v12!
Yes sir...started pulling things out.. not bad so far. Learning a lot actually. Taking a lot pictures as i go.
Here are some picts. Alot of the plastic are hard and do brake. The injectors plastic peaces are dry hard.. one broke.
Yesterday it was nice outside, so I went on and did a lil more pulling. Was struggling removing the intake bottom bolts by using a U joint, but then quickly realized that if I took off the injector sound proof out ( 3 bolts), I could
then insert a long extension and go straight down to the bolt. Doing it that way took about 5 minutes per side. At the back of the intakes are the oil separators, one side broke.
So far I have both intakes and valve cover out. It will be cold for the next couple of days, so will see continue when we get a warmer day.
Here are some pictures.
They look fairly nice, save for all the water and sludge pockets at the front. I'm glad you're saving this from the crusher.
When you get to the pistons, be very careful with not touching the walls. Degreaser and/or sanding will eat the dull grey paste.
Glad you're able to view this as a valuable learning experience, and at your own pace and leisure. Must be nice, lol.
Hands-on experience truly upgrades the knowledge level vs knowledge gained from research alone,
good luck and happy wrenching!
Getting ready to attack the removal of the heads.
Can someone enlighten me on how to go about locking the cams and removing the heads. The plan is to remove the heads and take them to machine shop for resurfacing ( is it necessary?).
Do I have to remove the cams, springs, and valves before sending the heads off?
The M73 is fairly similar to the M70. The E32 forum should also be useful for help with timing.
http://bmwe32.masscom.net/sean750/en...0rebuild_1.htm
http://bimmerboard.com/forums/posts/1211972
decided to inspect the head bolts while researching on how to do the timing, and found 2 loose and 1 broken bolts on left side head
and 1 broken bold on right side head. Those that are broken I was able to pull them straight out. All the loose and broken bolts are on the exhaust side
They are one time use bolts, are they not? Previous mechanics had other ideas.
Like I said, previous mechanics had other ideas regarding the one-time use policy, lol.
I trust you wouldn't commit such errors. The error of their ways is confirmed by the evidence.
Does anyone know how to remove the exhaust heat shield plates on the side of the heads? Trying to remove it so that I can see if I have room to remove the exhaust manifolds from the top.
