Page 5 of 6 FirstFirst 123456 LastLast
Results 101 to 125 of 130
Thread: Z3 coupe L33 twin 6262
  1. #101
    Mar 2019
    Milwaukee, WI
    '99 LS-swapped 323i vert
    Quote Originally Posted by fallguy View Post
    I didn’t want to use anything less than a 1350 u joint. Unfortunately the z3 is tight in that area. So angle grinder... hammer and welder sorted it out.
    Umm, wow!
    Diving in at the shallow end!
  2. #102
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
  3. #103
    Jul 2018
    Louisiana
    Bmw E39 528i
    Dang you made nice work of that, you got skills.
  4. #104
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Thanks guys I pretty happy with the way it’s turning out. But not supper happy about the exhaust going under the cross member. But the only way to get it above worth the twin turbos is to join the two 3” into one 4” and go right where the AC compressor is.... but I like the idea of AC lol. Or fender exit lol.
    tried pressing these bushings out with the pipe method.... it just ripped the centre out. So burning them out it was.... worked pretty well. Then dropped it off for semi gloss black powder.
    A58E8A94-0D8F-4180-809B-F43654378A5F.jpgA12E6B02-C4DD-42D5-B8CD-E0406B5BA47A.jpg22FF7AA8-639C-4B36-8158-19FEE9929665.jpg
  5. #105
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Just bled the clutch and reinstalled the modified cross member. Got it powder coated semi gloss. Nothing too exciting
  6. #106
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I love this! Nice work. Could you go oval single 4” on the exhaust?
  7. #107
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    I could. If it ends up rubbing I will change it out. The problem with oval is the bends are only on a horizontal or vertical plane. So if you want to come up at an angle it’s hard to do. With round you can clock it any way you want.
  8. #108
    Nov 2015
    kelowna
    Z3 Coupe 3.0
  9. #109
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    just working on the heater core lines, found a VW at the wrecker that had the same fittings but in 90deg. The straight one was pointing right at my engine. And got my 9” setback shifter.
  10. #110
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Still lots to do. But it fired up.
  11. #111
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
    That shifter is sweet.
  12. #112
    Mar 2019
    Milwaukee, WI
    That is great! Congrats.
  13. #113
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Excellent!
  14. #114
    Nov 2015
    kelowna
    Z3 Coupe 3.0
  15. #115
    Nov 2005
    Finland
    Z3 Coupe individual
    Sounds great!
    Z3 & E36 RamAir systems, send private message for more information.
  16. #116
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
  17. #117
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Thanks guys.
    got the 996 calipers and the 345mm M3 CSL rotors on.
  18. #118
    Nov 2015
    kelowna
    Z3 Coupe 3.0
  19. #119
    Nov 2015
    kelowna
    Z3 Coupe 3.0
  20. #120
    Nov 2015
    kelowna
    Z3 Coupe 3.0
  21. #121
    Indianapolis
    F30 328d X-Drive
    Shifter fits perfect in there. Nice work on placement. I need to do some work on where mine ends up in my RX-7. When Its in 2,4,6 the shifter is basically touching the trim at the back of the boot. I have a Steeda Tri-ax handle. I think I just need to go with something that jogs back an inch or two then goes straight up instead of at an angle.
    1995 Mazda RX-7 Feed Widebody LS3 6-speed (Toy, project)
    2010 Cadillac Escalade Luxury (Daily, Pulls my 18' car hauler)
    2014 BMW 328d XDrive (Wife's Daily)
    Have owned 4 other BWM's I no longer have.
  22. #122
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Thanks in hindsight I would’ve went with the Magnum XL and had the LS shaft swapped in
    I got the driveshaft installed today.
  23. #123
    Indianapolis
    F30 328d X-Drive
    How's the project looking in 2021?! Have this beast out on the road yet?
  24. #124
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    its not going too bad, was out on the road a bit before i put it away for winter in December. Was having some cooling issues added a fan shroud and a 160deg stat, it seems to be helping before it would get to 220deg now it seems to be 190ish.
    I'm going to add another muffler in the tunnel to tone it down a bit, the single 4" is a bit much with just one straight thru vibrant muffler.
    https://youtu.be/974UGjUj7gY
    https://youtu.be/yUIldGFrins
  25. #125
    Jul 2011
    Houston
    LS e39, LT e53,
    How do you have your heater core lines ran?
    2003 X5 4.6is - for sale
    2006 X5 L83 5.3 6l80 swapped in progress - for sale
    1999 528i 5.7L 4l60e swapped w/ 31 spline 8.8 cobra diff - for sale
    2007 ZX-10r - sold
    1987 R-10 SWB L83 5.3L 6L80e swapped
    www.87chevy.com
  1. Turbo Z3 M Coupe vs Twin Turbo Gallardo [vid]
    By drdre0728 in forum Kill Stories
    Last Post: 11-27-2013, 11:06 AM
  2. Z3 E36/7 FS BMW NOAH Z3 Coupe Car Cover
    By Wojtek79 in forum Z3,Z4,Z8 Classifieds
    Last Post: 11-01-2009, 01:21 PM
  3. Z3 E36/7 OEM 3 series modified to fit a z3 coupe for sale.
    By wheelieh in forum Z3,Z4,Z8 Classifieds
    Last Post: 03-16-2009, 12:20 PM
  4. Z3 E36/7 WTB: Stock airbox for my 2000 Z3 coupe
    By Tackleberry in forum Z3,Z4,Z8 Classifieds
    Last Post: 03-11-2009, 08:47 PM
  5. Z3 E36/7 FS-Z3 Coupe Original ACS Rear Wing
    By Ian 2.0 in forum Z3,Z4,Z8 Classifieds
    Last Post: 03-04-2009, 02:43 AM
