Wanted:Passenger side headlight cover.05 Z4.Thanks.
I imagine it's not very often that the housing gets damaged, but the lens is still intact?
I noticed some moisture/fogging inside my passenger headlight. I haven't had a chance to investigate the extent of the damage yet, hoping it's fixable.
Some (most?) cars headlights, the lens are held onto the housing with a few screws and silicon seal around the edge. On my old car, I was able to perform the ghetto stick it in the oven trick to loosen the silicon and take apart the lens from the housing. I'm hoping to do something similar with the Z4, to avoid having to buy a whole new headlight unit. Please note I haven't investigated this at all yet, please don't stick your headlight in an oven.
Oy that sucks. Well, I guess I'm hoping that I can blow out the moisture with a hair dryer, then maybe the crack/damage is small enough that I could cover it with a bit of silicone that won't be noticeable. Otherwise I'll have to buy a new headlight unit ($250+) but I sure as hell will try the oven + dremel on the old one. If it works I can just resell the one I bought. I will certainly report back, but it'll be a while, gotta get it past inspection first.
